Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras
#42
4.4
based on 113 reviews
Ratings Distribution
5 star
65
4 star
41
3 star
3
2 star
0
1 star
4
Category Average
4.2
Low Price:
$136.95 at B&H Photo Video
 Trusted:
$136.95 at Adorama
Find it at Amazon
$136.95 - $149.99
from 5 stores
More Images
Pros
  • Easy setup (41)
  • Durable (37)
  • Easy to use (37)
  • Lightweight (37)
  • Nice features (34)
  • Nice button configuration (33)
  • Ergonomic design (27)
  • Reliable (24)
  • Improves function (9)
  • Great features (5)
See less See more
Cons
  • Pricey (10)
  • Bulky (4)
  • No on/off switch (4)
  • Not enough features (4)
  • Short power cord (4)
  • Cord too short (2)
  • Flimsy (2)
  • 1-sec minimum interval (1)
  • A bit delicate (1)
  • A bit pricy in my opinion (1)
Best Uses
  • High-end equipment (27)
  • Landscapes (21)
  • Macro (20)
  • Travel (14)
  • Upgrade (12)
  • Long exposures (11)
  • Everyday (10)
  • Home (9)
  • Portraits (9)
  • Studio (9)
Provided by OneCall
This is a remote switch with an 2.6ft cord and a self-timer, interval timer, long-exposure timer, and exposure-count setting feature.
The timer can be set anywhere from 1 second to 99 hours. A new dial enables you to easily enter the numeric settings with a single thumb. The LCD panel can also be illuminated. It has the new N-3 type connector, which locks with a simple push.
The rear of the Controller has a slot to store the camera's remote control socket cap.
Models:
EOS 10D, 1D, D60, D30, D2000, 1v/1vHS, 3
Specification Description
Model 2477A002
UPC 082966581564
Select Remote Controls
To Fit Canon EOS
Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 16, 2009
Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras Reviews
Most helpful positive review
[9 of 9 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Surprisingly useful
"Here's how I use the timer features: 1. For group photos that I'm in: 10 second initial delay so I can get myself into the shot, then 3-7 pictures (depending on the group) with 3-5 second delays in-between. Assuming that you're going to take a handful of shots in the first place is *so* much easier than going back to start the camera's self-timer again, then getting back into the picture. 2. For long (bu..." Read Full Review »
May 20, 2009 by Nuke
See more positive Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras reviews
3.0
Function Yes. Price No!
"If you're looking for a simple remote trigger look elsewhere. If you're after a tool to help with very long exposures or time lapse this is the tool. Sadly it is much larger than it needs to be, far too expensive and it has no way of shutting it off. The only way to conserve battery life is to remove the battery. Does it do what it claims? Yes. I think this item should be re-engineered to have a smaller ..." Read Full Review »
Jun 24, 2009 by Hogie
See more negative Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras reviews
Displaying 1 - 5 of 113 Reviews
Show
Sort by
Surprisingly useful
5.0
    Pros
  • Durable
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • Design quirks
    Best Uses
  • Astrophotography
  • Group self-portraits
  • Night photography
1. For group photos that I'm in: 10 second initial delay so I can get myself into the shot, then 3-7 pictures (depending on the group) with 3-5 second delays in-between. Assuming that you're going to take a handful of shots in the first place is *so* much e …"  Read Full Review »
Was this Camera Accessory review on the Canon TC-80N3 Timer Remote Control for many EOS Digital Cameras helpful to you?
 Report Abuse  (9)  (0)  0 comments
May 20 2009
Nuke
State College, PA
I am:
  • Semi-Professional
Reviewed at:
Price: $136.95
Much better than a plain tethered switch
5.0
    Pros
  • Easy To Use
  • Lightweight
    Cons
  • A tad expensive
    Best Uses
  • long exposures
  • Multiple Exposures
  • Self-timer Exposures
"I'm a huge fan of long exposures and I've loved using plain tethered remotes on all my Canon cameras over the years (5D, 20D, 300D, A-1, AV-1, AE-1). This controller goes so far beyond a simple remote switch. I can't believe I've gone without this level of functionality up until now. All those long …"  Read Full Review »
Mar 23 2009
Todd
Boston, MA
I am:
  • Semi-Professional
Reviewed at:
Price: $136.95
[4 of 4 customers found this review helpful]
A
5.0
    Pros
  • High Quality
  • Simple to use
    Cons
  • Expensive
    Best Uses
  • Flowers blooming
  • Macro
  • Portraits
  • Wildlife
"You can't get a sharper photo than with your camera sitting on a tripod and using a remote shutter release. Especially with those slow shutter speeds.
The 2.6 foot cord is long enough for me in most cases. Any longer and it would just be in the way. You can get an extension, but it's not cheap.
 Report Abuse  (4)  (0)  0 comments
Jan 15 2009
TreeMan
PA
Reviewed at:
Price: $136.95
Does The Job
4.0
    Pros
  • Easy To Use
  • Lightweight
  • Reliable
    Cons
  • None
    Best Uses
  • None
"It's a timer. Simple to use, as it should be, and it does the job. That's all. And that is what "success" looks like to me.
The only thing I do not like about it---and why I gave it 4 starts instead of 5---is the feel of the buttons, but I'll get used to that.
Also, it's weird not having …"  Read Full Review »
Nov 16 2009
Haim
New York, NY
I am:
  • Hobbyist/Enthusiast
Reviewed at:
Price: $136.95
Landscape Photographers Tool
5.0
    Pros
  • Lightweight
  • Reliable
    Cons
  • A Bit Delicate
    Best Uses
  • Landscape Photography
  • Time lapse photography
"Often, while I'm shooting nightscapes, I am required to keep the shutter open for longer than 30 seconds. However, my cameras (5DI, 30D) require me to manually hold the shutter button down for exposures longer than 30 seconds - a mild pain in the butt. This is a cure for the manual shutter 30 second …"  Read Full Review »
Nov 5 2009
BSG Images
Pasadena, CA
I am:
  • Semi-Professional
Reviewed at:
Price: $136.95
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
