Boston Acoustics BRAVO White (Ea) 2-Way Bookshelf Loudspeaker
4.0
based on 1 review
Ratings Distribution
5 star
0
4 star
1
3 star
0
2 star
0
1 star
0
Category Average
4.4
Pros
  • Attractive design (1)
  • Crisp sound (1)
  • Easy to connect (1)
  • Great sound quality (1)
See less See more
Best Uses
  • Home theater (1)
  • Smaller rooms (1)
Provided by OneCall
The Boston Bravo™ is a multi-purpose, high performance compact loudspeaker. The Boston Bravo, which uses Boston’s patented one-inch aluminum dome VR tweeter with AMD and a 41/2-inch woofer, can be combined with its supplied mounting bracket or rear stand to be mounted or placed virtually anywhere in any room.
The Boston Bravo is essentially one-quarter of a cylinder, allowing it to be mounted vertically at any height in a corner, or horizontally at the top of a wall, where wall and ceiling meet. Attaching the Boston Bravo to any surface is as simple as mounting the bracket to the wall, removing the grille from the speaker, and then attaching the speaker to the bracket using the supplied screws. Once the grille is placed back on the speaker, the means of attachment becomes virtually invisible. Additionally, the Boston Bravo can be placed either horizontally or vertically on any flat surface, such as a table or a shelf. Horizontally, it can either angle upward by resting on its two corner fillers or sit untilted using the rear stand.
By virtue of its patented VR tweeter, the Boston Bravo is an economical and appropriate choice as a surround speaker for any Boston system using similarly equipped main and center channel speakers: VR-M50, 60, 80, 90 and VR-MC; VR940, 950, 965, 975, 910 and 920; MR90x, 100x and 90c. However, since it shares the Boston Sound™ with all other Boston speakers, the Boston Bravo can be used successfully as a surround speaker with any Boston main and center channel speakers. The Boston Bravo can also be used in conjunction with any of today’s widely available quality loudspeaker brands.
Because it is designed as a high-performance, general-purpose speaker, the Boston Bravo is suitable for any high-fidelity application where it is important that the speaker blends into its surroundings. The Boston Bravo is well suited for background and whole house music applications. The Boston Bravo’s highly flexible mounting bracket allows it to be placed in
a wide variety of locations, and to for the speaker to be angled for optimum sound quality and three-dimensional imaging. When a pair is placed vertically in the corners of a room, the Boston Bravo creates an unusually wide listening window, providing true stereo sound reproduction over a broad area.
For full-range applications, it is recommended that the Boston Bravo be used in conjunction with one of Boston’s powered subwoofers. The Boston Bravo’s low frequency limit is 80Hz, allowing for a great deal of placement flexibility for the subwoofer. The Boston Bravo’s robust design allows it be used with full-range signals and amplifiers rated between 15 and 125 watts. Please note that the Boston Bravo is not magnetically shielded. Therefore, it
should not be placed closer than 18 inches from a tube television. The Boston Bravo may be used safely near projection and plasma televisions.
Specification Description
UPC 690283214081
Color White
Crossover Frequency 2.5kHz
Depth (Inches) 4.38
Frequency Response 80Hz-20kHz
Height (Inches) 6.5
Impedance 8 ohms
Sensitivity 89dB
Speaker Terminals 5-Way Binding Post
Speaker Type 2-Way
Speaker Type Center Channel
Tweeter Size (Inches) 1
Weight (Pounds) 5.5
Width (Inches) 14.38
Woofer Size (Inches) 4.5
Boston Acoustics BRAVO White (Ea) 2-Way Bookshelf Loudspeaker Questions
Questions and Answers
Where to Buy
Amazon   at Amazon.com
ebay
eBay listings for: BRAVO White (Ea) 2-Way Bookshelf Loudspeaker
See all eBay results
  at eBay.com
Product Reviews
Last update: May 12, 2009
Boston Acoustics BRAVO White (Ea) 2-Way Bookshelf Loudspeaker Reviews
Displaying 1 - 1 of 1 Reviews
Show
Sort by
Sound fine to me
4.0
    Pros
  • Attractive Design
  • Crisp Sound
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Home Theater
  • Smaller Rooms
"These have a great shape for fitting in corners, and they're easy to install on a wall. They sound fine. I don't have anything to compare them to. It's nice to have surround sound. "
Was this Speaker & Subwoofer review on the Boston Acoustics BRAVO White (Ea) 2-Way Bookshelf Loudspeaker helpful to you?
May 12 2009
Andrew
Cambridge, MA
I am:
  • Musically Inclined
  • Tech Savvy
Reviewed at:
Email Address: (required)
Comments:
or Cancel
Where to Buy
ebay
  at eBay.com
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
