#555
based on 13 reviews
Ratings Distribution
| 5 star |
3 |
| 4 star |
2 |
| 3 star |
2 |
| 2 star |
0 |
| 1 star |
6 |
Category Average
$75.99 - $99.99
from 5 storesPros
Cons
Best Uses
Where to Buy
BizRate Rating
Good 8.9
$75.99 |
BizRate Rating
Good 8.7
$76.99 |
at
ClubMac
$76.99 |
at
OnSale
Product Reviews
[5 of 5 customers found this review helpful]
"I prefer to use two-stud support.I had a narrow wall space with molding on both sides.In order to support to second stud I had to drill two more holes for the lag screws in the back plate. I like the slide plates that secure the tv brackets. Better than hexhead screw support.Nice design feature plus security lockable too...." Read Full Review »
Jan 28, 2009 by Mr. Fixit
"Pros This wall mount seems to be sturdy, made of a thick metal material, and durable, even though I could not use it. It would have been overall easy to put up once you found your studs in the wall. I would recommend it to a friend if they did not have the VIZIO VX37L 37-INCH LCD HDTV. Cons This tv would not fit my VIZIO VX37L 37-INCH LCD HDTV. The mounting holes where bolts connect the mount to the tv are of..." Read Full Review »
Dec 17, 2007 by Anonymous
Displaying 1 - 5 of 13 Reviews
Chief Manufacturing Universal Medium Tilting LCD/Plasma Wall Mount (Screens up to 40") Review
"Pros
Cons
This
Read Full Review »
"Pros
Cons
This tv
Read Full Review »
"Pros
NONE!! Well maybe if DELL sent the right size bracket when you go through the customization options on their website when purchasing a TV.
Cons
Not the right size bracket to fit Sony Bravia 40". Looks like I am not the only one with this issue. You can only use one set of screw holes at the
Read Full Review »
Pros
Cons
Best Uses
Read Full Review »
[3 of 3 customers found this review helpful]
"Pros
Would have been a relatively easy install if it fit the TV
Cons
Does not fit the Visio 37" tv, even though recommended as part of the customize options with that TV. The back panel is too short for TV mounts to even fasten onto.
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Good 8.9
$75.99 |
BizRate Rating
Good 8.7
$76.99 |
at
ClubMac
$76.99 |
at
OnSale
BizRate Rating
Good 8.9
$87.99 |
at
MacMall
BizRate Rating
Good 8.7
$99.99 |
at
Dell
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
