CablesToGo 6 ft USB 2.0 Y Cable
#77
4.5
based on 21 reviews
from $4.99 - $12.99
Ratings Distribution
5 star
15
4 star
3
3 star
2
2 star
1
1 star
0
Category Average
4.1
Low Price:
$4.99 at MacMall
 Trusted:
$9.95 at B&H Photo Video
$4.99 at ClubMac
see all stores
More Images
Pros
  • Consistent performance (5)
  • Versatile (5)
  • Rugged (4)
  • Good length (2)
  • Doesn't kink the wires (1)
  • Professionally assembled (1)
  • Warranty (1)
See less See more
Cons
  • Arms of the "y" are short (1)
  • Too short (1)
Best Uses
  • High-end equipment (2)
  • Travel (2)
  • Shift from drive to drive (1)
Provided by Super Warehouse
There are times you may have an external device- such as a portable 2.5" hard drive- and a standard USB cable is not able to transfer enough power to operate the device. This problem can be easily solved by using the USB 2.0 "Y" Cables. The cable features a red molded hood for the auxiliary USB A connector- allowing the user to easily distinguish between main and auxiliary power. Foil and braid shielding reduces EMI/RFI interference and a twisted-pair construction helps reduce crosstalk- ensuring high-speed- error-free data transfer. This cable is compatible with USB 1.0- 1.1- and 2.0 specifications.
CablesToGo 6 ft USB 2.0 Y Cable Questions
Questions and Answers
Where to Buy
$12.99
$7.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$4.99
Show all 11 stores
_
Product Reviews
Last update: Oct 12, 2009
CablesToGo 6 ft USB 2.0 Y Cable Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
[3 of 3 customers found this review helpful]
5.0
Portable hard drive necessity
"External portable hard drives especially require this cable to function correctly because of the USB port current limit. I am very pleased with the heavier cable construction and reinforcement protection at the cable junction point. Quality color coded connectors allow for the cable to remain attached to the computer and plug in the correct added power connector when needed freeing up a USB port...." Read Full Review »
Jul 08, 2009 by Diamond Cutter
See more positive CablesToGo 6 ft USB 2.0 Y Cable reviews
3.0
Is what it says it is, but TOO SHORT for 15" PowerBook
"Item came as described, although there was no mention of how long the cables were after the split. Unfortunately, due to the fact that the two USB ports are on opposite sides of the 15" PowerBook G4, it's not the solution for me. I can only access one USB port at a time...therefore, not enough power to run my external hard drive...." Read Full Review »
Jan 22, 2009 by jijohns24
See more negative CablesToGo 6 ft USB 2.0 Y Cable reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Travel
"External portable hard drives especially require this cable to function correctly because of the USB port current limit. I am very pleased with the heavier cable construction and reinforcement protection at the cable junction point. Quality color coded connectors allow for the cable to remain attach …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the CablesToGo 6 ft USB 2.0 Y Cable helpful to you?
 Report Abuse  (1)  (0)  0 comments
Jul 8 2009
Diamond Cutter
Memphis, Michigan
I am:
  • Power User
Reviewed at:
Price: $12.99
Not as described, but exactly what I needed
5.0
"Funny thing... I did an Amazon search for a Western Digital USB 2.0 Power Booster Cable (Model: WDCA029RNN), and this is what came up. Only 'after' ordering did I realize that the description of the item was a 6 foot cable, which would have been too long a power cable for my needs. I received the ca …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 10 2009
PAFNY
MY, USA
Reviewed at:
Price: $12.99
Great, but Y is too short
4.0
    Pros
  • Good Warranty
  • Rugged
  • Versatile
    Cons
  • Too short
    Best Uses
  • None
"Great cable for use on removable HD on a 17" Powerbook except the arms of the Y aren't long enough to stretch across both sides of the laptop where the two USB ports are. I would also be interested in a micro USB Y cable for the same application. "
Oct 12 2009
JJMac
Indiana
I am:
  • Enthusiast
Reviewed at:
Price: $12.99
3.0
"Item came as described, although there was no mention of how long the cables were after the split. Unfortunately, due to the fact that the two USB ports are on opposite sides of the 15" PowerBook G4, it's not the solution for me. I can only access one USB port at a time...therefore, not enough pow …"  Read Full Review »
Jan 22 2009
jijohns24
Vancouver, BC
Reviewed at:
Price: $12.99
[2 of 2 customers found this review helpful]
Problem solved!
5.0
"I have a Verbatim 160GB portable hard drive that would not power up. The unit kept flashing, but would not initialize. After researching I found that my older desktop PC was not providing enough power to the drive through only one USB connection. This particular type of cable was suggested as a solu …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Apr 20 2009
S. W. Mertz
S.W. Florida
Reviewed at:
Price: $12.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
