CablesToGo Laptop to IDE Hard Drive Adapter
#6
4.6
based on 58 reviews
from $5.67 - $14.27
Ratings Distribution
5 star
43
4 star
10
3 star
1
2 star
0
1 star
3
Category Average
4.1
More Images
Pros
  • Highly compatible (21)
  • Reliable (20)
  • Strong connection points (17)
  • Durable (16)
  • Improves performance (3)
  • Handy (1)
  • Poor quality (1)
See less See more
Cons
  • No performance gain (3)
  • Flimsy (2)
  • Instructions just fair (1)
  • Limited compatibility (1)
  • Needs better instructions (1)
  • Weak connection points (1)
Best Uses
  • Computer equipment (26)
  • Data recovery (1)
  • Data retrieval (1)
  • High-end equipment (1)
  • Special purpose as needed (1)
  • Technician tool (1)
  • Troubleshooting (1)
Provided by Cables To Go
With the Laptop Hard Drive Adapter from Cables To Go, you can easily connect your 2.5in notebook IDE hard drive to a 40-pin IDE cable for installation in a desktop or tower PC. Each adapter features 44-pin female to 40-pin male connectors, and a power feed.
Transfer files to/from your laptop to your desktop quickly and easily: Simply attach your laptop's 2.5in drive to this adapter, and connect the adapter to our Then plug the USB to IDE adapter into an available USB port on your desktop. Your 2.5in drive will appear as a logical drive, enabling you to pull files directly back and forth. Save when you buy this laptop to IDE hard drive adapter AND the USB 2.0 to IDE drive adapter -
  • Connectors: 44-pin Female to 40-pin IDC Male
  • Use: Connects your 2.5in notebook IDE hard drive to a 40-pin IDE cable
to see the product manual.
Specification Description
Model 17705, RPD17705
UPC 757120177050
Accessory Indicator Yes
Benefits Features 44-pin female to 40-pin male connectorsConnects your 2.5" notebook IDE hard drive to a 40-pin IDE cableTransfer fil
Cable Length Under 1 ft.
Cable Type Printer
Capacity UOM mAh
Country Of Origin China
Description Header Share your files.
Display Catalog Number 55010640
Enclosure Color Black
Left Connector(s) 44-pin female to 40-pin IDC male
Manufacturer Labor Warranty 1
Manufacturer Part Number 17705
Manufacturer Parts Warranty 1
MAP Price 0.0
Model 17705
Operating Temperature UOM ° F
Product Type Adapter
Product Weight 0.5
Product Weight UOM pounds
Supported Languages English
CablesToGo Laptop to IDE Hard Drive Adapter Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 30, 2009
CablesToGo Laptop to IDE Hard Drive Adapter Reviews
Most helpful positive review
Most helpful negative review
[1 of 1 customers found this review helpful]
5.0
Works as advertised
"I had a hard drive from a dead laptop from which I needed the data. This did the trick. Used it to connect inside a desktop machine. Connection goes easily, although because of the machine's architecture it was a tight fit and required a bit of gymnastics. But the desktop didn't recognize the hard drive at first because I needed to add a jumper. (I thought I would, but had conflicting information about this.) Ha..." Read Full Review »
Sep 01, 2009 by Scott
See more positive CablesToGo Laptop to IDE Hard Drive Adapter reviews
1.0
Didn't Work For Me
"Don't know if it works or not. RMA'd the drive. The Adaptor got real hot, didn't want to take a chance on frying new drive. Never worked for me...." Read Full Review »
Sep 08, 2009 by garyshome
See more negative CablesToGo Laptop to IDE Hard Drive Adapter reviews
Displaying 1 - 5 of 58 Reviews
Show
Sort by
Works as advertised
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Reliable
  • Strong Connection Points
    Cons
    Best Uses
  • Computer Equipment
"I had a hard drive from a dead laptop from which I needed the data. This did the trick. Used it to connect inside a desktop machine. Connection goes easily, although because of the machine's architecture it was a tight fit and required a bit of gymnastics. But the desktop didn't recognize the hard d …"  Read Full Review »
Was this Computer Cable & Connection review on the CablesToGo Laptop to IDE Hard Drive Adapter helpful to you?
Sep 1 2009
Scott
Southern California
I am:
  • Quality Oriented
Reviewed at:
Price: $8.99
Works for me! :)
5.0
    Pros
  • Improves Performance
    Cons
  • None
    Best Uses
  • Technician Tool
"I got one of those IDE/SATA to USB adaptoid thingies, so i could plug many different hard drives in easily - hey, I'm a tech! (grin)
Then I found out there were two different pinouts on laptop hard drives. My thingy only had the standard 40-pin plug.
By using this adapter, I can now plug in …"  Read Full Review »
Aug 11 2009
jhecht
New York City
I am:
  • Quality Oriented
Reviewed at:
Price: $9.99
Essential cable
5.0
    Pros
    Cons
  • None
    Best Uses
"This is an essential cable to have in this day and time. I had a laptop go down due to my daughter spilling liquid on it. I had some files that I had not backed up yet to another source and I was able to easily transfer them to my desktop pc. Keep in mind you do have to have enough computer knowle …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Aug 24 2009
OakGrove
Whispering Pines, NC
I am:
  • Value Oriented
Reviewed at:
Price: $9.99
worked like a charm
5.0
    Pros
  • Highly Compatible
    Cons
  • None
    Best Uses
"I bought this cable to troubleshoot and save data on a laptop hard drive via hopefully plugging it in to a desktop. Once you figure out how to set the laptop hard drive to be a slave drive, this cable permitted viewing the drive perfectly! Just added a drive letter and was good to go. Copied all the …"  Read Full Review »
Aug 17 2009
Norm From RI
Smithfield, RI
I am:
  • Quality Oriented
Reviewed at:
Price: $9.99
Just what I needed.
4.0
    Pros
  • Highly Compatible
  • Reliable
    Cons
  • No Performance Gain
    Best Uses
  • Data recovery
"This is just what I needed to recover data from a dying laptop drive. The machine itself wasn't getting power so I had to remove the drive and rescue the data with my PC. The laptop hard drive adapter was the perfect solution! Thank you for such a great product. I'll be purchasing cabling products f …"  Read Full Review »
Sep 9 2009
EnigmaRx Computer Repair
St. Pete Beach,FL
I am:
  • Quality Oriented
Reviewed at:
Price: $9.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
