Camera Armor Protection System for Nikon D200 SLR
#145
2.0
based on 5 reviews
Ratings Distribution
5 star
0
4 star
1
3 star
1
2 star
0
1 star
3
Category Average
4.2
Low Price:
$19.95 at Adorama
$29.99 at Sell N Send
Find it at Amazon
$19.95 - $29.99
from 2 stores
More Images
Pros
  • Lightweight (1)
  • Semi good protection (1)
See less See more
Cons
  • Confusing / difficult controls (1)
  • Doesn't cushion camera well (1)
  • Have to cut some material (1)
  • Heavy / bulky (1)
  • Not a great fit (1)
  • Remove strap to attach (1)
  • Will not work with mb200 (1)
Best Uses
  • Protecting slrs (2)
  • Product not useful (1)
Provided by Buzzillions.com
Camera Armor - The Toughest Protection for your camera: Camera Armor custom designs each of their cases to fit your camera like a glove. All controls and access points are still accessible and you can use your camera at a moments notice. No more missed photographs trying to get your camera out of its case.
What Do You Get:
  • 4 Part System including- Body Armor, Lens Armor, LCD Shield and Lens Cap Leash
  • Ruggedized custom fit protection
  • All models come with a clear Polycarbonate Shield, that protects the LCD
  • Rubberized Comfort for ergonomic shooting
  • Bonus Lens guard will fit most lenses up to 85mm
  • Corners and Lenses protected by impact resistant material
  • Compatible with most tripods and accessories;
Proprietary silicone material is heat stable to 420 degrees, provides protection from heat or cold, and gives the camera a secure, grippy feel. Does not trap condensation under the armor, and will not deform or loose its shape over time. Lifetime warranty.
Rugged, custom fit cases that provide protection from impact and abrasion while allowing full access to all features of the camera. Great for outdoor use (nature photography, climbing, cycling), working with multiple cameras (wedding photography), or other applications where full-time protection is required without a lot of additional bulk or weight.
4 part system includes Lens Armor, Body Armor, LCD shield, and lens cap lanyard. Works with most tripods, optional battery grips, flash guns, L-brackets, and other accessories. (Some customization may be required)
Specification Description
Model CA-1114-BLK, CA-1114-CM1, CA-1114-SMK, CA00259
UPC 857912002604
Designed For SLR Bodies,SLR's w/Short Lenses
Designed For SLR's w/Short Lenses
Select Manufacturer Dedicated Cases
Camera Armor Protection System for Nikon D200 SLR Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 8, 2008
Camera Armor Protection System for Nikon D200 SLR Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
[5 of 5 customers found this review helpful]
Avoid this product
1.0
    Pros
  • None
    Cons
  • Controls obstructed
  • Doesn't Cushion Camera Well
    Best Uses
"This product is cumbersome and makes using the camera a burden. It restricts access to controls. Especially front and rear wheels. I attempted to trim some of the rubber away from the controls but that just caused the product to rip apart. On the Nikon D200 it prevents you from opening the battery c …"  Read Full Review »
Was this SLR Fitted Case review on the Camera Armor Protection System for Nikon D200 SLR helpful to you?
 Report Abuse  (5)  (0)  0 comments
Oct 8 2008
JpGallagher
New Jersey
I am:
  • Pro Photographer
Reviewed at:
[2 of 2 customers found this review helpful]
It needs to be redesigned for the D-200
1.0
    Pros
  • None
    Cons
  • Not a Great Fit
    Best Uses
  • None
"I bought this with high hopes.....they were soon dashed. First of all the IS easy to get on.....the fit is not that good, especially around the top front part of the camera body. The camera strap must be un-hooked to get it to fit & it WILL NOT fit right if you have the MB-D200 battery pack on the b …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Feb 26 2007
Skeeter
Manassas, Virginia
I am:
  • Semi-Pro
Reviewed at:
Price: $19.95
Beware
1.0
    Pros
  • None
    Cons
  • Too Bulky
  • Will not work with MB200
    Best Uses
  • None
"Do not purchase this product if you plan to use a battery pack. I bought one for my D200 and I also purchased the battery pack cover. This system stops working as soon as you attempt to attach the battery pack to the camera body. I contacted the manufacturer direct and was told it will not fit wi …"  Read Full Review »
Mar 14 2008
Mike
Dallas, Texas
I am:
  • Hobbyist/Enthusiast
NOT AN EASY FIT WITH BATTERY PACK COVER,
3.0
    Pros
  • SEMI GOOD PROTECTION
    Cons
  • HAVE TO CUT SOME MATERIAL
    Best Uses
  • Protecting SLRs
"HAVE TO CUT SOME MATERIAL AWAY FOR A CUSTOM FIT WITH THE BATTERY PACK COVER USED. "
Sep 27 2007
JOE
REISTERSTOWN,MD
I am:
Reviewed at:
Price: $19.95
Good protection for camera
4.0
    Pros
  • Lightweight
    Cons
    Best Uses
  • Protecting SLRs
"Will prevent Scratches "
Jan 21 2008
Ron
Phoenix, AZ
I am:
Reviewed at:
Price: $19.95
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
