Cables Unlimited USB to Parallel Printer Adapter Cable
#1131
3.8
based on 39 reviews
from $10.99 - $26.07
Ratings Distribution
5 star
17
4 star
7
3 star
4
2 star
5
1 star
4
Category Average
4.1
More Images
Pros
  • Durable (2)
  • Fairly simple to install (1)
  • Highly compatible (1)
  • Improves performance (1)
  • Reliable (1)
  • Strong connection points (1)
  • Well crafted (1)
See less See more
Cons
  • Limited compatibility (2)
  • No cons these are perfec (1)
Best Uses
  • Computer equipment (3)
  • Convert printer to usb (1)
  • High-end equipment (1)
Provided by Kmart
Centronics 36 Printer Connection. Attractive plastic housing. 6' Cable, USB Type A, Centronics 36 Pin Male, Bus powered. Bi-directional communication between PC and printer. USB Ver. 1.1 Compliant. Supports WIN98/2000/XP/Vista.Bi-directional communication between PC and printer. USB Ver. 1.1 Compliant. Supports WIN98/2000/XP/Vista.Supported printers include inkjet and laser printers from HP, Lexmark, Epson and Canon and all other compatible clones. Draws its power from the USB port.Connects to the parallel port on your printer. Note: When using this with a HP Officejet or other multifunction product, this cable will only allow access of the printer capability. It will not work with the faxing and scanning capabilities of the multifunction product.
Specification Description
Model USB-1470-06, USB147006
UPC 724580113119
Type Type A Male USB to 36-pin Centronics Male Parallel
Cables Unlimited USB to Parallel Printer Adapter Cable Questions
Questions and Answers
Where to Buy
$16.99
$14.99
$1.99 Shipping On Orders Over $100 at TigerDirect
BizRate Rating Outstanding 9.1
$10.99
Code SEARS5OFF50 : $5 Off Orders Over $50!
Show all 15 stores
_
Product Reviews
Last update: Oct 22, 2009
Cables Unlimited USB to Parallel Printer Adapter Cable Reviews
Most helpful positive review
Most helpful negative review
4.0
This is a great product ...
"This is a great product for keeping old printers running. Several reviewers have noted correctly that there is a problem using this with Vista 64 bit. Vista 64 requires digitally signed drivers. The driver for this cable (and my old HP LaserJet) are not signed, so Vista 64 won't install them. Here's the solution -- as you boot your computer, press F8. Select the option to bypass the requirement for digital ..." Read Full Review »
Aug 08, 2009 by Ole
See more positive Cables Unlimited USB to Parallel Printer Adapter Cable reviews
2.0
Couldn't get the cable to ...
"Couldn't get the cable to work with my LaserJet HP3P. Tried installing the drivers, but couldn't get it to print. Tried different ports USB 1.1, USB2.0, LP1 etc. Called and sent e-mails to Cables Unlimeted, but they responded 2 weeks later after I gave up on the cable and had already returned. Well 3hrs trying to diagnose this problem and then had to pay return shipping costs when the Tiger say's satisfaction g..." Read Full Review »
Mar 31, 2009 by Anonymous
See more negative Cables Unlimited USB to Parallel Printer Adapter Cable reviews
Displaying 1 - 5 of 39 Reviews
Show
Sort by
4.0
"This is a great product for keeping old printers running. Several reviewers have noted correctly that there is a problem using this with Vista 64 bit. Vista 64 requires digitally signed drivers. The driver for this cable (and my old HP LaserJet) are not signed, so Vista 64 won't install them. He …"  Read Full Review »
Was this Computer Cable & Connection review on the Cables Unlimited USB to Parallel Printer Adapter Cable helpful to you?
Aug 8 2009
Ole
Undisclosed
Reviewed at:
Price: $14.99
Works as advertised.
4.0
    Pros
    Cons
  • None
    Best Uses
  • Computer Equipment
"10 minutes install
1. Insert mini-cd (follow prompts)
2. Plug cable into PC only (follow prompts)
3. Plug other end into printer (follow prompts)
4. Make sure your printer is using "USB virtual LPT1" "
Jul 15 2009
Milt
Charlotte, NC
I am:
  • Value Oriented
Reviewed at:
2.0
"Couldn't get the cable to work with my LaserJet HP3P. Tried installing the drivers, but couldn't get it to print. Tried different ports USB 1.1, USB2.0, LP1 etc. Called and sent e-mails to Cables Unlimeted, but they responded 2 weeks later after I gave up on the cable and had already returned. Well …"  Read Full Review »
Mar 31 2009
Undisclosed
Reviewed at:
Price: $14.99
USB to Parallel Printer Cable Very Effective
5.0
"Product Uses:print all my b&w; documents
Review:With the product and the driver disc included, I was able to take my old HP LaserJet 6P and connect it to my new desktop using a USB port. The software creates an additional port 3 that you assign to the printer and you have a fully functioning Oldie …"  Read Full Review »
Oct 14 2009
George1
Matawan, NJ
Reviewed at:
Price: $16.99
The adapter doesn't support Okidata 4W
1.0
    Pros
  • Durable construction
    Cons
  • Limited Compatibility
    Best Uses
  • None
"Required download of required drivers as a CD was not included. Could not get correct operation as bi-directional capability could not be established. "
Apr 23 2009
earlb
connecticut
I am:
  • Quality Oriented
Reviewed at:
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
