CablesToGo 7 Port Aluminum USB 2.0 Hub
#337
3.8
based on 31 reviews
from $26.00 - $39.99
Ratings Distribution
5 star
20
4 star
1
3 star
1
2 star
2
1 star
7
Category Average
4.1
More Images
Pros
  • Easy setup (10)
  • Fast (8)
  • Small (7)
  • Easily expanded (6)
  • Reliable (5)
  • Good layout (1)
  • Looks great (1)
  • Portable (1)
  • Worked immediatelt (1)
See less See more
Cons
  • Unreliable (5)
  • 2 ports stopped in 4 mo (1)
  • Flimsy (1)
  • Hub slids off base (1)
  • Today all hubs dead (1)
  • Vista not recognize (1)
Best Uses
  • Home (7)
  • Desktop (6)
  • Computer equipment (1)
  • Home computer (1)
  • Larger networks (1)
  • Work (1)
Provided by MAGo Enterprise
MODEL- 29563 VENDOR- CABLES TO GO FEATURES- 7-port USB 2.0 Aluminum HubAdd seven high-speed USB 2.0 ports to your computer. Hard-mountable metal base included!The 7-Port USB 2.0 Aluminum Hub conveniently adds seven high speed USB 2.0 ports to your desktop or notebook computer. The slim form factor saves space while the port placement and hard-mountable metal base keep the hub in place even when several USB devices are connected. The hub easily slides out of the base making it convenient to travel with as well.The 7-Port USB 2.0 Aluminum Hub can be self-powered from the USB port or utilize the included power supply. Add additional hubs to support up to 127 devices. USB-IF certification ensures high speed data transfers up to 480 Mbps. Whether you are downloading or transferring spreadsheets MP3 files digital pictures or video streams- the Port Authority2 7-Port USB 2.0 Aluminum Hub will make connecting several high speed USB 2.0 devices hassle-free. Includes USB 2.0 Aluminum Hub 3 ft. (approx.) USB 2.0 A Male to USBMini-B Male Cable DC 5V 2A power supply User manual. * One upstream port and seven downstream ports * Removable aluminum base can be hard-mounted to your desk * Slim design saves space on your desktop * Connect up to 127 USB devices by daisy-chaining hubs * USB-IF certificated CE & FCC approved * Fully compatible with USB 2.0 Specification * Fully backward Compatible with USB 1.1 Specification * Supports transfer rates of up to 480 Mbps * Supports self-powered mode or included AC power adapter * Downstream ports have automatic connect and speed detection function plusover-current protection with auto recovery. * Supports Windows 98SE/2000/ME/XP and Mac OS X or higher
Specification Description
Model 29563, 29563-
UPC 757120295631
#per pack 1
Accessory Indicator Yes
Benefits 1 upstream port and 7 downstream portsSlim design saves space on your desktopDownstream ports have automatic connect and spe
Capacity UOM mAh
Compatible Platforms Windows, Mac
Compliant Standards USB 2.0, 1.1
Country Of Origin China
Description Header Connect more stuff to your PC.
Display Catalog Number 55025547
Included in the Box 7-Port USB 2.0 Aluminum Hub3-ft. (approx.) USB 2.0 A male to USB mini-B male cableDC 5V, 2A power supplyUser manual
Manufacturer Labor Warranty 12
Manufacturer Part Number 29563
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 29563
Operating Temperature UOM ° F
Product Type Hubs
Product Weight 7
Product Weight UOM ounces
Required to function Supports Windows 98SE/2000/ME/XP and Mac OS X or higher
Supported Languages English
CablesToGo 7 Port Aluminum USB 2.0 Hub Questions
Questions and Answers
Where to Buy
$27.99
$34.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$26.00
Show all 16 stores
_
Product Reviews
Last update: Nov 5, 2009
CablesToGo 7 Port Aluminum USB 2.0 Hub Reviews
Most helpful positive review
Most helpful negative review
5.0
Best hubs I've ever used
"I have had other hubs that failed. I have 3 of these, 2 on the desktop and one on the laptop. They have worked without a hitch. They don't take much space. The side with 3 ports is good for using thumb drives because they are wider than most wires and can have a problem on the 4 port side. Like all of my stuff, they are plugged into a UPS. There are never any power glitches. They do slide out of the base t..." Read Full Review »
Aug 27, 2009 by Cathbad
See more positive CablesToGo 7 Port Aluminum USB 2.0 Hub reviews
1.0
Broke down too soon
"I just wanted to have more USB Ports. This was reviewed well elsewhere and bought it. People have been reviewing too soon. I would have said get it, (during the first few months it worked) but if I have to buy two or three a year it really isn't worth it is it? Please do not be misled by posotive reviews. Yes it works well when it works, but it will break down on you very soon. The only people that shoul..." Read Full Review »
Jun 25, 2009 by Tim
See more negative CablesToGo 7 Port Aluminum USB 2.0 Hub reviews
Displaying 1 - 5 of 31 Reviews
Show
Sort by
Broke down too soon
1.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Small
    Cons
  • Unreliable
    Best Uses
  • Desktop
  • Home
Please do not be misled …"  Read Full Review »
Was this Networking Hub & Switch review on the CablesToGo 7 Port Aluminum USB 2.0 Hub helpful to you?
Jun 25 2009
Tim
New York, New York
I am:
  • Low bandwidth user
Reviewed at:
Price: $39.99
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
Lik …"  Read Full Review »
Aug 27 2009
Cathbad
Lowell, MA
I am:
  • High bandwidth user
Reviewed at:
Price: $39.99
[3 of 3 customers found this review helpful]
GREAT little unit!
5.0
    Pros
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
"Durable little unit. Not the cheap plastic like you would typically expect. The base plate is removable and I have it mounted to the side of my desk, priceless feature! "
 Report Abuse  (3)  (0)  0 comments
Dec 22 2008
Jimmy C
Pittsburgh, PA
I am:
Reviewed at:
Price: $37.99
Great, reliable hub!
5.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Reliable
  • Small
    Cons
  • None
    Best Uses
  • Desktop
  • Home
  • Work
"I have two of these on my personal computer at home and two on my work pc for over one year. They are quick to set up, reliable and are very useful in connecting cables in the back with front ports open for flash drive, camera, BlackBerry, etc. connections. I STRONGLY recommend that you connect th …"  Read Full Review »
Jul 24 2009
KS Wildcat
Napa Valley, CA
I am:
Reviewed at:
Price: $39.99
Failed in less than a month!
1.0
    Pros
  • Easily Expanded
  • Easy To Set Up
  • Fast
  • Small
    Cons
  • Unreliable
    Best Uses
  • None
"I wish I'd seen the reviews already on here before I bought this, because mine failed in just a couple weeks time! Three of the seven ports still work, but I imagine they will fail soon. Interestingly, I see they don't list it as Vista compatible (just XP and prior), but it worked fine with Vista …"  Read Full Review »
Jul 4 2009
Wayne the Angry
Kansas City, MO
I am:
Reviewed at:
Price: $39.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
