#2
based on 46 reviews
Ratings Distribution
| 5 star |
38 |
| 4 star |
7 |
| 3 star |
1 |
| 2 star |
0 |
| 1 star |
0 |
Category Average
$14.99
from 1 storePros
Cons
Best Uses
Where to Buy
BizRate Rating
Outstanding 9.4
Product Reviews
"I bought the Bose Sounddock used and it was lacking the remote. Once I ordered a remote, I was no longer "tethered" to the sounddock just to adjust the volume or put the iPod on pause. However, the remote lacks is the ability to access the iPod menu. There is no way (from across the room) to change playlists or anything else on the iPod's menu. So, one still has to go directly up to the sounddock to make cha..." Read Full Review »
Apr 13, 2009 by Nancy T.
"[...] battery was dead. When I replaced the battery it worked fine...." Read Full Review »
Jan 12, 2009 by Brooklyn gal
Displaying 1 - 5 of 46 Reviews
Bose SoundDock Replacement Remote Review
Pros
Cons
Best Uses
"I bought the Bose Sounddock used and it was lacking the remote. Once I ordered a remote, I was no longer "tethered" to the sounddock just to adjust the volume or put the iPod on pause. However, the remote lacks is the ability to access the iPod menu. There is no way (from across the room) to chan …" Read Full Review »
Pros
Cons
Best Uses
"Used product as replacement for original. Hope this one doesn't go bad also.
Good: Small as a credit card, raised buttons, simple design
Not so good: Needs more features. Only does play (on), pause, stop (off)fast forward and reverse. Would like to see ability to go to Ipod menu or playlists.
Pros
Cons
Best Uses
"My dog chewed up my previous Sound Dock remote control (imagine a 2 year old Rottweiler chewing up this little buddy), and amazingly it still worked, but it looked horrible. So I decided to look up for a replacement for it. I love this little remote, it´s so intuitive, so easy to use. It allows you …" Read Full Review »
Pros
Cons
Best Uses
"I use this everyday on my sounddock. My old remote broke so I purchased this as a replacement. It worked perfect. I pulled it out of the box and didnt have to set anything up. It worked immediately. I love the design. The only bad thing about it is that you cant skip playlist. "
Pros
Cons
Best Uses
"great distance range on this remote. Smart design for use around moisture and pool. Quality built ,but easy to loose because of its small size. Attach to main unit with a velcro strip to keep it from being lost. "
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.comPrices, inventory, and product information are provided by the merchants and may include any promotional discounts that are not available to all customers. We assume no responsibility for accuracy of price information provided by merchants, but please price_alerts|snabela|powerreviews.com to any pricing discrepancies so we can notify the merchant. Additionally, sales taxes and shipping costs are not included in listed prices, so please check with the merchant for total costs.
Powered by PowerReviews, Inc. ©2009 All Rights Reserved
