CablesToGo USB 2.0 Fast Ethernet Adapter
#221
5.0
based on 3 reviews
Ratings Distribution
5 star
3
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$22.00 - $49.99
from 9 stores
More Images
Pros
  • Durable (2)
  • Consistent performance (1)
  • Easy to configure (1)
  • Easy to use (1)
  • Improves performance (1)
  • Reliable (1)
See less See more
Best Uses
  • Home (1)
  • Networking (1)
Provided by Cables To Go
The Cables To Go USB 2.0 Fast Ethernet Adapter is up to 20 times faster than USB 1.1 Ethernet Adapters. With its 480Mbps of available bandwidth, you get true 10/100 network access. The plug and play design makes this adapter the most convenient and efficient way to connect a laptop or desktop computer to a fast ethernet network. With the USB 2.0 Fast Ethernet Adapter experience the full speed of your fast ethernet network without the need for opening your PC and adding internal network adapters. The adapter allows you to share the Internet or printers, transfer files, compete in multi-player games and more at blazing speeds of up to 200Mbps (in full duplex mode). The portable, compact size makes it ideal for use with laptops. The USB 2.0 Fast Ethernet Adapter is hot-swappable and 100% compatible with both USB 2.0 and 1.1 hardware.
  • Interface:
    • Upstream Port: USB type A plug
    • Downstream Port: RJ45
  • 20x faster than USB 1.1 Fast Ethernet Adapters
  • Compact, portable design makes it ideal for laptops
  • IEEE 802.3u 100BASE-T, TX Compatible
  • Supports full-duplex or half-duplex
  • Supports suspended mode and remote wakeup
  • Compliant with the Standard Specification of USB 1.1 and 2.0
the product manual.
CablesToGo USB 2.0 Fast Ethernet Adapter Questions
Questions and Answers
Where to Buy
$29.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$39.99
$22.00
Show all 9 stores
Product Reviews
Last update: Jul 14, 2009
CablesToGo USB 2.0 Fast Ethernet Adapter Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Fast Ethernet over USB 2.0!
5.0
    Pros
  • Durable construction
  • Improves Performance
  • Reliable
    Cons
  • None
    Best Uses
  • Networking
"I am the IT department at my plant: sometimes I need to bypass the corporate net and get outside with a little speed for a quick download, right? With this adapter, I can run two totally separate networks on one machine. Since it's USB, I can even make it available to a virtual machine while hiding …"  Read Full Review »
Was this Computer Cable & Connection review on the CablesToGo USB 2.0 Fast Ethernet Adapter helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jul 14 2009
Good Hojjamighty
Thuh Woods, NC
I am:
  • Quality Oriented
Reviewed at:
Price: $39.99
[2 of 4 customers found this review helpful]
USB 2.0 Ethernet Option a Lifesaver
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • Home
"The USB Ethernet cable is a must for those computers that came without an Ethernet card and port installed. Saves a trip to the shop to have a port installed, and is easy to use, either with a DSL Modem or a Router, which was how I used it to hook into a late model PC that had no Ethernet Port in p …"  Read Full Review »
 Report Abuse  (2)  (2)  0 comments
May 4 2009
Bob
Aylett, VA USA
I am:
  • Casual User
Reviewed at:
Price: $39.99
This is a great product. ...
5.0
"This is a great product. Easy setup "
Jun 14 2009
David
Undisclosed
Reviewed at:
Price: $29.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
