CablesToGo RapidRun™ Integrated Wall Plate (HD15/3.5mm/3RCA) – Single Gang Brushed Aluminum
4.0
based on 1 review
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$69.99 at Cables To Go
Find it at Amazon
Find it at Ebay
$69.99
from 1 store
Pros
  • Consistent performance (1)
  • Durable (1)
  • Easy to configure (1)
  • Easy to use (1)
See less See more
Cons
  • Pricey (1)
Best Uses
  • Home (1)
Provided by Cables To Go
RapidRun™ is designed to be the standard for in-wall Audio/Video installations. The RapidRun system allows for a customized installation to create an ideal Audio/Video solution. Break-Away Flying Leads and Wall Plates ensure flexible, efficient, high quality connections for all types of equipment. Visit our RapidRun Information Center to learn more about
The RapidRun Integrated Wall Plates are the perfect solution for educational and institutional installations. The Wall Plates are constructed with aluminum for durability and the locking connector allows the integrator to save valuable space inside the surface mount or electrical box that typically is full of cabling. This particular Wall Plate cuts installation time and cost by allowing you to send PC Video, 3.5mm Stereo Audio, and Composite Audio/Video (3 RCA) over one cable.
Break-Away terminations are available in both Flying Leads and Wall Plates and are also available in different lengths and colors to meet the requirements of the installation. for your installation by using the RapidRun configurator.
Common Applications:
  • Education (Learning) and Collaborating - Classroom Setup Transmitting Video from PC to Projector
Features:
  • Color Code: Yellow
  • This Break-Away must be used with a Plenum-Rated PC (Yellow) Runner
  • Supports transmission of RGBHV signals (Does not support Data-Bit transmission), 3.5mm Stereo Audio, and Composite Audio/Video (3 RCA)
  • Fits a standard single gang J-box
  • Corresponding Flying Lead - (1)
Please note: To complete the RapidRun System, each Runner will need (2) Flying Leads, (2) Wall Plates, OR (1) Flying Lead and (1) Wall Plate.
CablesToGo RapidRun™ Integrated Wall Plate (HD15/3.5mm/3RCA) – Single Gang Brushed Aluminum Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 17, 2009
CablesToGo RapidRun™ Integrated Wall Plate (HD15/3.5mm/3RCA) – Single Gang Brushed Aluminum Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Great Product
4.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • pricey
    Best Uses
  • Home
"Great product that makes it easy for conference room AV installations. Professional appearance and quality "
Was this Electronics Accessory review on the CablesToGo RapidRun™ Integrated Wall Plate (HD15/3.5mm/3RCA) – Single Gang Brushed Aluminum helpful to you?
Aug 17 2009
DJTeeter
Atlanta, GA
I am:
  • Power User
Reviewed at:
Price: $69.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
