Cobra Electronics Cobra XRS9960G 15 Band Radar/Laser Detector
#121
3.5
based on 4 reviews
from $201.00 - $389.95
Ratings Distribution
5 star
0
4 star
3
3 star
0
2 star
1
1 star
0
Category Average
3.9
More Images
Pros
  • Easy to mount (3)
  • Neat features or extras (2)
  • Clear alert (1)
  • Durable (1)
  • Easy setup (1)
  • Easy to use (1)
  • Good sensitivity (1)
  • Pleasant audio (1)
  • Quality construction (1)
See less See more
Cons
  • Gives false reads (1)
  • Gps does disconnect (1)
  • More false alerts (1)
Best Uses
  • Urban navigation (3)
  • Highway driving (1)
  • Larger cars (1)
  • Replacement (1)
  • Rural navigation (1)
  • Small cars (1)
  • Upgrade (1)
Provided by RadarBusters.com
The XRS-9960G provides total protection and peace of mind with Super-Xtreme Range Superheterodyne Technology, detecting 15 radar/laser bands with its super-fast lock-on detection circuitry. the unit provides extra detection range and the best possible advance warning to even the fastest of POP mode radar guns. It comes with the Cobra exclusive full-color ExtremeBright DataGrafix Display II, and 8-point electronic compass, Voice Alert, and car battery voltage display/low car battery warning.
Enjoy advanced features like these:
AURA camera database - GPS-based technology warns the driver of fixed speed and red light cameras, speed traps, and dangerous intersections across North America. The AURA database is updated daily and provides the industry's most complete and accurate coverage and reliability. GPS locator and lifetime subscription included.
Intelliscope - provides information about the direction of location based alerts relative to your moving vehicle using GPS.
Programmable location alert - add up to 1,000 location-based alerts of your choice. Also provides alert when exceeding driver-preset speed limit.
Digital speedometer - provides accurate, current vehicle speed using GPS.
Full color DataGrafix display - 1.5 inch OLED display provides enhanced data display in easy-to-read vivid colors with 3D graphics. Allows user to select from 5 different color schemes to match your dash illumination.
Car battery voltage/low battery warning - provides approximate voltage of your car's battery and also alerts user whenever car battery voltage falls below 11.9 volts.
POP mode - detects the latest Radar gun POP mode.
Ku band detection - detects Ku band radar gun currently being used in Europe. Be ready if it come to the US.
IntelliMute - relative speed sensing auto-mute system that virtually eliminates false alerts.
IntelliMute Pro - relative speed sensing auto shutdown feature will render your detector undetectable by currently available radar detector-detectors.
Voice alert - provides the user with specific band voice annunciation.
Strobe alert - a Cobra exclusive, works with tens of thousands of emergency vehicles currently equipped with traffic light controlling strobe emmitters. Provides advanced alert of the presence and/or approach of these vehicles.
SmartPower - automatically shuts off power to the unit when ignition is turned off.
LaserEye - provides 360 degree detection of laser signals.
VG-2 alert - alerts the user when they are under surveillance of VG-2 radar detector-detectors.
VG-2 undetectable - provides complete immunity to VG-2 radar detector-detectors.
Spectre alert - alerts user when they are under surveillance of Spectre I/IV+ radar detector-detectors.
IntelliShield false signal rejection - reduces the frequency of falsing in densely populated urban areas. The city mode has 3 levels of setting for enhanced false signal rejection.
City/highway modes - allows the user to select operating mode, reducing the frequency of falsing in densely populated urban areas.
Auto mute - automatically mutes the alert tone for enhanced driver convenience.
EasySet programming menu - user-friendly mode selection/setting with visual guidance.
Specification Description
Model COBRA XRS9960G, XRS 9960G, XRS-9960G, XRS9960G
UPC 028377105203
Benefits AURA™ camera and driving database warns you of speed traps, red light cameras and moreIntelliView™ features picture-in-pict
Cables Included DC power cord
Capacity UOM mAh
Connections Power (1)
Country Of Origin China
Description Header For extreme protection.
Display Catalog Number 55032687
End Product Indicator Yes
Features POP mode detects the latest POP Mode radar gunsLaserEye® provides 360° detection of laser signalsVoice Alert™ w
Included in the Box XRS 9960GGPS locator and lifetime subscription to AURA databaseMini-USB to USB adapter cable12V DC power cord<
Manufacturer Labor Warranty 12
Manufacturer Part Number XRS 9960G
Manufacturer Parts Warranty 12
MAP Price 0.0
Model XRS 9960G
Operating Temperature UOM ° F
Power Device DC power cord
Product Depth 1.9
Product Dimensions UOM inches
Product Height 5.2
Product Type Radar/laser with POP Alert
Product Weight 6.5
Product Weight UOM ounces
Product Width 3.1
Supported Languages English
Cobra Electronics Cobra XRS9960G 15 Band Radar/Laser Detector Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Sep 29, 2009
Cobra Electronics Cobra XRS9960G 15 Band Radar/Laser Detector Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Much better than previous Cobra
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Pleasant Audio
  • Quality Construction
    Cons
  • More False Alerts
    Best Uses
  • Replacement
  • Upgrade
"I owned a Cobra previously that did most of what this one does, but the sensitivity of this radar detector is far superior. It actually compares now with my Escort 9500i in most situations.
Previous detector would pick up road side radar signs about the time the radar would pick up the vehicle. …"  Read Full Review »
Was this Radar & Laser Detector review on the Cobra Electronics Cobra XRS9960G 15 Band Radar/Laser Detector helpful to you?
 Report Abuse  (1)  (0)  0 comments
Apr 9 2009
Slyice
Dallas, TX
I am:
  • Enthusiast
Reviewed at:
Cobra does a good job here
4.0
    Pros
  • Clear Alert
  • Easy To Mount
  • Good Sensitivity
  • Neat Features or Extras
    Cons
    Best Uses
  • City Driving
  • Highway Driving
  • Larger Cars
  • Rural Driving
  • Small Cars
"Unit behaves quite nicely, excellent features. Like the GPS although it does have a tendency to disconnect and require me to pull the GPS module and reinsert to get it to reaquire. Screen is large and very easily readable, very bright. price was good for all of the features that were included.
V …"  Read Full Review »
Sep 29 2009
JDpageland
Monroe, NC
I am:
  • Gearhead
  • Practical
  • Techhead
  • Tuner
Reviewed at:
red light camera map - very poor
2.0
    Pros
  • Easy To Mount
    Cons
  • Gives False Reads
    Best Uses
  • City Driving
"It not have in data base all red light camera in Brooklyn "
Jun 7 2009
kiskin60
Brooklyn,NY
I am:
  • Gearhead
Reviewed at:
Worth the money!!!!!!!!
4.0
    Pros
  • Durable
  • Easy To Mount
    Cons
  • None
    Best Uses
  • City Driving
"Great for commuting, have'nt seen a camera yet. "
Jun 18 2009
Fast Eddie
Chicago, Illinois
I am:
  • Practical
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
