CablesToGo 10ft USA Cat6 Stranded Patch Cable - Blue
5.0
based on 1 review
Ratings Distribution
5 star
1
4 star
0
3 star
0
2 star
0
1 star
0
Category Average
4.1
Low Price:
$11.99 at MacMall
 Trusted:
$13.80 at PC Connection
$11.99 at ClubMac
see all stores
$11.99 - $13.80
from 4 stores
Pros
  • Consistent performance (1)
  • Good length (1)
  • Rugged (1)
  • Versatile (1)
See less See more
Best Uses
  • High-end equipment (1)
Provided by Cables To Go
Stay ahead of the game with Cables To Go's Cat6 550Mhz Patch Cables. These high-speed cables are an ideal solution for distributing data, voice and video, delivering stable performance to 550 MHz. Each cable meets EIA/TIA Cat 6 TIA/EIA- 568-B-2.1, draft 9 standards. They will handle bandwidth intensive applications up to 550 Mhz and beyond and drastically reduce both impedance and structural return loss (SRL) as compared to standard 100 Mhz wire. Constructed with high-quality cable and a shortened body plug, this design will keep Near-End Crosstalk (NEXT) levels to a minimum. The molded, snag-free boot prevents unwanted cable snags during installation and provides strain-relief. Cables To Go USA Cat6 550Mhz Patch Cables are available in multiple colors, allowing easy color-coding of your network installation.
These high-speed patch cords are 100% manufactured and tested within the United States. They are an ideal solution for anyone that needs to procure products that are manufactured exclusively in the USA.
  • Connector: 50-micron gold plated RJ-45 Male to Male
  • Conductor: 24 AWG Stranded Copper
  • Jacket: PVC
  • Molded, Snag-Free boot prevents unwanted cable snags
  • Applications:
    • Gigabit 1000 BASE-T; 100 BASE-T; 10 BASE-T (IEEE 802.3)
    • 4/16 Mbps Token Ring (IEEE 802.5); 100 VG-AnyLAN
    • 100 Mbps TP-PMD (ANSI X3T9.5); 55/155 Mbps ATM
    • Voice; T1
    • High bandwidth applications such as 622 ATM, Wideband
  • Designed For: Network Adapters, Hubs, Switches, Routers, DSL/Cable Modems, Patch Panels and other twisted-pair applications
  • Standard: Category 6 TIA/EIA- 568-B-2.1, draft 9
CablesToGo 10ft USA Cat6 Stranded Patch Cable - Blue Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Aug 18, 2009
CablesToGo 10ft USA Cat6 Stranded Patch Cable - Blue Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Quality Product!
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
"Used in data center environment to reduce time/cost assocated with making your own cables. Product stands up to it's name and functions as expected. "
Was this Audio Visual Cable & Connector review on the CablesToGo 10ft USA Cat6 Stranded Patch Cable - Blue helpful to you?
Aug 18 2009
Tim
Georgia
I am:
  • Power User
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
