CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables
#336
3.9
based on 38 reviews
from $85.93 - $119.99
Ratings Distribution
5 star
18
4 star
8
3 star
4
2 star
2
1 star
4
Category Average
4.1
Low Price:
$85.93 at pcRUSH
 Trusted:
$89.99 at TigerDirect
$89.99 at CompUSA
see all stores
More Images
Pros
  • Easy setup (10)
  • Small (5)
  • Fast (3)
  • Reliable (2)
  • Affordable (1)
  • Easily expanded (1)
See less See more
Cons
  • Unreliable (4)
  • Gets confused on occasion (1)
  • Incompatible (1)
  • Requires usb at pc side (1)
  • Short power cable (1)
Best Uses
  • Desktop (6)
  • Home (4)
  • Small networks (4)
  • Home office (1)
Provided by Beach Audio
MODEL- 35555 VENDOR- Cables To Go
FEATURES- Port Authority2 4-Port USB & PS2 KVM Switch with Cables
The Port Authority2 4-Port USB and PS2 KVM Switch can control up to
four computers with a single keyboard, mouse, and monitor. For
added convenience, this KVM switch works with both USB and PS2 mice
and keyboards. Because the Port Authority2 USB/PS2 KVM Switch also
features a 3-port USB hub, any of the four connected computers can
share USB devices.
The sleek design will save space on your desktop, and the durable
metal housing features rubberized ends to protect the unit from
damage. The Port Authority2 KVM Switch can handle even the most
power-hungry devices with support from the external power adapter
or bus power if you prefer. LED indicators take the guesswork out
of which computer is selected. Best of all, it comes with all the
cables you need. There is nothing extra to buy!
Includes Switch, Four USB A to USB B/VGA Male to Female combination
cables, DC 5V/2A Power Adapter, Software CD and User Manual.
* Connects four computers to one USB or PS2 keyboard and mouse, and one VGA
monitor.
* Built-in USB hub allows up to three USB devices to be shared among the
four PCs.
* Supports video resolutions of up to 2048x1536
* Features Auto Scan and Auto Switch
* Offers Overcurrent protection
* LED status indicators let you easily see which computer is selected
* Uses bus power or the external adapter for power-hungry devices
* Includes all necessary cables
* Supports Windows 98/98SE/ME/2000/XP and Mac OS9/X, Linux, and Sun Micro
OS.
www.cablestogo.com
Specification Description
Model 35555
UPC 757120355557
Accessory Indicator Yes
Benefits Connects 4 computers to 1 USB or PS2 keyboard and mouse, and 1 VGA monitorBuilt-in USB hub allows up to 3 USB devices to be shared am
Cables Included 4 USB A to USB B/VGA male to female combination cables
Capacity UOM mAh
Country Of Origin China
Description Header One slick switch.
Display Catalog Number 55009393
Enclosure Color Gray
Features Includes all necessary cablesSupports Windows 98/98SE/ME/2000/XP, Mac OS9/X, Linux and Sun Micro OS
Included in the Box Port Authority2 4-Port USB and PS/2 KVM Switch4 USB A to USB B/VGA male to female combination cablesDC 5V/2A power adapter
Manufacturer Labor Warranty 12
Manufacturer Part Number 35555
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 35555
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Height 2.5
Product Length 8.25
Product Type Wired
Product Weight 0.7
Product Weight UOM pounds
Product Width 3.5
Required to function Software utility requires Windows 98/98SE/ME/2000/XPAvailable USB port
Supported Languages English
CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables Questions
Questions and Answers
Where to Buy
$89.99
$1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09
BizRate Rating Outstanding 9.1
$119.99
$10 Off Orders Of Orders Over $85 + Free Shipping
$85.93
Show all 16 stores
_
Product Reviews
Last update: Oct 27, 2009
CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables Reviews
Most helpful positive review
Most helpful negative review
4.0
Better than units costing much more.
"I've got about 15 of these installed in our small office. They work well most of the time, but occasionally need to be reset. The reset button is located on the back so it's very difficult for end users to get to. If you are using a USB keyboard, the switch will not take commands from it, you'll have to use the buttons to switch. Another con is that the USB hub defaults to floating after a power outage. Any ..." Read Full Review »
Oct 27, 2009 by Reddy
See more positive CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables reviews
1.0
Do not buy this product
"Would not ever recommend this product. I cannot select between operating systems on my dual boot computer. It will not let me select to "boot from cd drive" when reinstalling operating systems and always locking up on me switching between other computers to my Vista PC. Talked to tech support and that was no help. I need to always have a spare keyboard and mouse when I am using this which defeats the purpose. My..." Read Full Review »
Oct 16, 2009 by bhollay
See more negative CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables reviews
Displaying 1 - 5 of 38 Reviews
Show
Sort by
4.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
If you are using a USB keyboard, the switch will not take commands from it, you'll …"  Read Full Review »
Was this Networking Hub & Switch review on the CablesToGo TruLink 4-Port VGA/USB and PS/2 KVM Switch w/Cables helpful to you?
Oct 27 2009
Reddy
Norman, OK
I am:
  • High bandwidth user
Very happy with this switch
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Home
  • Home Office
  • Small Networks
"This switch works perfectly with an IBM T60 docking station and an older HP desktop. I use two monitors with one keyboard and mouse. It worked from day one, unlike two other switches (IOGear MiniView and another) that failed to work with the T60 docking station. It's very easy to switch between t …"  Read Full Review »
Feb 18 2009
Gordon
MD
I am:
Reviewed at:
Price: $119.99
1.0
    Pros
  • Easy To Set Up
    Cons
  • Unreliable
    Best Uses
  • Home
"Would not ever recommend this product. I cannot select between operating systems on my dual boot computer. It will not let me select to "boot from cd drive" when reinstalling operating systems and always locking up on me switching between other computers to my Vista PC. Talked to tech support and th …"  Read Full Review »
Oct 16 2009
bhollay
milford, PA
I am:
Nice and heavy
4.0
"I have been through many kvm's over the years. With new units being digital video and PS/2 needed to upgrade. Wish I had one that could "do it all" I am very happy with this unit, more than a year or so. Every once in a while (2 or 3 times a year?) it will loose its settings (usb follows active …"  Read Full Review »
Sep 4 2009
Computer Dude
Beautifull Cleveland OH
I am:
Appears to be high quality and durable
5.0
    Pros
  • Easy To Set Up
    Cons
  • None
    Best Uses
  • Desktop
  • Small Networks
"I have it set up to use a wireless USB mouse and keyboard and only takes 1-2 seconds to recognize them when you switch over. It's hard to tell, but I think have a very very slight loss of picture quality. Hard to detect and I don't notice it anymore, just right when I switched over from direct con …"  Read Full Review »
Mar 17 2009
JD
IA
I am:
Reviewed at:
Price: $119.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
