CablesToGo 25ft Cat6 550MHz Snagless Crossover Cable Red
#127
5.0
based on 2 reviews
Ratings Distribution
5 star
2
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
$3.00 - $13.16
from 14 stores
More Images
Pros
  • Consistent performance (2)
  • Good length (2)
  • Great for my riverbed sh (1)
See less See more
Best Uses
  • High-end equipment (1)
  • Wireless bridge (1)
Provided by Cables To Go
Fast, fast, fast - the three words that describe Cables To Go's Cat 6 network cables. Perfect for distributing data, voice and video, these 550MHz rated patch cables ensure you always have the necessary throughput to handle today's and tomorrow's bandwidth-intensive applications. Each cable is fully tested and quality inspected, ensuring all EIA/TIA Cat 6 TIA/EIA- 568-B-2.1, draft 9 standards are met.
Cat 6 patch cords from Cables To Go drastically reduce both impedance and structural return loss (SRL) as compared to standard 100 Mhz wire, which ensures error-free transmission! pairs and that helps to maintain Constructed with high-quality cable and a shortened body plug, this design will keep Near-End Crosstalk (NEXT) levels to a minimum.
Our all-new molded, snag-free "clip" prevents unwanted cable snags during installation without impairing your ability to insert and remove the connector from the port. It also provides unparalleled strain-relief, so that the cable is not damaged even when pulled on excessively.
Features:
  • Connector: 50-micron gold plated RJ45 Male to Male
  • Conductor: 24 AWG Stranded Copper
  • Jacket: PVC
  • All-new molded, snag-free boot prevents unwanted cable snags while providing easy insertion and extraction from network ports
  • Crossed pin configuration allows you to connect two computers "peer-to-peer" without the need for a hub or switch
  • Perfect for connecting network switches and hubs without an uplink port to other switches and hubs
CablesToGo 25ft Cat6 550MHz Snagless Crossover Cable Red Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 6, 2009
CablesToGo 25ft Cat6 550MHz Snagless Crossover Cable Red Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Cat6 crossover ethernet cable
5.0
    Pros
  • Consistent Performance
  • Good Length
    Cons
  • None
    Best Uses
  • Wireless bridge
"My Squeezebox3 (by Logitech) is a wireless network music device that provides internet radio streams to my home theater sound system. I bought a network Bluray disk player that wants an ethernet connection to function with Netflix etc, but there is no RJ-45 socket anywhere near my hi-fi gear. Fortun …"  Read Full Review »
Was this Audio Visual Cable & Connector review on the CablesToGo 25ft Cat6 550MHz Snagless Crossover Cable Red helpful to you?
Nov 6 2009
Long John Silver
Alexandria VA
I am:
  • Enthusiast
Reviewed at:
Price: $10.99
Awesome crossover cable - and it's red!
5.0
    Pros
  • Good Length
  • Great for my Riverbed SH
    Cons
  • None
    Best Uses
  • High-End Equipment
"This is a great crossover cable. I have tried several others on my Riverbed Steelhead and none are giving us the solid consistent performance that this cable is. I highly recommend it! "
May 4 2009
BeFree
Arlington, VA
I am:
  • Power User
Reviewed at:
Price: $10.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
