Boston Acoustics Horizon Duo-i AM/FM Stereo Radio
#6
4.3
based on 59 reviews
Ratings Distribution
5 star
36
4 star
13
3 star
3
2 star
4
1 star
3
Category Average
3.9
$169.00 - $199.99
from 7 stores
Pros
  • Easy setup (32)
  • Nice sound (23)
  • Accurate controls (20)
  • Clear signal (19)
  • Compact (12)
  • Quality construction (10)
  • Good interface (8)
  • Reliable reception (8)
  • Durable (6)
  • Great sound (4)
See less See more
Cons
  • Bulky (6)
  • 2nd gen itouch issues (1)
  • Confusing / difficult controls (1)
  • Difficult to see (1)
  • Ipod-synced music distort (1)
  • Needs a carry handle (1)
  • No equalizer (1)
  • No instructions (1)
  • No usb port (1)
  • Not portable need handle (1)
Best Uses
  • Home (20)
  • Smaller rooms (20)
  • Office (15)
  • Audiophiles (14)
  • Basic systems (6)
  • Larger rooms (5)
  • Basic use (2)
  • Den (1)
  • Den or bedroom (1)
  • Dormitory (1)
Provided by B&H Photo Video
Duo-i Horizon AM/FM Stereo Radio with iPod Dock (Midnight)
Specification Description
Model BSNHDUIM, DUO-I, HDUOIMDNT, HDUOIMIST
UPC 690283471965
Alarm Dual
Alarm Snooze
Analog Audio Rear Output
color Midnight
Depth (Inches) 8
Headphone Jack Rear Output
Height (Inches) 5.5
iPod Dock Connector Top Input
Line In (2) Rear Input
Line In Rear Input
MP3 Player Dock for optional iPod
Presets 10 FM / 5 AM
Remote Control Included
size null
sku 147034 MIDNIGHT
skuprice 199.9900
Sleep Timer Yes
Speakers Built-in
style BSNHDUIM
taxable Y
Tuner AM
Tuner FM
Tuning AM/FM
Video Output Yes
Weight (Pounds) 8.2
Width (Inches) 12.9
Boston Acoustics Horizon Duo-i AM/FM Stereo Radio Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Nov 14, 2009
Boston Acoustics Horizon Duo-i AM/FM Stereo Radio Reviews
Most helpful positive review
[4 of 4 customers found this review helpful]
Most helpful negative review
4.0
Excellent Audio Quality
"As I said in my analysis of the product. Overall it is a very good product for those who want excellent sound. I had compared the best alarm clock units of Sony, IHome, Logitech, JVC and Philips for their sound quality. Now when it came to multifunctional uses the Philips Philips DCM230 took honors because it also had a USB-port that allows for larger hard drive scalability. But it lacked in sound quality and no..." Read Full Review »
Dec 16, 2008 by Steven the Audio Specialist
See more positive Boston Acoustics Horizon Duo-i AM/FM Stereo Radio reviews
3.0
Excellent Sound - ipod dock weak
"Great sound quality, radio reception, styling and user interface. Runs too hot for my liking in just standby mode. Let down by a faulty ipod docking connector and no mechanical support to the ipod itself. A curious but obvious oversight is that it doesn't display the time when the radio is on? Also found the entire display was backlit (blue) and quite bright which was annoying at night when one is trying to redu..." Read Full Review »
Nov 14, 2009 by Johny
See more negative Boston Acoustics Horizon Duo-i AM/FM Stereo Radio reviews
Displaying 1 - 5 of 59 Reviews
Show
Sort by
4.0
    Pros
  • Deep Bass
  • Dynamic Range of sound
  • Good Stereo Separation
  • Low distortion High level
  • MultiFunc Ipod Radio Aux
    Cons
  • No Equalizer
  • No USB Port
  • Not Portable need handle
    Best Uses
  • Home
"As I said in my analysis of the product. Overall it is a very good product for those who want excellent sound. I had compared the best alarm clock units of Sony, IHome, Logitech, JVC and Philips for their sound quality. Now when it came to multifunctional uses the Philips Philips DCM230 took honors …"  Read Full Review »
Was this Radio review on the Boston Acoustics Horizon Duo-i AM/FM Stereo Radio helpful to you?
 Report Abuse  (4)  (0)  0 comments
Dec 16 2008
Pennsylvania
I am:
  • Audiophile
  • Electronic Technician
Reviewed at:
[6 of 6 customers found this review helpful]
Fantastic Sound Option
5.0
    Pros
  • Good interface
  • Reliable Reception
  • Strong Construction
    Cons
  • None
    Best Uses
  • Home
  • Office
"Impressive unit. Clear, crisp sound. Intuitive controls. Well-made and beefy. (My cat will never knock this off the night stand.) Perfect mate for the Ipod. Handy dandy remote. Have heard other Ipod speaker docking units and none can hold a candle to this. If you're considering buying one, sp …"  Read Full Review »
 Report Abuse  (6)  (0)  0 comments
Jan 8 2009
Local Dog
North Florida
Reviewed at:
Price: $195.00
3.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Excellent sound
  • Great interface
    Cons
  • Runs hot
  • Won't display time freq
    Best Uses
  • Audiophiles
"Great sound quality, radio reception, styling and user interface. Runs too hot for my liking in just standby mode. Let down by a faulty ipod docking connector and no mechanical support to the ipod itself. A curious but obvious oversight is that it doesn't display the time when the radio is on? Also …"  Read Full Review »
Nov 14 2009
Johny
Manhattan New York
I am:
  • Audiophile
  • Tech Savvy
Reviewed at:
Price: $199.99
Excellent build quality, best sound ever
5.0
    Pros
  • Accurate Controls
  • Clear Signal
  • Compact
  • Easy To Set Up
  • Good Sound
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"Easy to set up. Logical and intuitive controls.Great looks and the alarm shut-off bar is a stroke of genius. The best of course is the superb sound,rich and highly detailed. Don't think you can do better. Highly recommended. "
Nov 10 2009
ronman
kcmo
I am:
  • Audiophile
  • Practical
  • Professional
  • Tech Savvy
Reviewed at:
Very good audio, high quality look/feel
5.0
    Pros
  • Good interface
    Cons
  • Track selection with knob
    Best Uses
  • Den
  • Home
  • Kitchen
  • Office
"Use for both radio and iPod. AM/FM reception on par with previous unit used in same location (iHome product). Wish it were better, but it seems like a bad location for good reception.
Fwd/reverse track skipping using a knob is a little bit finicky since every little click/detent skips one track. …"  Read Full Review »
Feb 2 2009
772D
Utah
I am:
  • Gear Head
  • Mechanical engineer
Reviewed at:
Price: $195.00
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
