CablesToGo 39977 Usb2.0 Transfer Cable
#2187
3.5
based on 24 reviews
from $17.00 - $32.06
Ratings Distribution
5 star
10
4 star
6
3 star
0
2 star
3
1 star
5
Category Average
4.1
More Images
Pros
  • Durable (6)
  • Good value (5)
  • High quality (3)
  • Strong connection points (3)
  • Highly compatible (2)
  • Reliable (2)
  • Consistent performance (1)
  • Good length (1)
  • Just plug in and load (1)
  • Rugged (1)
See less See more
Cons
  • Pricey (1)
Best Uses
  • Computer equipment (3)
  • Data transfer between pcs (1)
  • High-end equipment (1)
  • Safe way to transfer (1)
  • Transfer data (1)
Provided by Beach Audio
The USB 2.0 Vista-Compatible Easy Transfer Cable provides a hassle-free way to transfer all of your files from your older Windows XP system to the new Windows Vista system. A simple wizard-driven program walks you through a few simple steps, enabling you to transfer your files (such as program data files, photos, music, videos), e-mails, and settings from your old system to your new Vista system in no time. This transfer cable is also able to transfer data between two XP or two Vista systems.
CablesToGo 39977 Usb2.0 Transfer Cable Questions
Questions and Answers
Where to Buy
$19.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$19.99
$1.99 Shipping on Orders Over $75 ends 12/31/09
$17.00
Show all 9 stores
_
Product Reviews
Last update: Nov 17, 2009
CablesToGo 39977 Usb2.0 Transfer Cable Reviews
Most helpful positive review
Most helpful negative review
4.0
The cables were awsome, but.....
"When I finally found a reference to the NERO music program I was using and then deleted it, the Easy Transfer Program worked. The cables transfered 80 gigs of info, set up for four users flawlessly. With Nero gone this process lasted only 40 minutes. I think the Easy Transfer Program needs to be improved to describe the exact problem. Overall I would recommend this product...." Read Full Review »
Feb 26, 2009 by cmorbeach
See more positive CablesToGo 39977 Usb2.0 Transfer Cable reviews
1.0
I purchased this transfer ...
"I purchased this transfer cable and software on the strong advice of a chat tech here. Some of the worst advice I've ever been given. If you're going to use this system, be very, VERY careful what's transferred, especially if your new computer has programs already installed. The data conflicts between old OS and new OS files have been beyond nightmarish. I've been trapped in rollback and re-install hell for ..." Read Full Review »
Nov 17, 2009 by Kelli
See more negative CablesToGo 39977 Usb2.0 Transfer Cable reviews
Displaying 1 - 5 of 24 Reviews
Show
Sort by
1.0
"I purchased this transfer cable and software on the strong advice of a chat tech here. Some of the worst advice I've ever been given. If you're going to use this system, be very, VERY careful what's transferred, especially if your new computer has programs already installed. The data conflicts be …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the CablesToGo 39977 Usb2.0 Transfer Cable helpful to you?
Nov 17 2009
Kelli
Undisclosed
Reviewed at:
Price: $19.99
4.0
    Pros
  • Durable construction
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
"When I finally found a reference to the NERO music program I was using and then deleted it, the Easy Transfer Program worked. The cables transfered 80 gigs of info, set up for four users flawlessly. With Nero gone this process lasted only 40 minutes. I think the Easy Transfer Program needs to be im …"  Read Full Review »
Feb 26 2009
cmorbeach
Seattle WA
I am:
  • Quality Oriented
Reviewed at:
Did what it said it would do!
5.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"You plug the cord into both cpu's. You may have to use the cd that comes with it to upload a program onto your OLD computer. Then you follow the Window direction prompts. It was pretty simple, really. The only cons I saw were that the directions were a tad vague, and they looked a little like a …"  Read Full Review »
Jan 22 2009
chinesesquawk
Evanston, IL
Reviewed at:
Does What It Is supposed To Do
4.0
    Pros
  • Highly Compatible
    Cons
  • None
    Best Uses
"This is a pretty straightforward kind of product. You install the software in both computers (Windows XP)plug one end of the cable into a USB port on one computer and the other end into the USB port on the other computer and start the software and that's it.
This was also the best price I found. "
Feb 28 2009
Al from SLO
San Luis Obiapo CA
I am:
  • Quality Oriented
Reviewed at:
We brought this item to ...
5.0
"We brought this item to facilitate transferring our old XP computer to our new Vista computer. Very easy to set up, but be careful. It will literally take your C drive from one computer to the other and same with any other hard drive. This caused a problem for us because our old computer had a sm …"  Read Full Review »
Sep 12 2009
Wally
Undisclosed
Reviewed at:
Price: $19.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
