Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna
#13
3.6
based on 20 reviews
Ratings Distribution
5 star
8
4 star
5
3 star
1
2 star
2
1 star
4
Category Average
3.9
Low Price:
$74.99 at drugstore.com
 Trusted:
$93.99 at MacMall
$76.99 at ClubMac
see all stores
$74.99 - $109.00
from 11 stores
More Images
Pros
  • Easy to use (14)
  • Clear signal (6)
  • Lightweight (6)
  • Good reception (4)
  • Rugged (3)
  • Durable (2)
  • Good range (2)
  • Good value (2)
  • Can't even name one (1)
  • Enhanced our roadtrip (1)
See less See more
Cons
  • Short range (7)
  • Poor reception / weak antenna (4)
  • Heavy / bulky (1)
  • Just bad (1)
  • Poor battery life (1)
  • Poor quality (1)
  • Poor quality speaker (1)
  • The side mounted mic jack (1)
Best Uses
  • Emergencies (6)
  • Camping (4)
  • Road travel (4)
  • Hiking (2)
  • 4x4 trail (1)
  • 99 dollar paperweight (1)
  • Driving (1)
  • Hobby (1)
  • Leasure (1)
  • Off roading (1)
Provided by OutdoorPros.com
Cobra Electronics Road Trip Cb, Road Trip, 40 Channels 4 Watt (HH ROAD TRIP) Cobra Electronics Corporation is a leading designer of mobile communications products in the United States, Canada, Europe and around the world. After 50 years of innovation, the company continues to grow by boldly entering into new product categories. Whatever your outdoor activity, Cobra's compact handheld CB radios are a great way to stay in touch with friends. Complete access to 10 National Weather Channels (7 NOAA and 3 International) for the latest weather information. And there are no license or service fees! Cobra's HH ROADTRIP incorporates SoundTracker, a patent-pending technology that dramatically improves the sound quality of the transmission and reception of CB radio signals. Cobra Electronics Road Trip Cb, Road Trip, 40 Channels 4 Watt (HH ROAD TRIP) Features: • NOAA All Weather Emergency Radio • Mobile Mag Mount Antenna Included • SoundTracker System • 10 Channel Weather Reception • 4 Watts Power Output
Specification Description
Model 028377200472, HH ROAD TRIP, HH-ROADTRIP, HHROADTRIP
UPC 028377200472
Antenna Type Magnet mount mobile antenna
Benefits 10 national weather channels alert you to dangerous storms, so you can take a safer routeLow battery indicator and high/low power swi
Capacity UOM mAh
Channels 40 Channels
Country Of Origin Hong Kong
Description Header On the road again.
Display Catalog Number 55012554
End Product Indicator Yes
Features 4 watts of output power keep your signals going strong across 40 CB channelsOmni-directional microphone picks up voice from many dire
Frequency Range 26.965-27.405MHz
Included in the Box Handset unitMagnet mount mobile antenna
Includes NOAA Weather Channels Yes
Inputs 1 x (Antenna)
Manufacturer Labor Warranty 2
Manufacturer Part Number HH-ROADTRIP
Manufacturer Parts Warranty 2
MAP Price 0.0
Model HH-ROADTRIP
Operating Temperature UOM ° F
Outputs 1 x (Speaker jack)
Power 4 watts
Product Dimensions UOM inches
Product Disclaimer Warranty is 2 years limited.
Product Height 6.75
Product Length 1.75
Product Type CB radios
Product Weight 2.4
Product Weight UOM pounds
Product Width 2
Radio System Indicators Low battery
Radio System Type Handheld
Required to function 9 "AA" alkaline or Ni-Cd batteries
Supported Languages English
Weather Alert Yes
Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna Questions
Questions and Answers
Where to Buy
$99.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$74.99
BizRate Rating Outstanding 9.2
$76.99
Show all 11 stores
Product Reviews
Last update: Oct 21, 2009
Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
[15 of 15 customers found this review helpful]
4.0
Crazy range for hand-held!!!
"I live on the north of Long Island. I get Connecticut, New Jersey, New York City, no sweat. The mag mount is pretty good, but I recommend upgrading. Small size, but internal speaker is poor quality. Also, squelch is kinda weird. It resets every different channel you change. Kinda heavy with batteries. Got a lapel speaker/mic and love it. The rubber ducky is also poor...." Read Full Review »
Jan 03, 2009 by MustangMan
See more positive Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna reviews
3.0
Rubber duck antenna is TUNEABLE
"OK, here's something that will help you greatly if you bought this product and don't get any reception and/or can't "get out" on the transmit while using the mag mount external rubber duck antenna. None of the following is in the owner's manual and it should be. You'll need an SWR meter to tune the mag mount rubber duck antenna. Place the antenna on the vehicle and plug the antenna into the SWR meter and the ..." Read Full Review »
Mar 08, 2008 by Putz
See more negative Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
3.0
    Pros
  • Clear Signal
  • Easy To Use
    Cons
  • Bulky
  • Short Range
    Best Uses
  • Emergencies
You'll need an SWR meter to tune …"  Read Full Review »
Was this Communication System review on the Cobra Golf HH 38 WX ST CB Radio With A Magnetic Mount Antenna helpful to you?
 Report Abuse  (15)  (0)  0 comments
Mar 8 2008
Putz
Farmington, MI
I am:
  • Casual/ Recreational
Reviewed at:
Price: $99.99
4.0
    Pros
  • Clear Signal
  • Easy To Use
    Cons
    Best Uses
  • Leasure
  • Traffic advoidance
"I live on the north of Long Island. I get Connecticut, New Jersey, New York City, no sweat. The mag mount is pretty good, but I recommend upgrading. Small size, but internal speaker is poor quality. Also, squelch is kinda weird. It resets every different channel you change. Kinda heavy with batterie …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Jan 3 2009
MustangMan
Mount Sinai, New York
I am:
  • Casual Adventurer
Reviewed at:
Price: $99.99
[1 of 2 customers found this review helpful]
Weak product, don't waste your money!
1.0
    Pros
    Cons
  • Poor Reception
  • Short Range
    Best Uses
"I bought this unit to use for off-roading in and out of my 2007 Jeep. I pick up nothing but static from inside my Jeep, even when hooked up to the external antenna supplied. Likewise, I'm unable to send with the external antenna. Hooking the DC power cord to the cig lighter outlet in the Jeep pro …"  Read Full Review »
 Report Abuse  (1)  (1)  0 comments
Feb 7 2008
Carl
Farmington Hills, MI
I am:
Reviewed at:
Price: $99.99
This Handheld CB Exceeded My Expectation
5.0
    Pros
  • Easy To Use
  • Excellent car charger op
  • Good Range
  • Good Reception
  • More »
    Cons
  • None
    Best Uses
  • Road Travel
"Drove pace car for 4,642 mile road trip. Except for me, all parties were on motorcycles. I was able to communicate with my group up to nearly a mile on line-of-sight. Used the car power adaptor for the entire trip. The magnetic attenna must have been perfectly tuned. I bought this CB specifically …"  Read Full Review »
Jul 11 2009
Pacecar Driver
New Mexico
I am:
  • Practical
Reviewed at:
Price: $99.99
Nice starter CB
4.0
    Pros
  • Clear Signal
  • Easy To Use
  • Scan Mode
  • Sound Tracker Mode
    Cons
  • None
    Best Uses
  • Driving
"Good if this is your first CB. I like the scan mode to see whos out there. I mostly use it to listen on how the roads are. The sound tracker mode works awesome. It cuts down the static by about 70%. Its a nice CB. "
Dec 27 2007
MacGyver *64*
Pennsylvania
Reviewed at:
Price: $99.99
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
