Cisco Systems Wireless-G Access Point with Power Over Ethernet and RangeBooster (Model #WAP200)
#219
3.4
based on 7 reviews
Ratings Distribution
5 star
3
4 star
1
3 star
1
2 star
0
1 star
2
Category Average
3.9
$117.00 - $131.99
from 10 stores
More Images
Provided by ClubMac
Wireless-G Access Point with Power Over Ethernet and RangeBooster High-speed wireless access for existing networks! Features standards-based POE or External DC power, RangeBooster technology, advanced wireless security and support for WMM. High-Speed Wireless Access for Existing Networks!• Standards-based POE (IEEE 802.3af) or External DC power• RangeBooster technology for up to twice the range, reduced dead spots, and up to 35% more throughput than standard Wireless-G• Advanced wireless security using Wi-Fi Protected Access (WPA2) with up to 256-bit encryption, and new Security Monitoring Feature gives your business the visibility and protection it needs• Support for WMM provides improved QoS over wireless connections for better video and voice performance.RangeBooster technology is a compatible add-on to standard Wireless-G which increases your wireless network's range up to two times, and its throughput by up to 35%. Unlike ordinary wireless technologies that are confused by signal reflections, RangeBooster uses two smart receivers at each end to detect and decode reflected signals at distances where standard technologies give up. You'll find that "dead spots" in the wireless coverage area are reduced, too.The Advanced security features makes this solution ideal for your Business. Advanced wireless security using Wi-Fi Protected Access (WPA2 Enterprise) with up to 256-bit encryption, and the new Wireless Security Monitoring functionality gives your business the visibility and protection it needs. Used when Linksys 200-Series Wireless Adapters are present, the Wireless Security Monitoring functionality alerts you of possible wireless intruders, vulnerabilities in the wireless deployment, and visibility into Denial of Service attacks.The Linksys WAP200 Access Point lets you connect Wireless-G (802.11g) or Wireless-B (802.11b) devices to your wired network so you can add PCs to the network with no cabling hassle. Power over Ethernet support makes it easy to install -- you can mount the Access Point anywhere, even without ready access to a power plug. With appropriate Power Over Ethernet support at the other end, you only need to run one cable to the Access Point to deliver both data and power. Of course, you can also use the included AC adapter if your installation point has power available nearby.Moreover, the integrated QoS features provide consistent voice and video quality on both the wired and wireless networks, enabling the deployment of business qualilty VoIP and video applications.Additional features like Multiple BSSIDs, Wireless Roaming, Auto-channel selection, and Load Balancing, make this solution ideal for your Business.Features:• 10BASE-T/100Base-TX Ethernet port, autosensing half/full duplex & MDI/MDI-X• Full backwards compatibility with 802.11b• Easy installation and configuration• Supports WEP, WPA-PSK, WPA2-PSK, WPA-ENT, WPA2--ENT authentication (802.11i ready)• SMA detachable dipole antennae with 1x2 MIMO to increase coverage• Supports Power over Ethernet (PoE) or external DC power• Supports 4 BSSID and 802.1Q VLAN to SSID mapping• Supports SNMP and intuitive web-based interface• WMM wireless QoS support - upgradeable to 802.11e• Supports wireless roaming based on 802.11F (IAPP)• Supports AP, Bridge Mode and Repeater mode• Supports wireless security monitoring (working together with 200 series client cards)• Supports wireless client isolationSpecificationsStandards: IEEE802.11g, IEEE802.11b, IEEE802.3, IEEE802.3u, IEEE802.3af (Power Over Ethernet), 802.1p (QoS priority), 802.1q (VLAN), 802.1X (Security Authentication), 802.11i - Ready (Security WPA2), 802.11e - Ready (Wireless QoS), 802.11F (Wireless Roaming)Ports: 10BASE-T/100BASE-TX Ethernet, 12 VDC PowerButtons: ResetCabling Type: UTP CAT 5LEDs: Power, PoE, Wireless, EthernetOperating System: LinuxSetup/ConfigWebUI: Built-in Web UI for Easy Browser-based Configuration (HTTP/HTTPS)ManagementSNMP Version: SNMP Version 1, 2c, 3Event Logging: E-mail Notification / Remote SyslogWeb F/W upgrade: Firmware Upgradable Through Web-BrowserDiags: Flash, etc.: Diags: Flash, RAM, LAN, WLANDHCP: DHCP ClientOperating ModesAccess Point: Access Point Mode, Point-to-Point Bridge Mode, Point-to-Multipoint Bridge Mode, Repeater ModeWirelessSpec/Modulation: Radio and Modulation Type: 802.11b/DSSS, 11g/OFDMChannels: Operating Channels: 11 North America, 13 Most of Europe (ETSI and Japan)# of External Ant.: 2 (Omni-Directional) SMA detachableTransmit Power: Transmit Power (Adjustable) @ Normal Temp Range: 11b - 18~19 dBm; 11g - 14~15 dBmAntenna Gain in dBi: 2Receiver Sensitivity: 11.g: 54 Mbps@ -72 dBm, 11.b: 11 Mbps@ -85 dBMSecurityWEP/WPA/WPA2: WEP 64-Bit/128-Bit, WPA-PSK, WPA2-PSK, WPA-ENT, WPA2-ENTAccess Control: Wireless Connection Control: MAC-BasedSSID Broadcast: SSID Broadcast Enable/Disable802.1X: IEEE 802.1X supportWireless Client Isolation: Wireless Client Devices Can Be Isolated from Each Other either within an SSID or between Two SSIDsWireless Security Monitor: Scan and Classify Wireless Devices in the NetworkReport New Client and AP joining Network and Suspicious Network Events (Works together with 200 Business series client adapters):    1. Intrusion Alarms (e.g., Rogue Client Detected, Spoofed MAC address)    2. Denial of Service Alarms (e.g., Duration Attack, Association Table Full)    3. Vulnerability Alarms (e.g., AP is not using encryption, AP is broadcasting SSID)    4. Other Alarms (e.g., Low speed connection)Quality of ServiceQoS: 4 Queues / WMM Wireless PriorityMinimum Requirements:• 802.11b, 802.11g Wireless Adapter With TCP/IP Protocol Installed Per PC• Switch/Router with Power Over Ethernet (PoE) Support Or PoE Injector when used with PoE• Web-Based Configuration Java-Enabled Web Browser
Specification Description
Model WAP200
UPC 745883574452
Wireless Transfer Rate 54 Mbps
Cisco Systems Wireless-G Access Point with Power Over Ethernet and RangeBooster (Model #WAP200) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 26, 2009
Cisco Systems Wireless-G Access Point with Power Over Ethernet and RangeBooster (Model #WAP200) Reviews
Displaying 1 - 5 of 7 Reviews
Show
Sort by
[9 of 9 customers found this review helpful]
I'm hard to please... WAP 200 really good product (4 of 5)
4.0
"I needed to wirelessly network a Brooklyn Brownstone approximately 45' long by 100 feet tall 4 floors. Initially started with the Netgear
RANGEMAX WIRELESS ROUTER Netgear RangeMax Wireless Router (WPN824)because of the advertised (last year Sept)
-MIMO (Multi-In, Multi-Out) technology boosts netw …"  Read Full Review »
Was this Wireless Networking review on the Cisco Systems Wireless-G Access Point with Power Over Ethernet and RangeBooster (Model #WAP200) helpful to you?
 Report Abuse  (9)  (0)  0 comments
May 23 2007
H. asHley
New York
Reviewed at:
Price: $131.99
[2 of 2 customers found this review helpful]
Very Satisfied
5.0
"Buying an access point (or wireless equiment for that matter) is a tricky business since you never know how the different devices in the network will work together and setups it also a comfusing business...
I decided to buy this product after reading several buyers reviews that recommended this prod …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Sep 20 2007
Tom Goren-Bar
Israel
Reviewed at:
Price: $131.99
excellent features and range, but other issues
3.0
"other reviewers have covered the good feature set of this unit. it's a good small business model. I was most impressed with it's inclusion of 4 separate SSIDs with selective isolation and security.
it has a great range. was able to cover an entire 7500 sq ft. machining facility with plenty of mech …"  Read Full Review »
Sep 24 2007
Orbital
Greensboro, NC USA
Reviewed at:
Price: $131.99
Firmware bugs and reliability issues
1.0
"I purchased three of these units and used them for about 6 months. The WAP200 is not a quality product. There is a firmware bug in the unit that produces a ton of broadcast ping's throughout the network. After 6 months, Linksys posted a firmware update to address this problem. After attempting t …"  Read Full Review »
Apr 15 2008
D. Hecht
Ocala, FL
Reviewed at:
Price: $131.99
Great acccess point, no ...
5.0
"Great acccess point, no problems, solid conection. Have a computer conecting 40ft away through a cinderblock wall and windows says its an exelent conection. Security features are great. I also just found out my new Blackberry is not WPA, witch is secure. It only supports WEP which I know is insecure …"  Read Full Review »
Jun 26 2009
glenn
Undisclosed
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
