CablesToGo 2m Velocity™ High-Speed HDMI™ Cable
#4
4.7
based on 42 reviews
Ratings Distribution
5 star
35
4 star
4
3 star
0
2 star
0
1 star
2
Category Average
4.1
$15.00 - $34.99
from 16 stores
More Images
Pros
  • Good length (16)
  • Consistent performance (15)
  • Rugged (9)
  • Versatile (7)
  • Warranty (4)
  • Cheap, as in dollars (1)
  • Easy to install (1)
  • Pricey (1)
See less See more
Cons
  • Doesn't repel dust (1)
  • Wears out quickly (1)
Best Uses
  • High-end equipment (16)
  • Dorm room (3)
  • Anywhere (1)
  • Digital cable tv (1)
  • Personal computer set up (1)
Provided by MacMall
Impact Acoustics Velocity High-Definition Multimedia Interconnect - Video / audio cable - HDMI - 19 pin HDMI (M) - 19 pin HDMI (M) - 10 ft - shielded - ( HDMI 1.3 ) - blue Certified to perform at standards set by HDMI. Velocity HDMI cables deliver a strong combination of performance and value. Enjoy high-resolution digital video and true digital audio, delivered together in one convenient, compact connection. ... Certified to perform at standards set by HDMI. Velocity HDMI cables deliver a strong combination of performance and value. Enjoy high-resolution digital video and true digital audio, delivered together in one convenient, compact connection. High-quality materials and construction ensure a lifetime of dependable performance. Fully-shielded conductors provide complete immunity to EMI/RFI interference, and 24-karat gold-plated connectors ensure superior signal transfer. These fully-functional, high-bandwidth cables are tested to perform at industry standards.
Specification Description
Model 402XX, 40314, 40315, 40315-
UPC 757120403142
Accessory Indicator Yes
Benefits Fully shielded to help provide immunity from environmental EMI and RFI24-karat gold-plated connectors ensure superior signal transfer
Cable Length 9.75 ft
Cable Technology Shielded
Cable Type HDMI cable
Capacity UOM mAh
Color Blue
Country Of Origin China
Description Header Power to perform.
Display Catalog Number 55009410
Features HDMI male to HDMI male connectorsPure digital video, digital audio and intercomponent control signals all in one compact connection
Included Qty x Type 1 X HDMI M-HDMI M interconnect
Left Connector(s) HDMI m
Manufacturer Labor Warranty 12
Manufacturer Part Number 40316
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 40316
Operating Temperature UOM ° F
Product Type Cable
Right Connector(s) HDMI m
Supported Languages English
CablesToGo 2m Velocity™ High-Speed HDMI™ Cable Questions
Questions and Answers
Where to Buy
$24.99
$24.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$15.00
Show all 16 stores
Product Reviews
Last update: Nov 12, 2009
CablesToGo 2m Velocity™ High-Speed HDMI™ Cable Reviews
Most helpful positive review
[1 of 1 customers found this review helpful]
Most helpful negative review
5.0
It Is What It Says It Is!
"High quality indeed. No noticeable signal degradation at all, which is what counts. I'm not going to say I bench tested it for speed, I'll leave that for the engineers and anally retentive, but it gets the job done. Soft/slick jacket makes for easy snaking through the entertainment center. No noticeable interference from being close to 120 Volt lines either. It doesn't appear to repel dust, but I'm not dustin..." Read Full Review »
Aug 27, 2009 by Joe
See more positive CablesToGo 2m Velocity™ High-Speed HDMI™ Cable reviews
1.0
DO NOT BUY THIS CABLE
"Bought 2 of these cables - within weeks both cables stopped working. Upon investigation, it was the connector ends connection to the cable that became loose. Note: once they were installed they were not touched - so how they became loose by themselves I don't know. DO NOT BUY THIS CABLE..." Read Full Review »
Jul 29, 2007 by MikeJohnson
See more negative CablesToGo 2m Velocity™ High-Speed HDMI™ Cable reviews
Displaying 1 - 5 of 42 Reviews
Show
Sort by
5.0
    Pros
  • Consistent Performance
  • Good Length
    Cons
    Best Uses
  • High-End Equipment
No noticeable signal degradation at all, which is what counts. I'm not going to say I bench tested it for speed, I'll leave that for the engineers and anally retentive, but it gets the job done. Soft/slick jacket makes for easy snaking through the entertainment center. No no …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the CablesToGo 2m Velocity™ High-Speed HDMI™ Cable helpful to you?
 Report Abuse  (1)  (0)  0 comments
Aug 27 2009
Joe
Stroudsburg, Pa
I am:
  • Enthusiast
Reviewed at:
Price: $23.99
Works perfectly
5.0
    Pros
  • Good Length
  • Good Warranty
  • Rugged
    Cons
  • None
    Best Uses
  • Dorm Room
"Used the cable to hook up a Roku Digital Video Player to my TV (it delivers HD in 720p which the cable handled fine at top quality for the player.)
Overall it works perfectly. Other cables are either excessively expensive or cheap enough that you question their material or manufacturing quality …"  Read Full Review »
Sep 22 2009
Mitch
Long Island, NY
I am:
  • Casual User
Reviewed at:
Price: $23.99
Great Cables
5.0
    Pros
  • Versatile
    Cons
  • NA
    Best Uses
  • Personal Computer Set Up
"I use the HDMI cables for my personal computer. I'm a gammer and love the Steady and Reliable HD signal the cables give without fail. WOW never looked so good!!!
Perfect length for my set up and I can't think of anything wrong with my purchase. Im VERY glad i found this websight and I've told every …"  Read Full Review »
Jun 6 2009
BeRad
Columbus, Oh
I am:
  • Enthusiast
Reviewed at:
Price: $23.99
Great cable great price!!
5.0
    Pros
  • Good Length
  • Good Warranty
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
"Connect cd player to reciever "
Nov 9 2009
vernbo
westminster,co
I am:
  • Casual User
Reviewed at:
Price: $23.99
1.0
    Pros
  • PRICE
    Cons
  • Wears Easily
    Best Uses
  • None
DO NOT BUY THIS CABLE "
Jul 29 2007
MikeJohnson
Milwaukee, WI
I am:
  • Gearhead
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
