Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit
#103
4.2
based on 13 reviews
Ratings Distribution
5 star
6
4 star
4
3 star
1
2 star
0
1 star
1
Category Average
3.6
$10.27 - $29.99
from 9 stores
More Images
Pros
  • Versatile (5)
  • Durable (4)
  • Easy to install (2)
  • Easy to use (2)
  • Good value (2)
  • High quality (2)
  • Lightweight (2)
  • Simple / intuitive controls (1)
See less See more
Cons
  • Hard to install (1)
  • Poor design (1)
  • Taller flex would be ok (1)
Best Uses
  • Chevy hhr (1)
  • Good for commuting (1)
  • Larger cars (1)
  • Small cars (1)
  • Travel (1)
Provided by OuterBanksOutfitters.com
  • Compatible with most MP3 players, all cellular phones, many GPS and satellite radios in today's mobile electronics market.
  • Mounts to varying sizes of cupholders in your vehicle and keeps your mobile device secure.
  • Adjustable wings open up to 4-1/2" and can accommodate many other mobile devices, such as cell phones and MP3 players.
  • Easy-to-install design allows mount to be moved from vehicle to vehicle with ease.
The Mobile Dock-iT Cup Holder Mount easily installs into the vehicles cup holder providing a stable, secure and easily accessible mounting solution for your portable devices.
Included is the Mobile Grip-iT Device Holder which features arms that open up to 4 1/2 inches and also adjust up or down, allowing you to custom configure it to your particular device and full access to all buttons and functions.
Specification Description
Model UCH-100, UCH-100-BL, UCH-100BL, UCH100BL
UPC 874688000252
Accessory Indicator Yes
Benefits Compatible with most MP3 players, wireless phones, GPS units and satellite radiosExpands to varying sizes of cupholders in your vehic
Capacity UOM mAh
Country Of Origin China
Description Header For easy accessibility.
Display Catalog Number 55033909
Manufacturer Labor Warranty 12
Manufacturer Part Number UCH-100-BL
Manufacturer Parts Warranty 12
MAP Price 19.95
Model UCH-100BL
Operating Temperature UOM ° F
Product Dimensions UOM inches
Product Type Mounts
Product Weight UOM pounds
Supported Languages English
Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: May 26, 2009
Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit Reviews
Most helpful positive review
Most helpful negative review
[0 of 1 customers found this review helpful]
4.0
Good product
"Works well for me. I use it for my portable navigation device. I tried a similar Belkin product but I could not use it because I could not rotate the mount to a "landscape" position. The mount on the Bracketron can be rotated to both positions and it holds my device well. The device is well made and looks like it can fit anybody's needs......" Read Full Review »
Dec 15, 2007 by GPS Device User
See more positive Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit reviews
1.0
Nice Idea But It Doesn't Work
"The TomTom XL GPS has rounded, thin edges, so the top bracket didn't hold the TomTom XL in place very well. Also the TomTom XL is a little too large for the upper bracket. The upper bracket would probably be fine for a smaller GPS. At the other end, the piece that goes into a cup holder doesn't fit into the cup holders on a Honda CRV very well. The holder might work if it had more of an angle, like a real trav..." Read Full Review »
Nov 13, 2008 by Aldo
See more negative Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit reviews
Displaying 1 - 5 of 13 Reviews
Show
Sort by
1.0
    Pros
  • Easy Controls
    Cons
  • Poor Design
    Best Uses
  • None
"The TomTom XL GPS has rounded, thin edges, so the top bracket didn't hold the TomTom XL in place very well. Also the TomTom XL is a little too large for the upper bracket. The upper bracket would probably be fine for a smaller GPS. At the other end, the piece that goes into a cup holder doesn't fit …"  Read Full Review »
Was this Cell Phone Accessory review on the Bracketron Mobile Dock-iT Universal Cup Holder Mount Kit helpful to you?
 Report Abuse  (0)  (1)  0 comments
Nov 13 2008
Aldo
Boston, MA
I am:
  • Gearhead
[1 of 1 customers found this review helpful]
Mobile Dock-It works - most of the way
3.0
    Pros
  • Versatile
    Cons
  • Difficult To Install
    Best Uses
  • None
"Use this to place my BlackBerry and personal mobile phone at a convenient position while driving.
The cradle mechanism is excellent and easy to adjust for differing phone sizes. However, it is hard to get the base to sit securely in a cup holder. Tried it on two cars with the same result. I wa …"  Read Full Review »
 Report Abuse  (1)  (0)  0 comments
Jul 22 2008
Monk
Illinois
I am:
  • Gearhead
Reviewed at:
Good product
4.0
    Pros
  • Durable
  • Good Value
  • High Quality
    Cons
  • None
    Best Uses
  • None
"Works well for me. I use it for my portable navigation device. I tried a similar Belkin product but I could not use it because I could not rotate the mount to a "landscape" position. The mount on the Bracketron can be rotated to both positions and it holds my device well. The device is well made and …"  Read Full Review »
Dec 15 2007
GPS Device User
Huntington Beach, CA
Reviewed at:
bracketron uch-100bl
4.0
    Pros
  • Lightweight
  • Versatile
    Cons
  • None
    Best Uses
  • Commuting
  • Travel
"This bracket is just what i was looking for for my zune instalation in my car. It should also be great for other devices.Price is great. The thing is really well designed at a low price "
Nov 6 2008
ksteadford
arlington hts. IL
I am:
  • Parent
  • Practical
Reviewed at:
Interesting product
4.0
    Pros
  • Easy to Install
  • Easy To Use
  • Versatile
    Cons
    Best Uses
  • Chevy HHR
"Nice product for a reasonable price. Very flexible as far as supporting different devices. Can't say anything on reliability as I just got mine. An option for a longer neck would be cool. "
Mar 21 2008
StateOfWail
Portland, OR
I am:
  • Engineer
  • Musician
Reviewed at:
pages: 1 2 3 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
