Close Login Module
Join
Bose SL2 Wireless Surround Link
#20
4.7
based on 20 reviews
Ratings Distribution
5 star
14
4 star
5
3 star
1
2 star
0
1 star
0
Category Average
4.1
$224.00 - $249.00
from 6 stores
More Images
Pros
  • Consistent performance (8)
  • Compact (6)
  • Easy setup (6)
  • Attractive design (5)
  • Clear sound (4)
  • Great sound (4)
  • Easy to connect (2)
  • Easy to use (2)
  • Great sound quality (2)
  • High quality (2)
See less See more
Cons
  • Just needs a power source (1)
Best Uses
  • High-end equipment (5)
  • Entertainment (2)
  • Home (2)
  • Larger rooms (2)
  • Living room (2)
  • Any home theater (1)
  • Basic systems (1)
  • Bose speakers (1)
  • Dorm room (1)
  • Home theater (1)
Where to Buy
BizRate Rating Outstanding 9.3
$224.00
BizRate Rating Outstanding 9.1
$224.00
$224.00
Show all 6 stores
Product Reviews
Last update: Aug 23, 2009
Bose SL2 Wireless Surround Link Reviews
Most helpful positive review
[6 of 9 customers found this review helpful]
Most helpful negative review
[1 of 1 customers found this review helpful]
4.0
Not totally wireless...
"I got excited when I saw "Wireless" surround sound, so the assumption was mine that it would be totally wireless. It's not. You still have to connect speaker wires to the Receiver unit and then out to the surround speakers. The only difference is no wires are run from the front base unit to the rear surround speakers, but you still have to hide the wires in the back...." Read Full Review »
Aug 26, 2008 by Yui
See more positive Bose SL2 Wireless Surround Link reviews
3.0
"I have the wireless systems in my TV room. They really aren't completely wireless. You still have to run one set of wires from one side to the other. I have hardwood floors and didn't really want to drill holes in the floors but to install it you do unless you want to have the wires run on top of the floor...." Read Full Review »
Sep 06, 2008 by Hicksy
See more negative Bose SL2 Wireless Surround Link reviews
Displaying 1 - 5 of 20 Reviews
Show
Sort by
4.0
    Pros
  • Attractive Design
  • Compact
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • None
"I got excited when I saw "Wireless" surround sound, so the assumption was mine that it would be totally wireless. It's not. You still have to connect speaker wires to the Receiver unit and then out to the surround speakers. The only difference is no wires are run from the front base unit to the r …"  Read Full Review »
Aug 26 2008
Yui
New York
I am:
  • Practical
Reviewed at:
Price: $224.00
Performs Better than the Specs!
5.0
    Pros
  • Consistent Performance
  • Good Length
  • Versatile
    Cons
  • None
    Best Uses
  • Dorm Room
  • High-End Equipment
"If you're sold on BOSE, and you don't want to run wires all through your walls, this is the wireless system for you. I used this to set up the surround speakers on an Acoustimass 10 system. The wires harnesses that come with are 50' long and I used them to run up the wall from a cabinet and in to th …"  Read Full Review »
Mar 18 2009
CSquared Media
Lindale, TX
I am:
  • Power User
Reviewed at:
[2 of 4 customers found this review helpful]
Perfect!
5.0
    Pros
  • Attractive Design
  • Compact
  • Crisp Sound
  • Easy To Connect
    Cons
  • None
    Best Uses
  • Basic Systems
  • Home Theater
  • Smaller Rooms
"I have had a Bose 5.1 surround system for several years. My wife would not allow me to run wires along the baseboard and I never had the time to run them in the ceiling or under the carpet. This is perfect for me! Finally I get to hear my system how it should be heard. Sound is great and setup w …"  Read Full Review »
Dec 25 2008
GadgetMan
Finksburg, MD
I am:
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $224.00
[2 of 2 customers found this review helpful]
purchased for my lifestyle 28 system
5.0
"I recently moved to a new house, and didn't want to drill holes in the walls or floor to get the wires to the back of the room. I was somewhat skeptical about this product and concerned with sound quality. However, I'm happy to say there is absolutely no difference between using the SL2 and hard wir …"  Read Full Review »
Nov 11 2008
frank12345
miami, fl
Reviewed at:
Solid wireless performance
4.0
    Pros
  • Easy To Set Up
  • Easy To Use
  • Reliable
    Cons
  • None
    Best Uses
  • Home
"No noticeable sound degradation for typical home theater uses. just remember, if it's not already clear to you, this just allows you to send a wireless signal from the speaker base unit to the rear of the room. You still need to run speaker wire from the wireless receiver to the rear speakers. Se …"  Read Full Review »
Feb 27 2007
Doug
New York, NY
Reviewed at:
Price: $249.00
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$224.00
$224.00
$224.00
$224.00
BizRate Rating Outstanding 9.4
$224.00
5% off orders at Abt.com
$249.00
Out Of Stock
BizRate Rating Outstanding 9.6
$249.00
No Tax Outside NY
$249.99
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
