Close Login Module
Join
Boston Acoustics Horizon HPS 12HO Powered Subwoofer
#938
4.3
based on 66 reviews
Ratings Distribution
5 star
35
4 star
23
3 star
4
2 star
1
1 star
3
Category Average
4.4
$199.88 - $499.00
from 3 stores
More Images
Pros
  • Easy to connect (54)
  • Great sound quality (48)
  • Attractive design (39)
  • Powerful (37)
  • Crisp sound (29)
  • Powerful bass (13)
  • Compact (2)
  • Affordable (1)
  • Can buy custom grille cov (1)
  • Decent sound quality (1)
See less See more
Cons
  • Heavy (6)
  • Poor sound quality (5)
  • Not very powerful (4)
  • Distorted sound (2)
  • Average sound (1)
  • Better with films (1)
  • Good for price (1)
  • Medium rooms (1)
  • Mist color (1)
  • Muddy (1)
Best Uses
  • Home theater (52)
  • Basic systems (24)
  • Smaller rooms (10)
  • Larger rooms (7)
  • Audiophiles (4)
  • Audiophile system (1)
  • Good 400sq ft room (1)
  • Holding open doors (1)
  • Home theater polk mseries (1)
  • Movies and music (1)
Where to Buy
BizRate Rating Outstanding 9.1
$199.88
$360.00
$499.00
Product Reviews
Last update: Oct 15, 2009
Boston Acoustics Horizon HPS 12HO Powered Subwoofer Reviews
Most helpful positive review
Most helpful negative review
5.0
Amazing subwoofer for the price!
"This is such a great sub. I have had prior experience with Boston Acoustics since I also own the smaller HPS-10HO. I decided to either go with the Klipsch SUB-10, SUB-12, or the Boston Acoustics HPS-12HO for my main room setup. The Boston Acoustics HPS-12HO was the best price so I decided to go with that since I've already know what it could sound like. This is such a great subwoofer. At any volume level, t..." Read Full Review »
Jan 02, 2009 by PootieThang
See more positive Boston Acoustics Horizon HPS 12HO Powered Subwoofer reviews
3.0
Good for the price
"I have this paired with an onkyo 805, ps3 and samsung 1500 blu ray player, sharp aq 46 1080p 120hz this its an 85 serires, and klipsch quintet III's. The sound is somewhat muddy from the subwoofer if that can be understood. I was looking at a velodyne but could not get it, so i chose this based on good reviews. I am satified, but wish it was not so muddy. Music i don use my home theater for music. I do get a rum..." Read Full Review »
Jan 16, 2009 by If its not 1080p its not for me.
See more negative Boston Acoustics Horizon HPS 12HO Powered Subwoofer reviews
Displaying 1 - 5 of 66 Reviews
Show
Sort by
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
  • Powerful
    Cons
  • None
    Best Uses
  • Home Theater
  • Larger Rooms
  • Smaller Rooms
"This is such a great sub. I have had prior experience with Boston Acoustics since I also own the smaller HPS-10HO. I decided to either go with the Klipsch SUB-10, SUB-12, or the Boston Acoustics HPS-12HO for my main room setup. The Boston Acoustics HPS-12HO was the best price so I decided to go w …"  Read Full Review »
Here's the subwoofer on the floor
  • Picture of Product
The subwoofer connected to my Onkyo TX-SR806
  • Using Product
Was this Speaker & Subwoofer review on the Boston Acoustics helpful to you?
Jan 2 2009
PootieThang
Denver, CO
I am:
  • Tech Savvy
Reviewed at:
Price: $199.88
[3 of 3 customers found this review helpful]
What no base! I don't think so!
4.0
    Pros
  • Easy To Connect
  • Powerful
    Cons
  • Heavy
    Best Uses
  • Home Theater
"I own the Black version of this product and don't know what the previous reviewer is talking about. this sub, WHEN PROPERLY adjusted can produce deep,loud,tight base as good as anything in its price range. Will it outperform a Velodyne 12", maybe not but it is more 'musical' than the Velodyne and eq …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
Mar 9 2009
cnh
Augusta, Me
I am:
  • Audiophile
Reviewed at:
Price: $199.88
Great for Movies, good with music!
4.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
  • Powerful Bass
    Cons
  • Better with films
    Best Uses
"Bought this sub from Onecall at a great price [...].To the author below. There must be something WRONG with your sub. The HPS12HO provides deep clean powerful bass when and if the soundtrack actually has such bass in it. It's not a car boombox! And everything one plays does not always have a heavy b …"  Read Full Review »
Jan 16 2009
C-
New England
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Price: $199.88
A Valuable Beast!
5.0
    Pros
  • Crisp Sound
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
"I have two of these hooked up to an Onkyo tx-sr707 with 7.2. I don't really need more than one of these subs,because of the amt of bass just one can offer. But if you have 7.2 then why not right! I got the white one because it was 200 bucks cheaper than the black. @ [$] I feel like I owe ONECALL an …"  Read Full Review »
Oct 5 2009
Flirn
Springfield,Mo.
I am:
  • Guy who likes nice things
Reviewed at:
Price: $199.88
Great for Movies, Good for Music
4.0
    Pros
  • Easy To Connect
  • Good controlled bass
  • Powerful Bass
    Cons
  • Placement sensitive some
    Best Uses
  • Audiophiles
  • Home Theater Polk Mseries
"This review is to respond to a few below and also provide the buyer with more technical info that I have received from Boston Acoustics.[...]this sub is more than adequate for most Home Theater LFE (effects). Strong quick bass and quick decay recovery of sound that is fairly accurate and true. Very …"  Read Full Review »
Jan 20 2009
The Audio Don
central, Maine
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $199.88
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$199.88
$360.00
$499.00
Out Of Stock
BizRate Rating Outstanding 9.3
$229.99
$279.99
Overstock.com Club O Deals!
$399.00
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
