Close Login Module
Join
Bose Lifestyle 28 Series III Home Entertainment System
4.3
based on 16 reviews
Ratings Distribution
5 star
9
4 star
5
3 star
1
2 star
0
1 star
1
Category Average
4.1
$1,999.00 - $1,999.99
from 8 stores
Pros
  • Clear sound (6)
  • Easy setup (6)
  • Interfaces well with tv (5)
  • Intuitive controls (4)
  • Thundering bass (4)
  • Rf control instead of ir (2)
  • Attractive design (1)
  • Great sound (1)
  • Interfaces well with all (1)
  • Powerful (1)
See less See more
Cons
  • Non-ergonomic remote (1)
  • Pricey (1)
Best Uses
  • Surround sound solution (6)
  • Larger rooms (5)
  • Movies (5)
  • Living room (4)
  • Smaller rooms (3)
  • Television shows (3)
  • Audiophiles (1)
  • Multiple rooms (1)
  • Office (1)
  • With hdtvs (1)
Where to Buy
BizRate Rating Outstanding 9.6
$1,999.00
No Tax Outside NY
BizRate Rating Outstanding 9.4
$1,999.00
5% off orders at Abt.com
BizRate Rating Outstanding 9.3
$1,999.00
Show all 8 stores
Product Reviews
Last update: Jul 6, 2009
Bose Lifestyle 28 Series III Home Entertainment System Reviews
Most helpful positive review
Most helpful negative review
[3 of 4 customers found this review helpful]
4.0
Excellent quality in a small package
"Excellent sound in a small package. Ideal for city apartments where a typical system would be obtrusive. Was easy to set up, and using the speaker stands the wiring is well hidden (without needing to tunnel through the wall). Do make sure you use the AdaptIQ system to tune the sound -- makes a big difference. Only reservation is the price, which knocks rating down a star. Bottom line is that you can probab..." Read Full Review »
Feb 27, 2007 by Doug
See more positive Bose Lifestyle 28 Series III Home Entertainment System reviews
3.0
Good Audio System
"The system and sound quality are very good, but there are problems. I have had this system for 11 months and it works just fine. The remote operation is troublesome with regards to programming and the volume levels are very hard to get adjusted correctly. I have also had a problem using remote stereo headphones due to heavy static. Direct connect headphones work just fine. The CD/DVD player works very well, but ..." Read Full Review »
Sep 09, 2007 by BradD
See more negative Bose Lifestyle 28 Series III Home Entertainment System reviews
Displaying 1 - 5 of 16 Reviews
Show
Sort by
Good Audio System
3.0
"The system and sound quality are very good, but there are problems. I have had this system for 11 months and it works just fine. The remote operation is troublesome with regards to programming and the volume levels are very hard to get adjusted correctly. I have also had a problem using remote stere …"  Read Full Review »
Sep 9 2007
BradD
Santa Ynez, California
Reviewed at:
Price: $1,999.99
4.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Interfaces Well With TV
  • Stylish compact design
    Cons
  • None
    Best Uses
  • Movies
  • Smaller Rooms
  • Surround Sound Solution
  • Television Shows
"Excellent sound in a small package. Ideal for city apartments where a typical system would be obtrusive. Was easy to set up, and using the speaker stands the wiring is well hidden (without needing to tunnel through the wall). Do make sure you use the AdaptIQ system to tune the sound -- makes a bi …"  Read Full Review »
Feb 27 2007
Doug
New York, Ny
Reviewed at:
Price: $1,999.00
Why Go To The Movies?
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • Intuitive Controls
  • Thundering Bass
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
"Wow...talk about a GREAT sound! Who needs to go the movies when you can have your own theater sound at home?! We debated about spending so much, but knew we were buying quality with Bose. We are not dissappointed. I installed our system in an open great room with 12' foot ceilings. The results …"  Read Full Review »
Jan 23 2008
Sam The Music Man
Prairieville LA
I am:
  • Musically Inclined
  • Professional
  • Tech Savvy
Reviewed at:
Price: $1,999.00
[1 of 1 customers found this review helpful]
Decidely better, but pricey
4.0
    Pros
  • Attractive Design
  • Easy To Set Up
  • Great Sound
  • Powerful
  • RF control instead of IR
  • More »
    Cons
    Best Uses
  • Audiophiles
  • Larger Rooms
  • Offices
  • Smaller Rooms
  • With HDTVs
"Nice product, but it ought to be in light of how much more it costs than most of its competition.
If you have the $$ go for it. However, even if you have the $$, unless you have $$ to "burn", I think that the marginal advantages of the more expensive Lifestyle Systems are simply not worth the …"  Read Full Review »
Feb 1 2007
Golfcrackerjack
Honolulu
Reviewed at:
Price: $1,999.00
Who cares what people say.
5.0
    Pros
  • Clear Sound
  • Easy To Setup
  • More »
    Cons
  • None
    Best Uses
  • Larger Rooms
  • Living Room
  • Movies
  • Multiple Rooms
"This is so easy to use. I don't even have to explain how to use it to people. Although some people argue about the quality of sound of Bose and it's price. You can't argue with its Appearance, Lack of Wires, RF remote and the ability to easily control all your equipment. "
Sep 18 2007
Jason
Los Angeles, CA
I am:
  • Professional
Reviewed at:
Price: $1,999.00
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
$1,999.00
No Tax Outside NY
$1,999.00
$1,999.00
BizRate Rating Outstanding 9.1
$1,999.00
$1,999.00
$1,999.00
$1,999.97
$1,999.99
Out Of Stock
$1,999.00
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
