Close Login Module
Join
Chief Manufacturing Fusion PLP Series: Pull-N-Tilt Plasma Wall Mount
#477
3.5
based on 4 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
1
Category Average
4.4
$227.99
from 2 stores
Pros
  • Adjustable (2)
  • Easy to install (2)
  • Sturdy (2)
  • Close to wall (1)
  • Interfaces well with tv (1)
See less See more
Cons
  • Did not fit (1)
Best Uses
  • Boat anchor (1)
  • Media room (1)
Where to Buy
$227.99
$227.99
Product Reviews
Last update: Apr 20, 2009
Chief Manufacturing Fusion PLP Series: Pull-N-Tilt Plasma Wall Mount Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Good mount. Can be hard to get behind
4.0
    Pros
  • Close to wall
  • Easy To Adjust
  • Easy To Install
  • Sturdy
    Cons
  • None
    Best Uses
  • None
"This is a good mount if you do not need a swivel mount, and will not need to access the back panel much after the initial hook-up. It can be very tight looking up at the back of the panel and hooking the cables up. The mount is very easy to install and readily adjustable for tilt. "
Was this TV Wall Mount review on the Chief Manufacturing helpful to you?
Apr 20 2009
pwotruba
San Diego
I am:
  • Enthusiast
Reviewed at:
Price: $227.99
Works with 58" Panasonic Plasma
4.0
    Pros
  • Easy To Adjust
  • Easy To Install
  • Interfaces Well With TV
  • Sturdy
    Cons
  • None
    Best Uses
  • Media Room
"I was glad I could call and ask the opinion of your staff on which mount to buy. Who knew there were so many? I mean, after all, its a part. I never thought there were thousands of mounts for tv's "
Feb 29 2008
MauiBob
Kihei, Maui, HI
I am:
  • Tech Savvy
Reviewed at:
Price: $227.99
Great Mount!
5.0
"This is a great well build mount. It is very low profile and comes with a nice hardware set, should have everything you need to get it to mount to the back of your TV. The tilt mechanism is smooth and makes it easy to adjust the screen. Nice that you can also lift up from the bottom and tilt the …"  Read Full Review »
Oct 27 2006
SC
Boston, MA
Reviewed at:
Price: $227.99
Mount did not fit
1.0
    Pros
  • None
    Cons
  • Did not fit
    Best Uses
  • Boat anchor
"Do not trust the telephone sales people to spec the correct mount for your LCD. "
Sep 20 2008
IT Director
Boca Raton, Florida
I am:
  • Power User
Reviewed at:
Price: $227.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
$227.99
$227.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
