CablesToGo 1ft Monitor Power Adapter Cable (NEMA 5-15R to IEC320C14)
#2120
3.8
based on 5 reviews
from $3.99 - $6.99
Ratings Distribution
5 star
3
4 star
0
3 star
1
2 star
0
1 star
1
Category Average
4.1
Low Price:
$3.99 at OnSale
 Trusted:
$4.99 at MacMall
Find it at Amazon
More Images
Pros
  • Good length (4)
  • Rugged (3)
  • Consistent performance (2)
  • Versatile (2)
See less See more
Cons
  • Incompatible (1)
Best Uses
  • High-end equipment (4)
  • Non-standard set up (1)
Provided by Cables To Go
Plug in the Monitor Power Adapter Cable from Cables To Go to make your work environment more flexible and efficient. All Cables To Go power cables feature a fully molded design that provides maximum durability and long life.
  • Cable Type: Heavy-Duty 18AWG
  • Connectors: 3-pin Shroud Male to 3-Prong Grounded Plug Female
  • Design: Female connector plugs directly into device, and male connector plugs into existing cable
  • Compatibility: Monitors
  • Application: Female connector plugs into device, and male connector plugs into auxiliary power port on power supply for auto power when the system is turned on
  • Rated: 10 Amps
  • Warranty: Lifetime
CablesToGo 1ft Monitor Power Adapter Cable (NEMA 5-15R to IEC320C14) Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Oct 5, 2009
CablesToGo 1ft Monitor Power Adapter Cable (NEMA 5-15R to IEC320C14) Reviews
Displaying 1 - 5 of 5 Reviews
Show
Sort by
High quality power cables
5.0
    Pros
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
  • High-End Equipment
"We are using this product in a high performace, computing environment so need the best. Packaged well and shipped quickly. Highly recommended. "
Was this Audio Visual Cable & Connector review on the CablesToGo 1ft Monitor Power Adapter Cable (NEMA 5-15R to IEC320C14) helpful to you?
Oct 5 2009
Bill the UNIX SA
Annapolis Junction, MD.
I am:
  • Power User
Reviewed at:
Price: $4.99
The easiest way to procure a temporary e
5.0
    Pros
  • Versatile
    Cons
  • None
    Best Uses
"When a few extra feet of power cable is all is needed for a presentation or temporary arrangement, this product is very handy because it allows you to use the ever present power cords as an extension "
May 5 2009
elptuxman
El Paso, TX
I am:
  • Power User
Reviewed at:
Price: $4.99
Great!
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
"Great Product! Would recommend this someone needing a cable like this. "
Jul 15 2009
Jared
Chelsea, OK
I am:
  • Casual User
Reviewed at:
Price: $4.99
Good Quality for less price
1.0
    Pros
  • Good Length
  • Rugged
    Cons
  • None
    Best Uses
"This product is used in a development environment and works very good. [...] "
May 7 2009
Chris
Arlington, VA
I am:
  • Casual User
This is only rated for 120 volts AC.
3.0
    Pros
  • Good Length
    Cons
  • Incompatible
    Best Uses
"This is only rated for 120 volts AC be aware of use and power ratings. "
Jun 5 2009
James_Bondo
UK
I am:
  • Power User
Reviewed at:
Price: $4.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
