CablesToGo 2ft Port Authority USB to 2-Port Serial DB9 Adapter
#728
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$49.74 - $79.99
from 11 stores
More Images
Pros
  • Consistent performance (1)
  • Easy to install (1)
See less See more
Best Uses
Provided by Cables To Go
The USB to 2-Port DB9 Serial Adapter from Cables To Go is the perfect way to connect serial devices to laptops or PCs with no serial ports. Many new laptops and PCs have at the most, one serial port. This is a problem when you have multiple devices with serial connectors! What happens when you have a digital camera and a PDA that you want to connect at the same time? The USB to 2-Port DB9 Serial Adapter is the answer to that problem. It is designed for connections to PDAs, digital cameras, modems, ISDN terminal adapters, or any other serial devices through your USB port. Since the adapter uses no IRQs, it is perfect for attaching several serial devices to your PC. And don’t worry about transfer speeds; the USB to 2-Port DB9 Serial Adapter supports data transfer rates of over 230kbps!
The USB to 2-Port DB9 Serial Adapter provides you with the connections you need without the hassles. The plug-and-play functionality makes installation a breeze. The adapter is bus powered so no additional power source is needed. The light-weight design makes it perfect for the business traveler. Throw it in your laptop bag and be on your way!
Features:
  • Connectors: One USB A to two (2) DB9 Male
  • Cable length: 2 feet
  • Works with PDAs, digital cameras, modems, and ISDN terminal adapters
  • Supports automatic handshake mode
  • Over 230kbps data transfer rate
  • Supports remote wake-up and power management
  • 96 byte buffer each for upstream and downstream data flow
  • Easy installation
  • Gives you an additional RS-232 port and frees your existing ports for other uses
  • No IRQs, no IRQ conflicts
CablesToGo 2ft Port Authority USB to 2-Port Serial DB9 Adapter Questions
Questions and Answers
Where to Buy
$64.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$79.99
$49.74
Show all 11 stores
Product Reviews
Last update: May 4, 2009
CablesToGo 2ft Port Authority USB to 2-Port Serial DB9 Adapter Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Great, works well
5.0
    Pros
  • Consistent Performance
  • Easy to install
    Cons
  • None
    Best Uses
  • None
"I just plugged this in, installed right way, went into device manager and changed port setting. Great USN to serial "
Was this Audio Visual Cable & Connector review on the CablesToGo 2ft Port Authority USB to 2-Port Serial DB9 Adapter helpful to you?
May 4 2009
George
Eugene, OR
I am:
  • Enthusiast
Reviewed at:
Price: $79.99
I bought a new hp Desktop ...
5.0
"I bought a new hp Desktop and Laptop without realizing they have no serial port.
Bought this product and it solved the problem.
Installed on XP. Installation was simple and it works flawlessly. Pretty ''smart'' so you dont do needless config details. Recommend unconditionally. "
Nov 12 2006
curt
Undisclosed
Reviewed at:
Price: $64.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
