Cables Unlimited Spkvelo2 Speakers, Wireless Indoor/outdoor
#914
4.1
based on 8 reviews
Ratings Distribution
5 star
4
4 star
3
3 star
0
2 star
0
1 star
1
Category Average
4.4
$44.99 - $54.99
from 16 stores
More Images
Pros
  • Crisp sound (2)
  • Easy to connect (2)
  • Great sound quality (2)
  • Attractive design (1)
  • Powerful (1)
See less See more
Best Uses
  • Basic systems (2)
  • Outdoors (2)
  • Smaller rooms (1)
Provided by Beach Audio
  • This single add-on wireless speaker is the perfect addition to your current Audio Unlimited wireless speaker system (SPK-VELO-001)
  • With this add-on speaker you can create a multi-room sound system and have the freedom to listen to music just about anywhere in any house or yard without the hassle of running unsightly speaker wires
  • Auto tuning function for interference free reception utilizing Phase Loop Lock (PLL) technology automatically tuning in the optimal frequency
  • 900MHz transmitter sends audio signals without speaker wire (transmitter not included)
  • Speaker can be up to 150 away from the audio source without line of sight limitations
  • Existing systems transmitter connects via 3.5mm audio cable to pcs mp3 players iPods stereos and home theatre systems
  • Size (height width of speaker itself) 130x265mm woofer: 3 rubber edge tweeter: 2 mylar cone output watt rms: 10 watt rms 20 watt max transformer: DC 9V
  • Speaker can either be battery powered (using 6 C cell batteries per speaker - not included) or using the included AC adapter
  • Includes 1-year warranty transformer: DC 9V 1 AC adapter Wall mount with the option to hang speaker from a wall 3.5mm to RCA & 3.5mm to 1 4 adapter iPhone iPod adapter and user manual
  • Specification Description
    Model SPK-VELO2, SPKVELO2
    UPC 724580180401
    Accessory Indicator Yes
    Battery Type Product
    Benefits This single add-on wireless speaker is the perfect addition to your current Audio Unlimited systemWith this add-on speaker you can cr
    Capacity UOM mAh
    Connectivity technology Wireless
    Country Of Origin China
    Description Header Send audio anywhere.
    Display Catalog Number 55029036
    Enclosure Color Black
    End Product Indicator Yes
    Included in the Box Wireless Speaker (1)AC adapterWall mountUser's Manual
    Manufacturer Labor Warranty 12
    Manufacturer Part Number SPK-VELO2
    Manufacturer Parts Warranty 12
    MAP Price 54.99
    Model SPK-VELO2
    Mounting kit included Yes
    Operating Temperature UOM ° F
    Peak power 20 watts
    Power Device AC adapter, 6 "C" batteries
    Product Dimensions UOM inches
    Product Height 10
    Product Type Home speakers
    Product Weight UOM pounds
    Product Width 5
    Required to function SPK-VELO-001 900MHz Wireless Speaker System by Audio Unlimited
    Required to function SKU 55029035
    RMS (continuous) power 10 watts
    Size C
    Speaker type Outdoor
    Speakers included 1
    Supported Languages English
    Tweeter size 2 inches
    Tweeter type Mylar-cone
    Water resistant Yes
    Woofer size 3 inches
    Woofer type Rubber-surround
    Cables Unlimited Spkvelo2 Speakers, Wireless Indoor/outdoor Questions
    Questions and Answers
    Where to Buy
    Product Reviews
    Last update: Nov 9, 2009
    Cables Unlimited Spkvelo2 Speakers, Wireless Indoor/outdoor Reviews
    Displaying 1 - 5 of 8 Reviews
    Show
    Sort by
    Great Speakers
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Basic Systems
    • Outdoors
    • Smaller Rooms
    "I bought the set with transmitter, added 3 more for outdoor and bedroom and now purchasing 2 more to complete my entire 2 bedroom apartment. I got the pink ones for my daughter's room. I recommend these. really easy set up. Open the box & plug them in. Done! "
    Was this Speaker & Subwoofer review on the Cables Unlimited Spkvelo2 Speakers, Wireless Indoor/outdoor helpful to you?
    Nov 9 2009
    Mark
    11561
    I am:
    • Practical
    • Technically Challenged
    Reviewed at:
    Price: $44.99
    Great sound and reception
    5.0
      Pros
    • Crisp Sound
    • Easy To Connect
      Cons
    • None
      Best Uses
    • Basic Systems
    • Outdoors
    "Great sound, easy setup, and great range.
    Setup is as easy as pluging the speaker into the outlet and it finds the transmitter.
    I'm using 3 speakers in a garden suite where we don't get FM reception but the range of the speakers had no problem with placement in any room.
    It's great that you can …"  Read Full Review »
    Oct 29 2009
    gadget_man
    Palatine, IL
    I am:
    • Professional
    Reviewed at:
    Price: $44.99
    You have to realize that ...
    4.0
    "You have to realize that high end wireless speakers are very expensive, these are not. You get what you pay for. I have used these for the past year now and only a few times have had a little static. They sound great on their own but even better as a supplement to my sound system already wired. …"  Read Full Review »
    Oct 22 2009
    MV
    Undisclosed
    Wireless Speakers
    5.0
    "I have been using these for a few months. I used one up on the second floor - no problem. I like the option to select different receivers. Auto scans and uses the best signal (you do need to cycle through each channel until you find a good one). Just plug in and go! SOund is great for radio (I liste …"  Read Full Review »
    Feb 2 2009
    Wrkn4livn
    Maryland
    I HAVE SIX SPEAKERS ...
    4.0
    "I HAVE SIX SPEAKERS SCATTERED THROUGHOUT MY HOME INCLUDING ONE OUTSIDE IN THE GAZEBO. THEY FADE IN AND OUT SOMETIMES BUT OVERALL I AM TOTTALLY SATISFIED WITH THE UNITS. THE STORE'S SERVICES WERE ABOVE AND BEYOND MY EXPECTATIONS. I WILL USE THIS COMPANY AGAIN. "
    Jul 17 2009
    SPEAKERS
    Undisclosed
    pages: 1 2 Next »
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
