Chief Manufacturing PDR Universal Dual Swing Out Arm Plasma Wall Mount
#138
4.7
based on 6 reviews
Ratings Distribution
5 star
4
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
$592.79 - $665.00
from 4 stores
More Images
Pros
  • Adjustable (2)
  • Easy to install (2)
  • Interfaces well with tv (2)
  • Multiple viewing angles (2)
  • Sturdy (2)
See less See more
Best Uses
  • Changing viewing angle (2)
  • Home (2)
  • Bedroom (1)
  • Family/living room (1)
  • Office (1)
Provided by Mounts and More
View your new plasma or LCD display from any angle with the best mount that money can buy. The new PDR™ Dual Arm Plasma Wall Mount, which features greater range than anything else on the market, swings out and extends up to 36" (91.44 cm) from the wall, collapsing to only 2-7/8" (74 mm) when in home position! The PDR includes all of the standard features you can expect from a Chief mount, plus several new exclusive features developed specifically for the PDR plasma mount.
Best of all, any orders for this mount placed before 1:00pm EST will ship out SAME DAY (BLACK MODEL ONLY)! Silver model will still ship out NEXT DAY.
Features:
  • Articulating arm allows for up to 90° of swivel (depending on size of screen)
  • Easy Installation - Wall bracket can be placed on wall using convenient mount guides
  • Gravity-Centered Tilt™ No tools necessary for position adjustments
  • Integrated Lateral Shift Up to 9" (229 mm) – 2" (51 mm) left/right of 16" (406 mm) stud system without disassembly
  • Built-In Cable Management Channels inside the arms provide a clean installation
  • Q-Latch™ Mounting System Used on all Chief Large Flat Panel Mounts, this system uses a lockable latch to safely secure display to the mount
  • Unmatched Extension, Remains Low-Profile in Home Position Extends 36" (91.44 cm) from the wall, only 2-7/8" (74 mm) deep when collapsed
  • Height Adjustment Post-installation height adjustment up to 3" (76 mm) for ultimate installation flexibility
  • Independently Adjustable Tension at Pivot Points Provides customized control
  • Rubber stops protect the wall when arms are collapsed
  • Mounts easily with centers on 16" studs
  • Universal interface to accommodate a broader range of screens
  • Comes in a black or silver finish
  • Distance from wall: 2.88" (not including interface bracket)
  • Max Extension from wall: 36"
  • Weight capacity: 200 lbs
NOTE: If you have a 65" Panasonic, you will need an additional PSB bracket. Please call for details.
PDR Articulating Plasma Wall Mount Installation Instructions
PDR Articulating Plasma Wall Mount Technical Data
Chief warrants its products (excluding electric, gas cylinder, and one-way bearing mechanisms) to be free of defects in material and workmanship for 10 years.
PLEASE NOTE: This item cannot be shipped to Puerto Rico
About Chief Manufacturing
For over a quarter of a century, Chief has been an industry leader in manufacturing total support solutions for presentation systems. Chief's commitment to responding to growing industry needs is evident through a full line of mounts, lifts, and accessories for LCD/DLP/CRT and flat panels utilizing and technologies.
Chief is known for producing the original Roll, Pitch, and Yaw adjustments in 1978 to make projector mount installation and registration quick and easy. Today, Chief continues to provide innovative mount features, including the first-ever seismic-rated LCD and plasma wall mounts. For the highest quality in AV mounting, no name is trusted more than Chief.
All Chief products are designed and manufactured at Chief's main headquarters in Minnesota. Most mounts will ship within 24-48 hours: if you need your projector, LCD, or plasma mount fast, give us a call!
Chief Manufacturing PDR Universal Dual Swing Out Arm Plasma Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Apr 18, 2009
Chief Manufacturing PDR Universal Dual Swing Out Arm Plasma Wall Mount Reviews
Displaying 1 - 5 of 6 Reviews
Show
Sort by
Fantastic mount. Easy to use.
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Changing Viewing Angle
  • Family/Living Room
  • Home
  • Office
"Maximize the amount of studs you hit. The bracket weighs 50lbs plus my 150lbs Panasonic Plasma. "
Was this TV Wall Mount review on the Chief Manufacturing PDR Universal Dual Swing Out Arm Plasma Wall Mount helpful to you?
Apr 18 2009
User in Houston
Houston
I am:
  • Enthusiast
Reviewed at:
Price: $592.79
Very smooth transaction
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Home
"Perfect length to help enable flexibility. Very easy to adjust for great viewing from all angles. "
Mar 28 2008
S-B
St. Louis, MO
Reviewed at:
Price: $592.79
improvement comments
4.0
"Mount is well constructed, and operates as described in the description.
I would like to see additional Vertical adjustment (longer jack-screw
Cable tracks in arms redesigned to travel through the swing joints
Thanks for the prompt delivery and Quality of your product
Regards,
T Randall "
Dec 29 2006
T Randall
Vancouver
Reviewed at:
Price: $592.79
PDR CHIEF 2000 MOUNT
5.0
"it arrived well packaged, and with good directions, My husband and I had no trouble mounting our 50 inch tv by ourselves, and it works wonderfully, thanks! "
Mar 19 2007
Ms. Mellon
CA
Reviewed at:
Price: $592.79
bitchin' mount -- the best
5.0
"the best mount there is. why compromise with anything else? "
Feb 16 2007
tommy licious
L.A.
Reviewed at:
Price: $592.79
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
