Chief Manufacturing FWS-110 Single Swing Arm Wall Mount in Silver Finish
#198
5.0
based on 3 reviews
from $79.99 - $151.99
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.4
Low Price:
$79.99 at Dell
 Trusted:
$89.99 at MacMall
$79.99 at ClubMac
see all stores
More Images
Pros
  • Adjustable (2)
  • Easy to install (2)
  • Interfaces well with tv (2)
  • Multiple viewing angles (2)
  • Sturdy (2)
See less See more
Best Uses
  • Bedroom (2)
  • Changing viewing angle (1)
Provided by Mounts and More
Sleek designs with sophisticated adjustments, Chief's new Small Flat Panel Display Wall Mounts provide various ranges of motion and features.
Chief’s FWS-110 Single Swing Arm LCD Wall Mount swings out from the wall for close viewing and provides display pitch and pivot adjustment for ergonomic needs. Remains close to the wall in closed position for a low profile appearance.
Best of all, any orders for this mount placed before 1:00pm EST will ship out SAME DAY!
Features:
  • VESA compliant (75 mm / 100 mm). Interface brackets available for non-VESA compliant displays (see related products). Ships assembled
  • Easy installation – Attach wall plate to single stud. Attach display to mount. Slide mount onto plate. Secure hardware.
  • Sleek, attractive design hides all hardware
  • Smooth Pitch adjustment 15 degrees up, 15 degrees down by hand. Gravity-centered Pitch self-adjusts to securely hold different display weights.
  • Portrait/landscape rotation 360°
  • Independently adjustable tension at pivot points for customized control. Tension can be optimized for touchscreen use.
  • Color options: Silver Metallic or Black
  • Mount remains hidden behind the display when folded against the wall
  • Quick, easy cable management
  • Depth in closed position: 2.15"
  • Maximum extension: 9.43"
  • Pivot at wall plate: 180 degrees
  • Pivot at display connection: 180 degrees
  • Overall Dimensions: 9.71"H x 9.99"W x 2.15"D
  • Weight Capacity: 40 lbs.
  • Installation instruction found at: http://www.chiefmfg.com/uploads/pdfs/FWS-110-I.pdf
Chief warrants its products (excluding electric, gas cylinder, and one-way bearing mechanisms) to be free of defects in material and workmanship for 10 years.
PLEASE NOTE: This item cannot be shipped to Puerto Rico
FWS Swing Arm LCD Wall Mount Installation Instructions
About Chief Manufacturing
For over a quarter of a century, Chief has been an industry leader in manufacturing total support solutions for presentation systems. Chief's commitment to responding to growing industry needs is evident through a full line of mounts, lifts, and accessories for LCD/DLP/CRT and flat panels utilizing and technologies.
Chief is known for producing the original Roll, Pitch, and Yaw adjustments in 1978 to make projector mount installation and registration quick and easy. Today, Chief continues to provide innovative mount features, including the first-ever seismic-rated LCD and plasma wall mounts. For the highest quality in AV mounting, no name is trusted more than Chief.
All Chief products are designed and manufactured at Chief's main headquarters in Minnesota. Most mounts will ship within 24-48 hours: if you need your projector, LCD, or plasma mount fast, give us a call!
Chief Manufacturing FWS-110 Single Swing Arm Wall Mount in Silver Finish Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 3, 2008
Chief Manufacturing FWS-110 Single Swing Arm Wall Mount in Silver Finish Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
Very robust and good looking mount
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Multiple Viewing Angles
  • Sturdy
    Cons
  • none
    Best Uses
  • Bedroom
"I am very impressed with the design of this mount. It is holding a 38 pound LCD without the slightest sag. It is strong, yet easy to adjust. We swivel the tv multiple times each day to change viewing position. Very well designed. I used the 200mm X 200mm adaptor plate. Easy to attach. This is …"  Read Full Review »
Was this TV Wall Mount review on the Chief Manufacturing FWS-110 Single Swing Arm Wall Mount in Silver Finish helpful to you?
Feb 15 2008
Rick
Edina, MN
I am:
  • Tech Savvy
Reviewed at:
Price: $91.19
Love it
5.0
"Pros
It was very easy to install, took a matter of minutes. I use it for a 19" flat panel LCD. I can swivel and turn in both directions. I would definitely recommend this item. "
Nov 3 2008
saybrook182
Undisclosed
Reviewed at:
Price: $79.99
Great product
5.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • Bedroom
  • Changing Viewing Angle
"Easy to instsll "
Jan 7 2008
Taxman
El Paso, TX
I am:
  • Professional
Reviewed at:
Price: $151.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
