CablesToGo USB Superbooster Extender with 150ft Cat5E Cable
5.0
based on 1 review
from $99.99 - $163.78
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$99.99 at MacMall
 Trusted:
$163.78 at PC Connection
$99.99 at ClubMac
see all stores
Pros
  • Consistent performance (1)
  • Durable (1)
  • Easy to configure (1)
  • Easy to use (1)
See less See more
Best Uses
Provided by Cables To Go
Conquer USB length limitations with the Super Booster USB Extender from Cables To Go. This pocket-sized device extends the distance of a USB device to a host computer up to 150 feet so you can place your USB camera, printer, or any other USB device exactly where you want it! The Super Booster USB Extender is powerful yet simple. With no drivers to install or special software required, it's compatible with any computer that supports USB.
This plug-and-play device consists of a Base Unit and a Remote Unit connected together by a standard Cat5E network cable. Simply connect your cables to your device; then connect to your computer and USB peripheral and you're up and running. The Super Booster USB Extender has internal DC power-conditioning circuits to maintain the proper voltage to the remote device so no external power is required for either the Base or Remote units.
As an added bonus, a 150ft CAT5E Molded cable is included at big savings!
Features:
  • Extends the distance of a USB device from a USB-enabled computer up to 150 feet
  • Use with USB cameras, printers, web cams, keyboard/mouse extensions, and any other USB device
  • Self-powered so no external power source is required
  • Uses standard Cat5/Cat5E/Cat6 patch cord (150ft Cat5e cable is included with this kit) for ease of use and flexibility
  • Compliant with USB Specification 1.1
  • Base Connectors: USB Type A Male; RJ45 Female
  • Remote Connectors: USB Type A Female; RJ45 Female
Cable Features:
  • Connector: 50-micron gold plated RJ-45 Male to Male
  • Conductor: 4-pair 24 AWG Stranded Copper
  • Jacket: PVC
  • Molded, snag-Free boot prevents unwanted cable snags
CablesToGo USB Superbooster Extender with 150ft Cat5E Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 11, 2009
CablesToGo USB Superbooster Extender with 150ft Cat5E Cable Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Worked As Promised!
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • None
"I live-streamed the graduation of over 750 students using this superbooster and cable. I had 7 cameras. While the superbooster only used USB 1.1 speeds, it maintained a perfect signal for the 4 hours it was used.
The price and practicality is superb. "
Was this Electronics Accessory review on the CablesToGo USB Superbooster Extender with 150ft Cat5E Cable helpful to you?
Jun 11 2009
Daniel at Secram Studios
Cheyenne, Wyoming
I am:
  • Power User
Reviewed at:
Price: $125.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
