Casio Exilim Pro EX-F1 Digital Camera
#142
4.4
based on 35 reviews
from $999.00 - $999.99
Ratings Distribution
5 star
21
4 star
9
3 star
4
2 star
0
1 star
1
Category Average
4.7
Pros
  • Comfortable controls (21)
  • Easy setup (16)
  • Bright lcd (15)
  • Short lag time (9)
  • Well built / quality construction (7)
  • Easy to keep clean (6)
  • Fast shutter speed (5)
  • Easy to use (4)
  • Good battery life (2)
  • Great image quality (2)
See less See more
Cons
  • Poor in low light (10)
  • Long lag time (3)
  • Exposed lcd (1)
  • Focus in dim light (1)
  • Had to print the manual (1)
  • High learning curve (1)
  • Long save time (1)
  • Lots of stuff to learn (1)
  • No output to external hd (1)
  • Noise in high iso (1)
Best Uses
  • Fun (20)
  • Travel (17)
  • Photojournalism (10)
  • Documentary (9)
  • Art (7)
  • Sports (6)
  • Sports/action (4)
  • Outdoors (3)
  • Portraits (3)
  • Home (2)
Provided by OneCall
Ultra High Speed Continuous Shutter
Now you can capture exactly the moment you want, the moment it happens. Until now, digital cameras have been able to record consecutive images at speeds of only a few images per second. The Ultra High-speed Continuous Shutter (CS) capabilities of the EX-F1 are the fastest in the world, shooting 6-megapixel snapshots at a speed of 60 fps. The shooting rate is variable for the 60 images, ranging from one image per second for a full minute (one image per second) to 60 fps. All of this means that the EX-F1 allows burst shooting at speeds faster than those possible with a single reflex camera, and beautiful images of each moment of high-speed action as it occurs.
Prerecord CS: High-speed recording of action that occurs before you press the shutter button
Prerecord CS uses a continually updated buffer to pre-record images after you half-press the shutter button. Fully pressing the shutter button causes buffer contents to be stored at up to 60 fps. This means you never miss any of those special moments because you were late pressing the shutter button.
Selectable Prerecord CS shooting speed
As with Ultra High-speed CS, you can select from among the following speeds for Prerecord CS: 1 to 7, and 10, 12, 15, 20, 30, and 60 fps. The CS speed determines the size of the buffer (in seconds): 12 seconds at 5 fps, six seconds at 10 fps, one second at 60 fps).
Move Out CS
Move Out CS automatically records what happened immediately before and after a subject moves out of a boundary on the monitor screen. This mode makes it easy to capture the perfect image of a bird taking flight.
Move In CS
Move In CS automatically records what happened immediately before and after a subject moves into a boundary on the monitor screen. This mode is great when recording the image of a runner passing a specific point.
Slow LIve: View buffer images in slow motion as they are recorded
Slow Live lets you view images of fast-moving action on the camera's monitor screen in slow motion. When the image you want to keep is on the screen, simply press the shutter button to store it.
Flash CS: High-speed continuous shutter even where lighting is dim
Flash CS lets you shoot up to 20 consecutive images at a maximum speed of 7 fps. Using the camera's built-in LED light, you can record images with High-speed CS at speeds ranging from 10 images to 60 fps.
Function ring control of CS speed
CS speed can be changed quickly and easily with a turn of the function ring, even while a CS operation is in progress. Available continuous shutter speeds are 1 to 7, and 10, 12, 15, 20, 30, and 60 frames per second.
High-speed movie recording
The 1200 frame-per-second (maximum) High-speed Movie capabilities of the EX-F1 makes digital imaging more fun than ever before. This means that you can easily shoot ultra slow-motion movies at speeds that have until now been available only on professional level cameras. Not only does this provide you with a tool for capturing dramatic moments not visible to the naked eye with amazing clarity, it also lets you collect valuable visual information for sport technique analysis, scientific experiments, nature studies, and much more.
30-300 fps speed switching
While 30-300fps is selected as the recording speed, you can toggle the movie recording speed between 30 fps and 300 fps by pressing the SET button or by operating the function ring. This provides you with the versatility to creatively match recording speed to the action as it happens.
High-speed movie manual recording
The EX-F1 lets you configure camera settings manually while using High-speed Movie. You can select A, S, or M for the recording mode, and also configure aperture, shutter speed, and ISO sensitivity settings. Manual settings let you set up for maximum image sharpness, for movies that show the movement of insect wings and other very fast moving action.
Prerecord (Movie)
Prerecord (Movie) helps to ensure that you never miss recording the moment you want even though you were too late with the record button. Prerecord (Movie) continually refreshes a five-second buffer with action captured by the camera's lens. Then when you press the record button, the current contents of the buffer are saved, followed by real-time recording. Prerecord (Movie) also can be used in combination with High Speed Movie and other movie functions.
Full HD Movie for unmatched image clarity
The EX-F1 lets you shoot beautiful 1920 x 1080-pixel Full HD movies at a frame rate of 60 fields per second. A commercially available HDMI cable can be used to connect to a Full HD TV for big screen viewing.
6-megapixel high-speed CMOS sensor and new LSI
A high-speed 6-megapixel CMOS sensor combines with a new LSI to make the EX-S1 a totally new type of digital camera. This plus original image processing technology enable advanced features and function like full-resolution Ultra High-speed Continuous Shutter, High-speed Movie, Full HD Movie, and more.
12X optical zoom with CMOS shift stabilization
12X optical zoom combines with a CMOS shift stabilization for beautiful images even at high zoom factors where images are prone to blurring. HD zoom, which can be used when shooting standard movies, lets you zoom up to 48X (12X optical zoom x 4X digital zoom), with high-resolution clarity that is virtually equal to that of optical zoom.
Crisp, clear LCD monitor screen
A wide built-in 2.8-inch clear monitor screen displays images of exceptional clarity for both recording and playback. High contrast, wide viewing angle, and high brightness ensure clear images regardless of viewing conditions.
Specification Description
Model EX-F1BKFBA, EXF1BKFBA
UPC 079767623401
*Megapixels 6.0
Aperture f/2.7-7.5
Compatible Battery NP-100
Depth (Inches) 5.12
Digital Zoom 4
Digital Zoom 4x
Effective Megapixel Count 6.0
Electronic Flash Built-in
Exposure Modes Aperture-Priority AE
Exposure Modes Manual
Exposure Modes Program AE
Exposure Modes Shutter-Priority AE
Flash Automatic
Flash Built-in with Red Eye Reducer
Focus Modes Auto
Focus Modes Infinity Mode
Focus Modes Macro
Focus Modes Manual
Focus Modes Spot
HDMI Mini Yes
Height (Inches) 3.13
Image Format JPEG
Image Format RAW
LCD Display Size (Inches) 2.8
LCD Viewer 2.8 Inch
Lens Zoom Lens
Microphone Built-in
Movie Mode 1280 x 720
Movie Mode 1920 x 1080
Movie Mode 640 x 480
Movie Mode Quicktime MOV
Optical Viewfinder Yes
Optical Zoom 12
Optical Zoom 12x
Pixel Count 6 Megapixel
Removable Memory Type Secure Digital
Select Camera Style Fixed Lens SLR's
Select Media Multimedia Cards,Secure Digital Cards(SD),Secure D
Self Timer Yes
Sensitivity ISO 100-1600
Shutter Speed 1-1/40000
Sound Yes
Speakers Built-in
Still Image Resolution (Max.) 2816 x 2112
Still Picture Capture Yes
Storage Media Type Secure Digital (SD) / MultiMedia Card (MMC)
USB Port Mini-B
Weight (Pounds) 5.03
White Balance Auto
White Balance Daylight
White Balance Manual
White Balance Overcast
White Balance Shade
White Balance Tungsten Bulb
Casio Exilim Pro EX-F1 Digital Camera Questions
Questions and Answers
Where to Buy
$999.99
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$999.00
BizRate Rating Outstanding 9.1
$999.00
Show all 4 stores
_
Product Reviews
Last update: Jul 17, 2009
Casio Exilim Pro EX-F1 Digital Camera Reviews
Most helpful positive review
[10 of 10 customers found this review helpful]
Most helpful negative review
[5 of 5 customers found this review helpful]
4.0
Less still more video
"I found this camera through a review from another site, that reviewer said he felt the EX-F1 is more of a video camera with nice still capabilities, then a still camera with bonus video features, and I completely agree. Still Camera wise, the sensor is 6 megapixels, which isn't bad, but by many cameras on the market, it's not exceedingly special either. On iso settings greater than 100 in low-light/ and indoor ..." Read Full Review »
Dec 09, 2008 by Collin
See more positive Casio Exilim Pro EX-F1 Digital Camera reviews
3.0
Good new concept
"This new camera presents some interesting new concepts. You can leave the camera standing by, and it will shoot automatically when a subject comes in or out of frame. This feature is good for nature shots. Its lens has a good coverage, and is fast when using wide angle. The pre-recording feature is very nice, but requires more light, since it will necessary to use the shutter at 1/60 sec. It is great that you ca..." Read Full Review »
May 05, 2008 by Lucida Flex
See more negative Casio Exilim Pro EX-F1 Digital Camera reviews
Displaying 1 - 5 of 35 Reviews
Show
Sort by
4.0
    Pros
  • Easy to Use
  • Fast Shutter Speed
  • Good Battery Life
  • Good sized screen
  • Nice Features and Settings
    Cons
  • None
    Best Uses
  • Home
  • Outdoors
  • Portraits
  • Sports/Action
  • Travel
Still Camera wise, the sensor is 6 megapixels, which isn't bad, but by many c …"  Read Full Review »
Was this Digital SLR Camera review on the Casio Exilim Pro EX-F1 Digital Camera helpful to you?
 Report Abuse  (10)  (0)  0 comments
Dec 9 2008
Collin
San Bruno, CA
I am:
  • Photo Enthusiast
Reviewed at:
Tigger Happy comes to mind... Love it!
5.0
    Pros
  • Easy Setup
    Cons
  • Long Lag Time
    Best Uses
  • Art
  • Documentary
  • Fun
  • Photojournalism
  • Travel
"I film sports and wildlife and this camera holds up well and especially in Slow Motion!
Cameras I own: Canon 10d, GL1, and XL1s.
Photography:
Pros
1. Image Color is excellent. I've set mine at
Saturation at +2 and contrast +1.
2. Shoots at phenomenal rates! For my purposes
May 21 2008
Johnny
Santa Monica, CA
I am:
  • Professional
Reviewed at:
Price: $999.99
[6 of 6 customers found this review helpful]
Speedy consumer-level chameleon
4.0
    Pros
  • Bright LCD
  • Comfortable Controls
  • Dedicated Record Buttons
  • Fast Burst Rate
    Cons
  • Poor Operation in Low Light
  • Poor User Interface
  • Short User Manual
    Best Uses
  • Fun
  • Scientific applications
  • Travel
"I use the high-speed function on this camera almost exclusively and have a dedicated DSLR for still photos. Obviously, there is currently no other consumer camera that can capture high-speed video at this price. However, the EX-F1 is not without limitations.
The zoom is fairly powerful and the …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Aug 25 2008
Douglas
Mystic, CT
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $999.99
Good new concept
3.0
    Pros
  • Bright LCD
  • Easy Setup
    Cons
    Best Uses
  • Art
  • Fun
  • Travel
"This new camera presents some interesting new concepts. You can leave the camera standing by, and it will shoot automatically when a subject comes in or out of frame. This feature is good for nature shots. Its lens has a good coverage, and is fast when using wide angle. The pre-recording feature is …"  Read Full Review »
 Report Abuse  (5)  (0)  0 comments
May 5 2008
Lucida Flex
Rio de Janeiro, Brazil
I am:
  • Professional
Reviewed at:
Price: $999.99
[7 of 7 customers found this review helpful]
Best Ever
5.0
    Pros
  • Bright LCD
  • Easy Setup
  • Easy to Keep Clean
  • Short Lag Time
  • More »
    Cons
  • None
    Best Uses
  • Art
  • Documentary
  • Fun
  • Photojournalism
  • Travel
"I have been after this camera ever since I saw it on the Casio website 4 months before its release. I studied any reviews that I could find, but no one could describe just how incredible this camera is.
I can waste time writing about the many features, but the camera's description and website …"  Read Full Review »
 Report Abuse  (7)  (0)  1 comment
May 30 2008
ClockWork
Miami
I am:
Reviewed at:
Price: $999.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
