CablesToGo 3ft Ultima™ HD15 to RCA HDTV Component Video Breakout Cable
#298
5.0
based on 2 reviews
from $9.00 - $19.99
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
More Images
Pros
  • Consistent performance (1)
  • Durable (1)
  • Good length (1)
  • Highly compatible (1)
  • Improves performance (1)
  • Reliable (1)
  • Strong connection points (1)
See less See more
Best Uses
  • Computer equipment (1)
  • High-end equipment (1)
Provided by Cables To Go
Ultima HDTV Video Cables are specifically designed for digital and next generation, high-definition analog video applications. The Ultima HDTV Video Cables are constructed from three individually shielded, 75-ohm coax cables, which provide a performance connection that maximizes color and image. The cable features 100% shield with an overlapped foil and copper braid. The shield continues through the connector with a 360-degree solder joint between the cable braid and a copper foil wrap on the HD15 aluminum undermold, providing a shielding solution for a noise-free connection. The Ultima HDTV Video Cable meets the rigid standards of everyday use. Ultima HDTV Video Cables are designed for satellite TV, HDTV, component RGB video, Y/Pb/Pr video and most LCD projectors.
Please note: These cables are not compatible with Y/Cr/Cb video, and are not compatible with all computer monitor ports. Make sure your graphics card supports Y/Pb/Pr component video or that your video source provides a YPbPr component video signal from the HD15 port to use this cable.
Features:
  • Connectors: HD15 male to (3) RCA male
  • Designed for satellite TV, HDTV, component YPbPr video and most LCD projectors
  • Provides a performance monitor connection that maximizes color and imaging
  • 24k gold connectors provide maximum resistance to oxidation for error-free data transfer
  • Ultra-flexible jacket and oversized thumbscrews make installation easy
  • Heavy-duty molded strain relief provides increased flexibility and durability
  • Foil and braid shield for high-resolution images
  • Constructed of three individually shielded miniature 75-ohm coax cables
  • Aluminum undermold shield assists in reducing EMI/RFI interference to meet FCC requirements
CablesToGo 3ft Ultima™ HD15 to RCA HDTV Component Video Breakout Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jul 10, 2009
CablesToGo 3ft Ultima™ HD15 to RCA HDTV Component Video Breakout Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
awesome result
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
"I'm using that with a projector to connect through a BGA port- awesome picture quality!! I am really happy with result and price! "
Was this Audio Visual Cable & Connector review on the CablesToGo 3ft Ultima™ HD15 to RCA HDTV Component Video Breakout Cable helpful to you?
May 4 2009
NYerTeki
Queens, NY
I am:
  • Quality Oriented
Reviewed at:
Price: $19.99
5.0
    Pros
  • Consistent Performance
  • Good Length
    Cons
  • None
    Best Uses
  • High-End Equipment
Jul 10 2009
tolicesar
west palm beach fl
I am:
  • Casual User
Reviewed at:
Price: $19.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
