C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio
#152
3.3
based on 10 reviews
Ratings Distribution
5 star
2
4 star
4
3 star
1
2 star
1
1 star
2
Category Average
3.9
$44.99 at J&R Electronics
Find it at Amazon
Find it at Ebay
$44.99
from 1 store
Pros
  • Compact (5)
  • Nice sound (5)
  • Clear signal (4)
  • Easy setup (3)
  • 2aa'sfits shirtpocket (1)
  • Accurate controls (1)
  • Battery life excellent (1)
  • Frequency key pad (1)
  • Good size good reception (1)
  • Great-looking unit (1)
See less See more
Cons
  • Confusing / difficult controls (4)
  • Defectivedid not work (1)
  • Not durable (1)
  • Not easy to set up (1)
  • Overloaded by strong fm (1)
  • Poor reception / weak antenna (1)
  • Poor volumn control (1)
  • Somewhat sensitive on sw (1)
  • Sw reception buggy volum (1)
  • Volume control (1)
Best Uses
  • Smaller rooms / apartments (4)
  • Audiophiles (1)
  • Earphones while biking (1)
  • Mostly for outdoors (1)
  • Take everywhere radio (1)
  • Take it anywhere (1)
  • To throw in the garbage (1)
Provided by J&R Electronics
Illuminated Display / 200 Station Memories / Alarm Mode / Requires 2 AA Batteries (not included) for up to 70 hours use / 1 Speaker / Stereo earphone jack
Specification Description
Model SWP
Alarm 1 Alarm
Tuning AM/FM/Shortwave
C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 12, 2009
C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio Reviews
Most helpful positive review
[2 of 2 customers found this review helpful]
Most helpful negative review
4.0
A hit & miss like with all electrons
"Hi,I first bought this item in Sept.of '08. Buttons like that sleeper fowls up radio. After 4 weeks buttons frozed & radio stayed on. I exchanged it [...] Like using it outdoors (NYC)it's a little bigger than my mini sw Grundig,but has more needed bands freq's,from 3.000mhz & up for night listening of US stations like GCN. Has no breaks in band unlike those multi band ones,that's good.Those push buttons are a pa..." Read Full Review »
Apr 16, 2009 by George NYC
See more positive C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio reviews
3.0
A GOOD POCKET RADIO
"I BOUGHT THIS LITTLE RADIO AFTER READING SEVERAL GLOWING ONLINE REVIEWS (INCLUDING THE 2008 PASSPORT TO SHORTWAVE GUIDE)...AFTER OWNING A FEW 5 DOLLAR PORTABLE CHEAPIES, I DECIDED TO FORK OVER 50 BUCKS FOR A PREMIUM PORTABLE. HERE ARE MY CONCLUSIONS AFTER 6 MONTHS OF OWNERSHIP: GOOD: 1. AM RECEPTION IS GOOD FOR IT'S SIZE 2. FM IS EQUALLY GOOD 3. BUILD QUALITY SO FAR IS DURABLE 4. PICTURES DO NOT DO JUSTICE, THI..." Read Full Review »
Oct 13, 2008 by JEMEMIAH
See more negative C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio reviews
Displaying 1 - 5 of 10 Reviews
Show
Sort by
4.0
    Pros
  • Compact
  • Good Sound
    Cons
  • Difficult Controls
  • Somewhat sensitive on SW
    Best Uses
  • Smaller Rooms
"Hi,I first bought this item in Sept.of '08. Buttons like that sleeper fowls up radio. After 4 weeks buttons frozed & radio stayed on. I exchanged it [...] Like using it outdoors (NYC)it's a little bigger than my mini sw Grundig,but has more needed bands freq's,from 3.000mhz & up for night listening …"  Read Full Review »
Was this Radio review on the C Crane And Company CCRadio SWP AM/FM Shortwave Pocket Radio helpful to you?
 Report Abuse  (2)  (0)  0 comments
Apr 16 2009
George NYC
Manhattan,Nyc
I am:
  • Practical
Reviewed at:
Price: $44.99
Nice, but Fussy!
4.0
    Pros
  • 2AA'sfits shirtpocket
  • Clear Signal
  • Compact
  • Good Sound
  • ShortwaveDXLocal alarm
    Cons
    Best Uses
  • Smaller Rooms
"Difficult logic in programming or retrieving frequencies. CCRANE Company very helpful to explain functioning before I returned unit. Small, but powerful unit! An excellent travel radio!!!
Volume is supposed to work in two ways, but mine only worked one way: J and R immediately accepted my return an …"  Read Full Review »
Feb 28 2009
Rattlebone
San Jose, CA
I am:
  • Antagonistic
  • Musically Inclined
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Price: $44.99
[1 of 1 customers found this review helpful]
WOW! What A Great Little Radio!
5.0
    Pros
  • Battery Life Excellent
  • Clear Signal
  • Compact
  • Frequency Key Pad
  • Good Sound
  • More »
    Cons
  • Volume Control
    Best Uses
  • Take it anywhere
"I have always been a big fan of C Crane products. They have been committed to high-quality radio products for a long time.
Since I already owned a CCRadio-Plus, which I have been very pleased with, I decided to order the CCRadio-SWP pocket radio. What a pleasant surprise! This is the most incredibl …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
May 23 2009
Hudson A.
Franklin, TN
I am:
  • Audiophile
  • Life-long Radio Fanatic
  • Practical
Reviewed at:
Price: $44.99
A GOOD POCKET RADIO
3.0
    Pros
  • GOOD SIZE GOOD RECEPTION
    Cons
  • SW RECEPTION BUGGY VOLUM
    Best Uses
  • None
GOOD:
1. AM RECEP …"  Read Full Review »
Oct 13 2008
JEMEMIAH
CA
I am:
  • Practical
[8 of 14 customers found this review helpful]
Disaster!
1.0
    Pros
  • None
    Cons
  • Not Durable
    Best Uses
"My experience was a disaster. The first version of the radio that i received could not be dialed to any AM stations and was unprogrammable. I returned it [...]. The second one was no better. Total garbage and not as you advertised in the NY Times. I just tossed it in the trash where it belonged …"  Read Full Review »
 Report Abuse  (8)  (6)  0 comments
Jun 18 2008
Steven Zwerling
New York City
I am:
  • Practical
Reviewed at:
Price: $44.99
pages: 1 2 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
