CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter
#2
4.8
based on 94 reviews
Ratings Distribution
5 star
71
4 star
15
3 star
1
2 star
0
1 star
1
Category Average
4.1
Low Price:
$20.00 at www.sayera.com
 Trusted:
$24.95 at PC Connection
Find it at Amazon
$20.00 - $35.99
from 10 stores
More Images
Pros
  • Highly compatible (38)
  • Reliable (33)
  • Durable (31)
  • Strong connection points (24)
  • Improves performance (10)
  • Easy to use (2)
  • Cable connections perfect (1)
  • Easy to install (1)
  • Flexability (1)
  • Just works (1)
See less See more
Cons
  • Flimsy (1)
  • Limited compatibility (1)
  • No performance gain (1)
  • Not perfect but good (1)
Best Uses
  • Computer equipment (41)
  • Networking (5)
  • High-end equipment (3)
  • Back-up (1)
  • Data recovery (1)
  • Hard drive repairs (1)
Provided by Overstock.com
The USB 2.0 to IDE or Serial ATA Controller from Cables To Go turns any IDE or SATA drive into a convenient external drive. Simply connect one IDE/ATAPI or SATA-based mass storage device through a USB port to easily transfer files from a computer or notebook, back up files or store large file archives on an external hard drive. The hi-speed USB interface enables easy installation with its plug-and-play design. The adapter supports all existing IDE/ATAPI devices such as Iomega Zip, CD-ROM, CD-RW, DVD-ROM and IDE hard drives, and works with any SATA hard drive from 80GB to 500GB.*Manufacturer: Cables To Go *Manufacturer Part Number: 30504 *Manufacturer Website Address: www.cablestogo.com *Product Name: USB 2.0 to IDE/Serial ATA Drive Adapter *Product Type: Serial/Ultra ATA Controller *Host Interface: USB *Data Transfer Rate: Up to 480Mbps *Drive Type: Ultra ATA *Ports: 1 x 7-pin Female Serial ATA *Form Factor: External *Weight: 0.95 lb , 0.95 lb *Package Contents: *USB 2.0 to IDE/Serial ATA Drive Adapter *5" 7-Pin M/M Serial ATA Cable *5V 1A/12V 1A Power Supply (supports both SATA Power and 4-Pin Molex Power) Power Cable (for power supply) *User Manual
CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter Questions
Questions and Answers
Where to Buy
$24.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$35.99
$20.00
Show all 10 stores
Product Reviews
Last update: Nov 18, 2009
CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
5.0
A Must Have For Every PC User!
"This device worked exactly as I needed. I am not a skilled technician, and another hard drive failure was unexpected (10 months old), but the horrible inconvenience was greatly diminished by using this adapter. I was not only able to capture everything I needed from the failed drive, but went through a box full of other failed drives in my collection. The adapter accessed every failed hard drive except two tha..." Read Full Review »
Nov 18, 2009 by Steve
See more positive CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter reviews
1.0
Need User Friendly Instructions
"This product was recommended to retrieve files from a broken computer. All I got was a box, cables and some instructions that were hard to follow. Would be nice if the directions included some type of picture diagram for those of us that are cable challenged...." Read Full Review »
Sep 13, 2009 by Roxie
See more negative CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter reviews
Displaying 1 - 5 of 94 Reviews
Show
Sort by
Hard Drive Rescue plan
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
  • Networking
"When my NetGear external dual drive unit went belly up, I had written off the drives as unusable. Then I got my [...] "magic" IDE to USB "cable". "Magic" because it was simply unheard of before this, plug it together and it works, and "Cable" because that is an understatement. This is a dream dev …"  Read Full Review »
Old box put back to use
  • Using Product
Was this Computer Cable & Connection review on the CablesToGo USB 2.0 to IDE/Serial ATA Drive Adapter helpful to you?
Nov 19 2009
Marty
Louisville Colorado
I am:
  • Value Oriented
Reviewed at:
Price: $35.99
This product retrieved my important data
5.0
    Pros
  • Highly Compatible
  • Reliable
    Cons
  • No Complaints
    Best Uses
"This product was used after complete failure of my main desktop computer. After removing the data hard disk from my main computer, I was able to access all data and transfer to my backup computer. "
USB 2.0 to IDE Adapter
  • Made with Product
  • Using Product
  • Picture of Product
Nov 18 2009
Gordy the Guru
San Jose, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $35.99
5.0
    Pros
  • Highly Compatible
  • Reliable
    Cons
  • None
    Best Uses
"This device worked exactly as I needed. I am not a skilled technician, and another hard drive failure was unexpected (10 months old), but the horrible inconvenience was greatly diminished by using this adapter. I was not only able to capture everything I needed from the failed drive, but went throu …"  Read Full Review »
Nov 18 2009
Steve
Southeastern US
I am:
  • Value Oriented
Reviewed at:
Price: $35.99
Great time saver!
4.0
    Pros
  • Highly Compatible
  • Just works
    Cons
    Best Uses
"I am using it to access files from my old computer Hard Drive while I configure and transfer the files I need to keep on my "new" computer. I don't want all the junk files I have collected on the new machine, but I don't want to take the time to sort all the files before moving. This way I have my …"  Read Full Review »
Nov 5 2009
Sanddad
Orcas Island, WA
I am:
  • Value Oriented
Reviewed at:
Price: $35.99
Easy to use, seems well made
4.0
    Pros
    Cons
  • None
    Best Uses
"I bought this to pull data off of hard drives from old computers. It has a USB-to-IDE cable and an external plug-in power supply designed to power standard drives. Use is pretty much automatic: you plug it in and turn it on. It worked very well on IDE drives (I didn't test the other options). It …"  Read Full Review »
Nov 18 2009
Computer doctor
Lindenhurst, IL
I am:
  • Quality Oriented
Reviewed at:
Price: $35.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
