Chief Manufacturing Height-Adjustable Single Swing Arm LCD Desk Mount in Silver
#360
4.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$198.26 at CSN Stores
 Trusted:
$198.26 at Mounts and More
Find it at Amazon
$198.26
from 2 stores
More Images
Pros
  • Adjustable (1)
  • Easy to install (1)
  • Multiple viewing angles (1)
  • Sturdy (1)
See less See more
Best Uses
  • Office (1)
Provided by CSN Stores
Chief's KCV-110 Height-Adjustable Single Swing Arm LCD Desk Mount provides excellent adjustability using only one arm. Attaches to horizontal surfaces with grommet or direct clamp options.
Features:
  • VESA compliant (75 mm / 100 mm). Interface brackets available for non-VESA® compliant displays (see related products).
  • Ships assembled
  • Easy installation – Top-down mounting (clamp options do not require hardware to be assembled from the underside of the mounting surface).
  • Clean look - Minimal hardware visible from underside of work surface
  • Centris Pitch Mechanism provides infinite 15 degrees up, 15 degrees down, 15 degrees left and 15 degrees right by hand. Gravity-centered pitch self-adjusts to securely hold different display weights.
  • Quick, easy cable management
  • Independently adjustable tension at pivot points for customized control. Tension can be optimized for touchscreen use.
  • Color: Silver Metallic
  • Also available in Black
Specifications:
  • Depth in closed position: 2.17"
  • Maximum extension: 12.38"
  • Pivot at desk attachment: 360 degrees
  • Pivot at display connection: 180 degrees
  • Weight Capacity: 25 lbs.
  • Overall Dimensions: 7-5/8"H x 5-5/8"W x 7/8"D
Mounting Options:
  • Edge Clamp (works for surface thicknesses between 0.50" and 2.375")
  • Grommet Clamp (works for surface thicknesses between 0.50" and 2.375")
  • Grommet Hole Size: 0.375" - 3.0"
Chief warrants its products (excluding electric, gas cylinder, and one-way bearing mechanisms) to be free of defects in material and workmanship for 10 years.
PLEASE NOTE: This item cannot be shipped to Puerto Rico
KCV-110 LCD Desk Mount Installation Instructions
About Chief Manufacturing
For over a quarter of a century, Chief has been an industry leader in manufacturing total support solutions for presentation systems. Chief's commitment to responding to growing industry needs is evident through a full line of mounts, lifts, and accessories for LCD/DLP/CRT and flat panels utilizing and technologies.
Chief is known for producing the original Roll, Pitch, and Yaw adjustments in 1978 to make projector mount installation and registration quick and easy. Today, Chief continues to provide innovative mount features, including the first-ever seismic-rated LCD and plasma wall mounts. For the highest quality in AV mounting, no name is trusted more than Chief.
All Chief products are designed and manufactured at Chief's main headquarters in Minnesota. Most mounts will ship within 24-48 hours: if you need your projector, LCD, or plasma mount fast, give us a call!
Need professional installation? Use the or the ! Give us a call with any questions!
Chief Manufacturing Height-Adjustable Single Swing Arm LCD Desk Mount in Silver Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 20, 2008
Chief Manufacturing Height-Adjustable Single Swing Arm LCD Desk Mount in Silver Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Great Product.
4.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • None
    Best Uses
  • Office
"What I like most about this product is that it has a couple options for you to install. One way is to clamp it at an edge of a desk. The other is that you can drill a hole in your desk and bolt down the arm which is exactly what I need as I have no space to mount it at the edge of a desk. "
Was this TV Wall Mount review on the Chief Manufacturing Height-Adjustable Single Swing Arm LCD Desk Mount in Silver helpful to you?
Aug 20 2008
tu
Los Angeles, CA
I am:
  • Professional
Reviewed at:
Price: $198.26
My opinion
5.0
"Rock solid - excellent product - worth the price! "
Nov 1 2006
SH
San Diego, CA
Reviewed at:
Price: $198.26
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
