CablesToGo 25ft HD15 M/M UXGA Monitor Cable with 3.5mm Audio
#424
4.5
based on 4 reviews
Ratings Distribution
5 star
2
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.1
$26.00 - $59.99
from 8 stores
Pros
  • Durable (3)
  • Highly compatible (2)
  • Consistent performance (1)
  • Improves performance (1)
  • Reliable (1)
  • Rugged (1)
  • Strong connection points (1)
See less See more
Best Uses
  • Computer equipment (1)
  • Computer to hdtv (1)
  • High-end equipment (1)
  • Projector connections (1)
  • Travel (1)
Provided by Cables To Go
The Pro Series UXGA Monitor Cable with 3.5mm Audio is the ideal high performance solution for quickly connecting your PC to a video display system with speakers. Use this cable with projectors, flat-screen monitors, KVM switches with audio, speakers or a microphone. Designed to support resolutions up to 1600x1200, this cable can support distances up to 100 feet without conditioning the signal. Plus this cable is shielded to extend your video and audio signals without distortion or loss.
Features:
  • Ideal for video presentations, projector applications, and classroom environments
  • Drive signals without ghosting or signal distortion
  • Distance from the HD15M connector to the 3.5mm stereo plug is about 12 inches
  • Includes an HD15 F/F Mini Gender Changer (#18962) for more audio and video applications.
CablesToGo 25ft HD15 M/M UXGA Monitor Cable with 3.5mm Audio Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 10, 2009
CablesToGo 25ft HD15 M/M UXGA Monitor Cable with 3.5mm Audio Reviews
Displaying 1 - 4 of 4 Reviews
Show
Sort by
Prompt, but slight problem with cable
4.0
    Pros
  • Consistent Performance
  • Rugged
    Cons
  • None
    Best Uses
  • High-End Equipment
  • Travel
"This cable has a built-in audio cable that could be a few inches longer to easily access the vdieo and the audio port on my laptop(s). "
Was this Audio Visual Cable & Connector review on the CablesToGo 25ft HD15 M/M UXGA Monitor Cable with 3.5mm Audio helpful to you?
Aug 10 2009
Old Guy
Riverside, CA
I am:
  • Enthusiast
Reviewed at:
Price: $59.99
Just what the doctor ordered
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Projector Connections
"Perfect for connecting a laptop to a projection system - Video and Audio in one cable. Now if only they would make a DVI version. "
May 4 2009
Fred
Stanford CA
I am:
  • Quality Oriented
Reviewed at:
Price: $59.99
High Quality
5.0
    Pros
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Computer to HDTV
"I use this to connect my iMac to my Samsung 52" HDTV. I use the PC inputs on my TV. Works great! "
May 4 2009
4score
Auburn, CA
I am:
  • Quality Oriented
Reviewed at:
Price: $59.99
Quality Cable
4.0
    Pros
    Cons
  • None
    Best Uses
  • Computer Equipment
"Works great. No issues. "
May 4 2009
User
VA
I am:
  • Value Oriented
Reviewed at:
Price: $59.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
