CablesToGo 2-Port UXGA Monitor Splitter Extender
#1
4.8
based on 21 reviews
Ratings Distribution
5 star
18
4 star
2
3 star
1
2 star
0
1 star
0
Category Average
4.1
$34.99 - $44.99
from 16 stores
More Images
Pros
  • Compact design (4)
  • Easy to use (3)
  • High quality (3)
  • Highly compatible (3)
See less See more
Best Uses
  • Complex projects (1)
  • Large room projection (1)
  • Office training (1)
  • Trade shows (1)
Provided by Cables To Go
Break the limits of SVGA with a Port Authority2 VSE from Cables To Go. Simultaneously distribute any video signal to up to 8 different video outputs, while maintaining vivid picture quality. The VSE is powerful, yet easy to use. Connect the cables, and you’re ready to go! There is no software or complicated interface cards to install. The VSE not only distributes, but also boosts your high-resolution video signal up to 210 feet. Available with two, four and eight ports, the VSE is perfect for classrooms, exhibits, trade shows, monitor testing, demonstrations and multi-media presentations. The VSE is also ideal for broadcasting video information such as news headlines, stock prices, airline flights and train schedules.
Specifications and Features:
  • Power-Saving Mode
  • No Software Required
  • Color-Coded Connectors - HD15 Male Input, HD15 Female Output
  • 350MHz Video Bandwidth - 2 & 4 Port Models
  • Durable All-Metal Housing
  • Power and Activity LED Indicators
  • 1920 x 1440 @80Hz Maximum Resolution
  • FREE technical support and 1 Year Warranty
  • Transmission distance of up to 210 feet
  • Suitable for XGA, SVGA, VGA, and Multi-Sync monitors
  • Daisy-Chain multiple units together for even more outputs
Please note: The term "extender" refers to the ability of the product to extend the distance of your cable runs to 210 feet. It does not mean the product provides "extended desktop" functionality, or the ability to view different information on each of your monitors. If you are looking to add extended desktop capabilities to your computer, please take a look at our product #30534
Specification Description
Model 29550, 29550-, 39967
UPC 757120295501
Accessory Indicator Yes
Benefits Distributes and boosts your high-resolution video signal up to 210 feetNo software or interface cards to install and color-coded conn
Capacity UOM mAh
Country Of Origin China
Description Header Spread the word.
Display Catalog Number 55014685
Features Works with XGA, SVGA, VGA and MultiSync monitorsCables To Go free technical support for peace of mind
Manufacturer Labor Warranty 12
Manufacturer Part Number 29550
Manufacturer Parts Warranty 12
MAP Price 0.0
Model 29550
Operating Temperature UOM ° F
Product Type Splitters
Required to function System with HD15 VGA video cardMale-to-female SVGA cable2 male-to-male SVGA cables
Supported Languages English
CablesToGo 2-Port UXGA Monitor Splitter Extender Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 29, 2009
CablesToGo 2-Port UXGA Monitor Splitter Extender Reviews
Most helpful positive review
[9 of 9 customers found this review helpful]
Most helpful negative review
[2 of 2 customers found this review helpful]
5.0
Excellent 2 Port VGA Splitter
"I needed to split the output of one computer so I could feed a monitor and a projector. The projector has a run of 25 feet so just splitting the cable with a Y splitter wouldn't work. It would degrade the signal too much. This powered splitter works great. It's a very solid little unit and very nicely built. The image on the monitor and the projector look great. I highly recommend this for driving two displays..." Read Full Review »
Nov 26, 2007 by Scott Bright
See more positive CablesToGo 2-Port UXGA Monitor Splitter Extender reviews
3.0
Works well, but doesn't come with a male-to-fem VGA adapter..
"After I received the product, I learned that it requires a male-to-female VGA adapter or cable, which doesn't come with it...." Read Full Review »
Jan 12, 2009 by JW
See more negative CablesToGo 2-Port UXGA Monitor Splitter Extender reviews
Displaying 1 - 5 of 21 Reviews
Show
Sort by
5.0
This powered splitter works great. It's a very solid little unit and very ni …"  Read Full Review »
Was this Video Amplifier, Splitter, & Modulator review on the CablesToGo 2-Port UXGA Monitor Splitter Extender helpful to you?
 Report Abuse  (9)  (0)  0 comments
Nov 26 2007
Scott Bright
Grayslake, IL USA
Reviewed at:
Price: $44.99
[8 of 8 customers found this review helpful]
One of the better units out there
5.0
"We needed to split a trainer's display between a monitor and a projector, which would need a long run to reach the unit, and upon reading other reviews, comments, and specs, I decided upon this unit. It arrived, solid and stout, and it has worked beautifully. The unit has a heft to it, which helps …"  Read Full Review »
 Report Abuse  (8)  (0)  0 comments
Jan 2 2007
Shane O. Laake
Columbus, OH
Reviewed at:
Price: $44.99
Easily support multiple projectors
5.0
    Pros
  • Compact Design
  • Easy To Use
  • Highly Compatible
    Cons
  • None
    Best Uses
  • Office training
  • Trade shows
"I have 2 of these. One is in a room with 2 video projectors facing different audiences watching identical content. 150' cable runs to each projector. This box creates a flawless picture on both projectors from a single video source.
The second unit is in a large room where the projector was too d …"  Read Full Review »
Oct 15 2009
Chasmo
Tucson, Arizona
I am:
  • Computer support tech
I PLAN ON ORERING MORE FOR OUR CHURCH
5.0
    Pros
  • Compact Design
  • Highly Compatible
  • Professional Quality
    Cons
  • None
    Best Uses
  • None
"We used the video splicer for our sanctuary video praise and worship and plan on ordering more in the video equipment in the coming months. Onne 100 per cent satisfied.
Pastor Richard Reid Sr. ThD
Senior Pastor
Faith Ministry Church "
Oct 29 2009
Dick
Sparta, Illinois 62286
Nice piece of equipment
5.0
"I purchased this product to connect a new LCD TV to a PC in order to facilitate the use of the PC for training. I wanted to be able to replicate both the video and sound from the PC to the TV, since the PC is in one corner of the classroom and the TV in the other. This device is powered and from w …"  Read Full Review »
Feb 24 2008
Keith Hermiz
Amazon
Reviewed at:
Price: $44.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
