#307
based on 12 reviews
Ratings Distribution
| 5 star |
4 |
| 4 star |
5 |
| 3 star |
2 |
| 2 star |
1 |
| 1 star |
0 |
Category Average
Low Price:
Trusted:
Where to Buy
| $1.99 Shipping On Orders Over $100 at TigerDirect ends 12/31/09 |
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.8
Product Reviews
"I would have preferred that the device hook up to the 8 pin USB header on the motherboard. Luckily I had USB add on card that had an internal connection which was compatible with the connector on the hub. After that, it works flawlessly...." Read Full Review »
Oct 22, 2009 by Tanstaafl
See more positive CablesToGo Port Authority USB 2.0 Hi-Speed Front-Bay Hub 4-port reviews
"The PC board in it is fine. However the screw holes don't like up with standard 3.5" bay holes and the wire has to be routed outside the computer and plugged into an existing USB port. So you lose one port. Thus your net gain in USB ports is only 3. Yes it works, but it should use a motherboard plug for the connection instead of wasting an existing port on the outside of the computer. I kept it because I got 3..." Read Full Review »
Nov 03, 2009 by Paul
See more negative CablesToGo Port Authority USB 2.0 Hi-Speed Front-Bay Hub 4-port reviews
Displaying 1 - 5 of 12 Reviews
CablesToGo Port Authority USB 2.0 Hi-Speed Front-Bay Hub 4-port Review
Pros
Cons
Best Uses
"The PC board in it is fine. However the screw holes don't like up with standard 3.5" bay holes and the wire has to be routed outside the computer and plugged into an existing USB port. So you lose one port. Thus your net gain in USB ports is only 3. Yes it works, but it should use a motherboard pl …" Read Full Review »
Pros
Cons
Best Uses
"I would have preferred that the device hook up to the 8 pin USB header on the motherboard. Luckily I had USB add on card that had an internal connection which was compatible with the connector on the hub. After that, it works flawlessly. "
"Quality is good and the LED's only light when a device is plugged in and active,nice touch at this price point. Things to consider: The power hook up is with the same connector as a floppy drive which is no big deal if you have two plugs of that type or your discarding the FD. Otherwise you'll need …" Read Full Review »
Pros
Cons
Best Uses
"the description as to what is included is poor. this item is ready to go out of the box. everything needed is included........all cables and hardware necessary for every situation imaginable. great item,[...] "
[1 of 1 customers found this review helpful]
Pros
Cons
Best Uses
"Bought this item for my dad's old Dell, to add the convienience of a USB 2.0 in the front of his desktop. I guided him through the installation by phone. Worked like a champ. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
BizRate Rating
Outstanding 9.1
BizRate Rating
Good 8.8
| Free Shipping on Orders Over $299 ends 07/03/14 | ||||
BizRate Rating
Good 8.8
BizRate Rating
Good 8.9
| $1.99 Shipping on Orders Over $75 ends 12/31/09 | ||||
BizRate Rating
Good 8.7
BizRate Rating
Good 8.8
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
