Boston Acoustics VS 240PF (Ea.) 2-Way 4-1/2 inch Bookshelf Loudspeaker
#727
4.0
based on 2 reviews
Ratings Distribution
5 star
1
4 star
0
3 star
1
2 star
0
1 star
0
Category Average
4.4
$399.00 at OneCall
Find it at Amazon
Find it at Ebay
$399.00
from 1 store
Pros
  • Attractive design (2)
  • Easy to connect (2)
  • Great sound quality (2)
  • Compact (1)
  • Powerful (1)
See less See more
Best Uses
  • Home theater (1)
  • Smaller rooms / apartments (1)
Provided by OneCall
Great sound has a whole new look
Introducing Boston Vista Series Loudspeakers–our best performing, best-looking products. Vista delivers a home theater or audio-only experience. Innovative driver and cabinet designs yield exceptional sonic characteristics.
Each Vista Series model is voiced to blend with the others so they can be combined to deliver the best performance in any configuration. Dispelling all notions of the typical loudspeaker rectangular box, Vista Series models all feature elegant piano lacquer finish cabinets and high-gloss furniture-grade end panels. And further reflecting the seamless merging of art and science that defines Vista, the structural elements of the cabinets are made of high-frequency-molded MDF with wave like curved surfaces that reduce internal standing waves and panel resonances. Additionally, substantial internal bracing enhances the strength of the cabinets to provide an ideal environment for high-performance sound.
  • Super Wide Bandwidth (SWB) Tweeter featuring a Coupled Dual Concentric-Diaphragm (CDCD) minimizes phase shift and distortion while improving pistonic motion. (except VPS 210)
  • Organic Composite Cone Material (OCCM) was developed using a mix of select natural fibers to reduce resonance and improve accuracy.
  • High-frequency-molded MDF cabinet features curved surfaces, which reduce internal standing waves and panel resonances.
  • MagnaGuard(R) video shielding
  • Gold-plated 5-way binding posts
  • Elegant lacquer piano finish cabinet
  • High-gloss multi-layer furniture-grade end panels
  • Specification Description
    Model VS240PF
    UPC 690283474843
    Crossover Frequency 2,000Hz
    Depth (Inches) 6.4
    Frequency Response 70Hz?30kHz
    Height (Inches) 9.4
    Impedance 8 ohms
    Magnetic Shielding Yes
    Sensitivity 86dB
    Speaker Type 2-Way
    Speaker Type Bookshelf Speaker
    Weight (Pounds) 6.3
    Width (Inches) 5.9
    Boston Acoustics VS 240PF (Ea.) 2-Way 4-1/2 inch Bookshelf Loudspeaker Questions
    Questions and Answers
    Where to Buy
    $399.00
    BizRate Rating Outstanding 9.1
    Product Reviews
    Last update: Jan 29, 2009
    Boston Acoustics VS 240PF (Ea.) 2-Way 4-1/2 inch Bookshelf Loudspeaker Reviews
    Displaying 1 - 2 of 2 Reviews
    Show
    Sort by
    Good price great sound
    5.0
      Pros
    • Attractive Design
    • Crisp Sound
    • Easy To Connect
    • Great Sound Quality
    • Powerful
      Cons
    • None
      Best Uses
    • Home Theater
    "Awsome sound for my home theater "
    Was this Speaker & Subwoofer review on the Boston Acoustics VS 240PF (Ea.) 2-Way 4-1/2 inch Bookshelf Loudspeaker helpful to you?
    Jan 29 2009
    Xracer
    Western PA.
    I am:
    • Audiophile
    Reviewed at:
    Price: $399.00
    Good small speakerCompact and good looki
    3.0
      Pros
    • Attractive Design
    • Compact
    • Easy To Connect
      Cons
    • None
      Best Uses
    • Smaller Rooms
    "compact and good looking "
    Nov 1 2008
    Jack
    Concord, CA
    I am:
    • Audiophile
    Reviewed at:
    Price: $399.00
    Email Address: (required)
    Comments:
    or Cancel
    Where to Buy
    Selling products online?
    Engage, Connect, and Sell.
    www.powerreviews.com
    Close Login Module
    Join
