Boston Acoustics XB6 12-inch 200-watt Powered Subwoofer
#639
4.3
based on 3 reviews
Ratings Distribution
5 star
1
4 star
2
3 star
0
2 star
0
1 star
0
Category Average
4.4
$298.88 at OneCall
Find it at Amazon
Find it at Ebay
$298.88
from 1 store
Pros
  • Great sound quality (3)
  • Powerful (3)
  • Attractive design (2)
  • Compact (2)
  • Easy to connect (1)
See less See more
Best Uses
  • Basic systems (2)
  • Larger rooms (2)
  • Smaller rooms (2)
  • Audiophiles (1)
Provided by OneCall
The XB6 powered subwoofer features a large 12-inch Deep Channel woofer, BassTrac circuitry, and powerful amplifier in a vented enclosure. The XB6 has a FTC-rated 200-watt amplifier. The XB6 has a frequency response (+/-3dB) of 29Hz-150Hz respectively. The volume control is mounted on top of the cabinet, flush with the surface, so the top remains perfectly flat.
All XB Subwoofers deliver The Boston Sound; the sound the artist intended. Pure, natural, true-to-the-original performance(R).
Boston Acoustics' new XB Subwoofers offer a clean,contemporary style that is visually more compatible with modern interiors. New style elements include a lower,slightly wider footprint,gently rounded corners, metal grilles, and flush-mounted volume controls on top of the XB8,XB6,and XB4.All are available in black ash.All four are front-firing, front-ported, and very easy to install. The XB subwoofers are equipped with Deep Channel(TM) woofers that deliver extended excursion with increased bass response, and Boston`s exclusive BassTrac circuitry, designed to eliminate distortion. A 24dB/octave lowpass filter on each subwoofer prevents it from being easily localized by ear, increasing placement flexibility. Also provided are variable crossovers, phase controls, rear-panel line and speaker level inputs, and a crossover bypass function for Home Theater components that perform their own bass management.
Specification Description
Model XB6
UPC 690283390907
Amplifier 200 Watts
Auto Power On/Off Yes
Depth (Inches) 13.94
Frequency Response 29Hz-150Hz
Height (Inches) 13.75
Line Level (2) Rear Input
Speaker Level Inputs Rear Input
Weight (Pounds) 28
Width (Inches) 15.55
Woofer Size (Inches) 12
Boston Acoustics XB6 12-inch 200-watt Powered Subwoofer Questions
Questions and Answers
Where to Buy
$298.88
BizRate Rating Outstanding 9.1
Product Reviews
Last update: Sep 26, 2008
Boston Acoustics XB6 12-inch 200-watt Powered Subwoofer Reviews
Displaying 1 - 3 of 3 Reviews
Show
Sort by
4.0
    Pros
  • Compact
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Smaller Rooms
"I'm very happy with finding a 12 inch sub in this size, this unit replaced a 10 inch basscube and fits in the same compact space that the basscube did.
It performs very well though I feel much like my other subwoofer it is handicapped by the fact that it is positioned in a basement with a con …"  Read Full Review »
Was this Speaker & Subwoofer review on the Boston Acoustics XB6 12-inch 200-watt Powered Subwoofer helpful to you?
Sep 19 2008
Joe
Braintree, MA
I am:
  • Tech Savvy
Reviewed at:
Price: $298.88
This thing has great punch.
4.0
    Pros
  • Attractive Design
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"This Poered Sub has great sound for the money. "
Aug 30 2008
Tim
Butler, PA
I am:
  • Tech Savvy
Reviewed at:
Price: $298.88
Great Value!
5.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Larger Rooms
"Easy - great performance "
Sep 26 2008
Farting
Dallas TX
I am:
  • Audiophile
Reviewed at:
Price: $298.88
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
