CablesToGo 6ft Serial270™ DB9 F/F All Lines Cable
#706
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$10.98 - $29.99
from 5 stores
More Images
Pros
  • Consistent performance (1)
  • Good length (1)
  • Rugged (1)
  • Versatile (1)
See less See more
Cons
  • Incompatible (1)
  • Not full 360 rotation (1)
Best Uses
  • Barcode scanners (1)
  • Dorm room (1)
  • High-end equipment (1)
  • Modular applications (1)
  • Travel (1)
Provided by Cables To Go
Bring ultimate flexibility to RS-232 applications with the patented Serial270™ DB9 Extension Cables by Cables To Go. The 270° DB9 connector on each end rotates from side to side in almost a complete circle, allowing easy positioning of the cable to fit the installation. The connectors feature detents, or “click-stops”, every 90 degrees ensuring signal integrity is maintained. The oversized thumbscrews are slotted for easy connection to equipment. With Serial270™, the days of not having the right connector orientation on your cables are over!
Features
  • Rotating 270 degree connectors on each end move from side to side in almost a complete circle
  • Oversized slotted thumbscrews make connecting to equipment easy
  • Connectors: DB9 Female to DB9 Female
  • Used to convert an existing DB9M/M cable
  • Fully shielded to prevent unwanted EMI/RFI interference
  • All lines wired straight through
**Warning: Forcing the connector past the click-stops will break the connector and possibly damage the cable.
CablesToGo 6ft Serial270™ DB9 F/F All Lines Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 4, 2009
CablesToGo 6ft Serial270™ DB9 F/F All Lines Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Perfect solution for a common problem...
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • Not full 360 Rotation
    Best Uses
  • Barcode Scanners
  • Modular Applications
"We fabricated a custom barcode scanning and verification solution for our production lines. Many of the cables we used needed to be replaced within a month of initial use because of wear on the connectors from slightly adjusting the barcode scanners.
The rotation on these cables allowed us to …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the CablesToGo 6ft Serial270™ DB9 F/F All Lines Cable helpful to you?
May 4 2009
MONOFLO
Winchester, VA
I am:
  • Power User
Reviewed at:
Price: $10.98
Product didn't fit
5.0
    Pros
  • None
    Cons
  • Incompatible
    Best Uses
  • Dorm Room
  • High-End Equipment
  • Travel
"product was fine, but was incompatible with my hardware. "
May 4 2009
masongreen
Long Beach
I am:
  • Power User
Reviewed at:
Price: $10.98
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
