CablesToGo DB9M Serial Add-A-Port Adapter with Bracket
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$5.99 at Cables To Go
Find it at Amazon
Find it at Ebay
$5.99
from 1 store
Pros
  • Consistent performance (1)
  • Durable (1)
  • Easy to configure (1)
  • Easy to use (1)
See less See more
Best Uses
Provided by Cables To Go
Ensure smooth data flow from either your serial or parallel port with an I/O Add-a-Port Adapter Cable from Cables To Go. Choose DB9-pin or DB25-pin male serial ports with a bracket or a DB25-pin female parallel port with a bracket. These adapter cables connect to the motherboard or I/O adapter via flat ribbon cabling.
  • Connectors: Internal 10-pin IDS dual row to external DB9 Male
  • Crossed-configuration
  • Compatible with most brands of motherboards and I/O cards
  • Application: Serial
CablesToGo DB9M Serial Add-A-Port Adapter with Bracket Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jun 16, 2009
CablesToGo DB9M Serial Add-A-Port Adapter with Bracket Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
make sure your mother board is compatibl
5.0
    Pros
  • Consistent Performance
  • Durable
  • Easy To Configure
  • Easy To Use
    Cons
  • None
    Best Uses
  • None
"make sure your mother board is compatible. i had to reorder the correct cable. this will NOT work on INTEL boards "
Was this Electronics Accessory review on the CablesToGo DB9M Serial Add-A-Port Adapter with Bracket helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jun 16 2009
duzy
north tonawanda, NY
I am:
  • Power User
Reviewed at:
Price: $5.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
