CablesToGo USB to Dual PS/2 Adapter
#1119
3.8
based on 41 reviews
from $8.59 - $19.99
Ratings Distribution
5 star
18
4 star
7
3 star
9
2 star
2
1 star
5
Category Average
4.1
Pros
  • Durable (10)
  • Highly compatible (9)
  • Strong connection points (7)
  • Reliable (5)
  • Improves performance (2)
See less See more
Cons
  • Limited compatibility (2)
  • No performance gain (1)
  • Unreliable (1)
Best Uses
  • Computer equipment (10)
  • Networking (2)
  • High-end equipment (1)
Provided by Shoppers Choice
MODEL- 27225 VENDOR- CABLES TO GO FEATURES- USB to Dual PS/2 Keyboard/Mouse Adapter Allows you to use your PS/2 compatible mouse and keyboard on a USB port. The USB to Dual PS/2 Adapter from Cables To Go is the ideal solution for those who want to use legacy PS/2 devices on new USB systems. The USB to Dual PS/2 Adapter allows you to connect a PS/2 mouse and keyboard through the USB port on any computer. It s the ideal solution for connecting a full-size keyboard and mouse to the USB Port on your notebook. Connectors: One USB A, two mini-DIN 6 pin sockets Connect directly to USB port on computer or to a USB hub Fully compliant with USB 1. 1 specifications Easy to install; Plug and Play compatible Color-coded connectors for easy identification Ideal for notebooks No power adapter is needed Supports Microsoft Intellimouse and compatible mice Requires standard PS/2 mouse driver Windows 98/ME/2000/XP compatible Works with PC, Mac and Sun platforms www. Cablestogo. Com
Specification Description
Model 27225
UPC 757120272250
Accessory Indicator Yes
Benefits Connect directly to USB port on computer or to a USB hubEasy to install with plug-and-play compatibilityColor-coded connecto
Cable Length Under 1 ft.
Cable Type Keyboard/mouse
Capacity UOM mAh
Color Beige
Country Of Origin China
Description Header Get 2 PS/2 ports from 1 USB port.
Display Catalog Number 55008892
Features Works with PC, Mac and Sun platforms and is Windows 98/ME/2000/XP compatibleNo power adapter is neededFully compliant with U
Left Connector(s) 1 USB A
Manufacturer Labor Warranty 1
Manufacturer Part Number 27225
Manufacturer Parts Warranty 1
MAP Price 0.0
Model 27225
Operating Temperature UOM ° F
Product Dimensions UOM feet
Product Length 0.1
Product Type Adapter
Product Weight 0.19
Product Weight UOM pounds
Right Connector(s) 2 mini-DIN 6-pin sockets
Supported Languages English
CablesToGo USB to Dual PS/2 Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 11, 2009
CablesToGo USB to Dual PS/2 Adapter Reviews
Most helpful positive review
[9 of 9 customers found this review helpful]
Most helpful negative review
[27 of 28 customers found this review helpful]
5.0
Works great - with caveats
"This converter works great but with caveats. Specifically, if older (1994 and older) mouse drivers are used the mouse input will be erratic and after a few minutes to several hours of inactivity, the USB port on the computer will think nothing is connected and shut down. To reactivate, the USB plug must be removed and reinserted. The solution is to update the mouse drivers to current, proper drivers that are USB..." Read Full Review »
Nov 07, 2006 by R. C. Saunders
See more positive CablesToGo USB to Dual PS/2 Adapter reviews
3.0
It works, but not necessarily completely
"first off, the product definitely works. i can plug my PS2 keyboards into the keyboard connector and type. no problemo. that's fine.however, all of the keys that manufacturers have been adding to the top of the keyboards do NOT work with this adapter. windows (xp) definitely knows it's a keyboard with those buttons, and i can change what the buttons do in the driver setup, but from what i can tell, the signal ca..." Read Full Review »
Dec 12, 2003 by Anonymous
See more negative CablesToGo USB to Dual PS/2 Adapter reviews
Displaying 1 - 5 of 41 Reviews
Show
Sort by
3.0
"first off, the product definitely works. i can plug my PS2 keyboards into the keyboard connector and type. no problemo. that's fine.however, all of the keys that manufacturers have been adding to the top of the keyboards do NOT work with this adapter. windows (xp) definitely knows it's a keyboard wi …"  Read Full Review »
Was this Computer Cable & Connection review on the CablesToGo USB to Dual PS/2 Adapter helpful to you?
 Report Abuse  (27)  (1)  0 comments
Dec 12 2003
Amazon
Reviewed at:
Price: $19.99
5.0
"This converter works great but with caveats. Specifically, if older (1994 and older) mouse drivers are used the mouse input will be erratic and after a few minutes to several hours of inactivity, the USB port on the computer will think nothing is connected and shut down. To reactivate, the USB plug …"  Read Full Review »
 Report Abuse  (9)  (0)  0 comments
Nov 7 2006
R. C. Saunders
Dayton, Ohio
Reviewed at:
Price: $19.99
[9 of 10 customers found this review helpful]
Works - Kinda - Not all the Time
2.0
"This product does work, kinda, and not all of the time. I have found that if you leave your computer on for long periods of time that is seems to forget that it is there and stops functioning. This seems to happen about evey 8 hours. So, I would deffinately NOT recommend this for a person that le …"  Read Full Review »
 Report Abuse  (9)  (1)  0 comments
Jan 31 2004
Amazon
Reviewed at:
Price: $19.99
Excellent produtc
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
  • High-End Equipment
"Love the fact that I can continue to use a keyboard I've loved since 2000 in a USB port.
Works great! "
Nov 9 2009
Shannon
Milford, Oh.
I am:
  • Value Oriented
Wrong Application
3.0
    Pros
  • None
    Cons
  • Limited Compatibility
  • No Performance Gain
    Best Uses
"The cable had connection problems with the Belkin Flip switch I was trying to use it with. I have just ordered a similar item from Belkin and will see if that one works. If so I will return this one. "
Oct 27 2009
FrankB
New Jersey
I am:
  • Quality Oriented
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
