CablesToGo 10ft Pro Series HD15 M/F UXGA Monitor Extension Cable
#329
4.5
based on 2 reviews
Ratings Distribution
5 star
1
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.1
$13.00 - $37.99
from 8 stores
Pros
  • Consistent performance (1)
  • Durable (1)
  • Good length (1)
  • Highly compatible (1)
  • Improves performance (1)
  • Reliable (1)
  • Rugged (1)
  • Strong connection points (1)
  • Versatile (1)
  • Warranty (1)
See less See more
Best Uses
  • Computer equipment (1)
  • High-end equipment (1)
Provided by Cables To Go
Now you can place your monitor where you want to place it! Introducing, Cables To Go's Workstation Monitor Cables. Ferrited and Double Shielded, Cables To Go monitor cables can go the distance without Ghosting and Signal Distortion. They are truly worry free since they are constructed with premium grade composite coaxial and twisted pair shielded cables. Going 100ft and beyond...no problem. Cables To Go Workstation monitor cables ensure crisp, distortion free video so you have maximum monitor positioning flexibility. These ultra-premium monitor cables are ideal for extending the distance of your monitor from your PC. Premium VGA Monitor extension cables are ideal for video presentations, classroom environments, POS, server rooms, or just for organizing your work area for maximum comfort and efficiency.
  • Connector: HD15 Male to HD15 Female
  • Constructed of premium grade double-shielded video cable
  • Three internal coax lines for red, green and blue
  • 125% Foil shielding; 90% Tinned Copper Braid shielding
  • Ferrites protect against EMI/RFI interference
  • Accommodates cable runs up to 100ft without a booster (in most cases)
  • Extend the distance of your monitor from your PC
CablesToGo 10ft Pro Series HD15 M/F UXGA Monitor Extension Cable Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 10, 2009
CablesToGo 10ft Pro Series HD15 M/F UXGA Monitor Extension Cable Reviews
Displaying 1 - 2 of 2 Reviews
Show
Sort by
Video extension cables
4.0
    Pros
  • Consistent Performance
  • Good Length
  • Good Warranty
  • Rugged
  • Versatile
    Cons
  • None
    Best Uses
  • High-End Equipment
"We use the cables on our controls interface for the powerhouse. The computers are remotely located from the operator console. The cables allow us to mount the monitors as needed. [...]They were easy to install and appear to be built to last. "
Was this Audio Visual Cable & Connector review on the CablesToGo 10ft Pro Series HD15 M/F UXGA Monitor Extension Cable helpful to you?
Nov 10 2009
Matt D
Louisville, KY
I am:
  • Enthusiast
Reviewed at:
Price: $37.99
[1 of 1 customers found this review helpful]
Cables to go are just that
5.0
    Pros
  • Durable construction
  • Highly Compatible
  • Improves Performance
  • Reliable
  • Strong Connection Points
    Cons
  • None
    Best Uses
  • Computer Equipment
"The cable I received fit perfectly the first time and I have been using it with my mobile projector going from class to class doing powerpoint presentations and the cable has withstood all my connecting and reconnection without error. I have ordered cables from other sources that left much to be des …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 5 2009
beethovn
Greenville, South Carolina
I am:
  • Quality Oriented
Reviewed at:
Price: $37.99
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
