Chief Manufacturing JWD-210 Dual Swing Arm Plasma Wall Mount
#32
4.8
based on 13 reviews
from $113.99 - $225.00
Ratings Distribution
5 star
11
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
More Images
Pros
  • Easy to install (8)
  • Sturdy (8)
  • Adjustable (7)
  • Multiple viewing angles (6)
  • Interfaces well with tv (4)
  • Blends well (1)
  • Can support weight (1)
  • Center not offset mount (1)
  • Substantial beefy support (1)
See less See more
Cons
  • Fits not in small area (1)
  • Poor interface with tv (1)
  • See comments (1)
  • Too much adjustability (1)
Best Uses
  • Changing viewing angle (4)
  • Office (3)
  • Bedroom (2)
  • Home (2)
  • Classroom (1)
  • Corner mounting (1)
  • Family/living room (1)
  • Kitchen (1)
Provided by CSN Stores
Sleek designs with sophisticated adjustments, Chief's new Small Flat Panel Display Wall Mounts provide various ranges of motion and features.
Chief’s FWD-110 Dual Swing Arm LCDWall Mount provides a broad range of motion for viewing Small Flat Panel Displays from multiple angles. Folds in close to the wall for a low profile appearance.
Best of all, any orders for the FWD-V in Black placed before 1:00pm EST will ship out SAME DAY! The remaining models will still ship out NEXT DAY!
Features:
  • VESA compliant (75 mm x 75 mm / 100 mm x 100mm / optional 100mm x 200mm). Interface brackets available for non-VESA® compliant displays (see related products).
  • Ships assembled
  • Easy installation – Attach wall plate to single stud. Attach display to mount. Slide mount onto plate. Secure hardware.
  • Sleek, attractive design hides all hardware
  • Smooth Pitch adjustment 15 degrees up, 15 degrees down by hand. Gravity-centered Pitch self-adjusts to securely hold different display weights.
  • Portrait/landscape rotation 360°
  • Independently adjustable tension at pivot points for customized control. Tension can be optimized for touchscreen use.
  • Color options: Silver Metallic or Black
  • Mount remains hidden behind the display when folded against the wall
  • Quick, easy cable management
  • Depth in closed position: 2.15"
  • Maximum extension: 15.93"
  • Pivot at wall plate: 180 degrees
  • Pivot at arm connection: 360 degrees
  • Pivot at display connection: 180 degrees
  • Overall Dimensions: 12.18"H x 8.18"W x 2.15"D
  • Weight Capacity: 40 lbs.
Chief warrants its products (excluding electric, gas cylinder, and one-way bearing mechanisms) to be free of defects in material and workmanship for 10 years.
PLEASE NOTE: This item cannot be shipped to Puerto Rico
FWD Dual Swing LCD Wall Mount Installation Instructions
About Chief Manufacturing
For over a quarter of a century, Chief has been an industry leader in manufacturing total support solutions for presentation systems. Chief's commitment to responding to growing industry needs is evident through a full line of mounts, lifts, and accessories for LCD/DLP/CRT and flat panels utilizing and technologies.
Chief is known for producing the original Roll, Pitch, and Yaw adjustments in 1978 to make projector mount installation and registration quick and easy. Today, Chief continues to provide innovative mount features, including the first-ever seismic-rated LCD and plasma wall mounts. For the highest quality in AV mounting, no name is trusted more than Chief.
All Chief products are designed and manufactured at Chief's main headquarters in Minnesota. Most mounts will ship within 24-48 hours: if you need your projector, LCD, or plasma mount fast, give us a call!
Chief Manufacturing JWD-210 Dual Swing Arm Plasma Wall Mount Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 23, 2009
Chief Manufacturing JWD-210 Dual Swing Arm Plasma Wall Mount Reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
Far Better Than Competition
5.0
    Pros
  • Center not offset Mount
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • More »
    Cons
  • None
    Best Uses
  • None
"I carefully and systematically compared all major competition for 22 inch LCD on-wall mounting. Major competitors including Sanus and Omnimount offer either a very flimsy "small" size articulating mount with poor reviews online, or huge bulky "medium" size articulating mount with a huge flat metal …"  Read Full Review »
Was this TV Wall Mount review on the Chief Manufacturing JWD-210 Dual Swing Arm Plasma Wall Mount helpful to you?
Jun 5 2008
Lman
Denver, CO
I am:
  • Tech Savvy
Reviewed at:
Price: $113.99
Product does more than really needed :-)
4.0
    Pros
  • Easy To Install
  • Sturdy
    Cons
  • See comments
    Best Uses
  • Bedroom
  • Changing Viewing Angle
  • Classroom
  • Home
  • Office
"Very nice product. Strong, cool looking, no biggie to install. A multi-purpose wall mounting plate/device would be nice in case the stud isn't quite where you need it to be. Front/back tilt is great. Would have given 5 stars if not for the included lateral tilt adjustment. (you can tilt the screen l …"  Read Full Review »
Aug 1 2008
bronx
New York
I am:
  • Able to use a drill
  • Practical
  • Tech Savvy
Reviewed at:
Price: $113.99
Excellent Wall Mount
5.0
    Pros
  • Can Support Weight
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Family/Living Room
"We bought an articulating arm mount so that we could mount our TV between the kitchen and den and swing it to point either way. It mounted on the stud in the wall, was straight forward to install and worked as advertised. I worried about getting the mount exactly vertical for fear that the TV would …"  Read Full Review »
Jun 23 2009
Bill in Connecticut
Middletown, CT
I am:
  • Casual User
Reviewed at:
Price: $113.99
Excellent Mount
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • none
    Best Uses
  • Home
  • Office
"This is an extremely sturdy mount and will be easy to mount for anyone with even moderate skill with a power drill. Only two (long) screws need to be placed into a stud. The mount allows for easy switching from portrait to landscape. For those that are more do-it-yourself challenged the equivalent …"  Read Full Review »
Feb 12 2008
Tech Pro
New Jersey
I am:
  • Professional
  • Tech Savvy
Reviewed at:
Price: $113.99
Solidly Built, Easy to Install.
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • Poor Interface With TV
    Best Uses
  • Corner mounting
"This mount is impressive. The ONLY thing I didn't like about it was that the VESA plate is held to the TV with some very very tiny screws. They are suspiciously small!
I'm sure they're fine, and I have not had any problems, but it made me incredulous when installing the mount. "
Jan 1 2008
David
Rochester, NY
I am:
  • Tech Savvy
Reviewed at:
Price: $113.99
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
