Canon BP-945 Battery Pack - 7.2v, 4500mAh
#20
4.6
based on 11 reviews
Ratings Distribution
5 star
8
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.2
Low Price:
$97.99 at B&H Photo Video
 Trusted:
$97.99 at Adorama
Find it at Amazon
$97.99
from 2 stores
More Images
Pros
  • Long lasting (6)
  • High quality (4)
  • Easy to use (3)
  • Fast recharge (3)
  • Highly compatible (3)
  • Compact design (2)
  • Improves performance (2)
  • Well-constructed (1)
See less See more
Cons
  • Costs more (1)
  • It adds a bit of weight (1)
  • No power meter on battery (1)
  • Slow recharge (1)
Best Uses
  • Home movies (5)
  • Professional (5)
  • Complex projects (4)
  • Independent films (3)
  • Weddings (2)
  • Anything really (1)
  • Birthdays (1)
  • Corporateindustrial vids (1)
  • Longer shoots (1)
  • Parties (1)
Provided by CameraWorld.com
Main Features
  • Manufacturer: Canon
  • Manufacturer Part Number: 4244A002
  • Manufacturer Website Address: www.canonusa.com
  • Product Type: Rechargeable Photo Battery
  • Battery Chemistry: Lithium Ion (Li-Ion)
  • Capacity: 4500 mAh
  • Output Voltage: 7.2 V DC
  • Compatibility:
    Canon Digital Camcorders:
  • GL2
  • XL1S
  • XL-2
  • Specification Description
    Model 4244A002
    UPC 013803606195
    Select Camcorder Connection Canon
    Voltage 7.2 V DC
    Canon BP-945 Battery Pack - 7.2v, 4500mAh Questions
    Questions and Answers
    Where to Buy
    $97.99
    No Tax Outside NY ends 09/09/15
    BizRate Rating Outstanding 9.7
    $97.99
    BizRate Rating Outstanding 9.1
    Product Reviews
    Last update: Nov 3, 2009
    Canon BP-945 Battery Pack - 7.2v, 4500mAh Reviews
    Most helpful positive review
    Most helpful negative review
    5.0
    The Genuine Article!
    "You pay a little more for Canon's batteries, but it's an insurance policy against cheesy manufacturing. I had an off-brand "substitute" battery before this one. It worked okay, until the flimsy plastic casing split apart on me as I was using the camera! The base plate of the cheap aftermarket battery disintegrated, and the rest of the battery fell off onto the ground, where it shorted out and caught fire. Need..." Read Full Review »
    Nov 03, 2009 by Bill
    See more positive Canon BP-945 Battery Pack - 7.2v, 4500mAh reviews
    3.0
    Extra Battery a must with Cannon's XL2.
    "An extra battery is a must if you’re going to be away from an electrical outlet for more than an hour with the camera in constant use. While this battery will only last about 90 minutes with constant shooting, it is the only auxiliary battery offered by Cannon for the XL2. With careful use of the camera’s off/on controls, the standard battery and this auxiliary battery should last an entire day of hiking until..." Read Full Review »
    Aug 24, 2008 by Bill
    See more negative Canon BP-945 Battery Pack - 7.2v, 4500mAh reviews
    Displaying 1 - 5 of 11 Reviews
    Show
    Sort by
    5.0
      Pros
    • Easy To Use
    • Highly Compatible
    • Improves Performance
    • Professional Quality
    • Well constructed
      Cons
    • Costs More
      Best Uses
    • Complex Projects
    • CorporateIndustrial Vids
    • Home Movies
    • Independent Films
    I had an off-brand "substitute" battery before this one. It worked okay, until the flimsy plastic casing split apart on me as I was using the camera! The base plate of the cheap aftermarket ba …"  Read Full Review »
    Was this Professional Video Accessory review on the Canon BP-945 Battery Pack - 7.2v, 4500mAh helpful to you?
    Nov 3 2009
    Bill
    Charlotte, NC
    I am:
    • Training Vid Producer
    Reviewed at:
    Price: $97.99
    That things BIG!!!
    5.0
      Pros
    • Long Lasting
      Cons
      Best Uses
    • Anything really
    • Birthdays
    • Home Movies
    • Parties
    • Professional
    • More »
    "There's not really much to say about it. If you are used to the smaller battery, then you'll absolutely love the much larger capacity BP-945. I haven't ran one out of charge yet...mainly because I'm in the habit of recharging after every filming session, and secondly because I haven't really done …"  Read Full Review »
    Nov 24 2008
    The Video Guy
    Palestine, TX
    I am:
    • Tech Savvy
    Reviewed at:
    Price: $97.99
    3.0
      Pros
    • None
      Cons
    • None
      Best Uses
    • Home Movies
    • Wilderness Shooting
    "An extra battery is a must if you’re going to be away from an electrical outlet for more than an hour with the camera in constant use. While this battery will only last about 90 minutes with constant shooting, it is the only auxiliary battery offered by Cannon for the XL2. With careful use of the …"  Read Full Review »
    Aug 24 2008
    Bill
    Mesa, AZ
    I am:
    • Hobbyist
    Reviewed at:
    Lots of Life
    4.0
      Pros
    • Compact Design
    • Easy To Use
    • Highly Compatible
      Cons
    • None
      Best Uses
    • Complex Projects
    • Independent Films
    "I use this battery with my Canon GL2 camera and my XL1. I do a lot of field video for the local school district. You can't have enough battery life when you're filming kids take after take after take!
    Long, life, compact to fit in my camera bag, AND I can use it for both cameras! "
    Jul 1 2009
    Shawn Michael
    Cincinnati, OH
    I am:
    • Professional Artist
    Reviewed at:
    Price: $97.99
    [0 of 1 customers found this review helpful]
    Great Long-Lasting Battery
    5.0
      Pros
    • Long Lasting
      Cons
    • Slow Recharge
      Best Uses
    • Professional
    "Filmed from 10am to 5pm almost non-stop (still turned the camera off and on to save power occasionally). It lasted longer than I thought it would. Great, long lasting battery for the Canon XL2. It does take just as long to charge as it lasts, though. "
     Report Abuse  (0)  (1)  0 comments
    Jul 10 2008
    The Scarlet Spider
    Baltimore, MD
    I am:
    • Aspiring Film Maker
    Reviewed at:
    Price: $97.99
    pages: 1 2 3 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
