Bosch PB10-CD Jobsite Radio CD/FM Stereo
#104
3.3
based on 25 reviews
Ratings Distribution
5 star
5
4 star
9
3 star
4
2 star
2
1 star
5
Category Average
3.8
Low Price:
$3.99 at Toolking
 Trusted:
$178.73 at PlumberSurplus.com
Find it at Amazon
$3.99 - $224.00
from 4 stores
More Images
Pros
  • Durable (12)
  • Great sound quality (5)
  • Good value (3)
  • Great reception (3)
  • Lightweight (3)
  • Good battery life (2)
  • High quality (2)
  • Tough (1)
See less See more
Cons
  • Heavy / bulky (2)
  • Pricey (2)
  • Cubical (1)
  • Plastic cord holders (1)
  • Poor reception / weak antenna (1)
  • Poor sound quality (1)
  • Radio reception (1)
Best Uses
  • Everyday (4)
  • Home use (2)
  • Construction (1)
  • Great jobsite radio (1)
  • Job site (1)
  • Work or shop radio (1)
More than Music. Rugged design with many extras. A serious jobsite radio that charges batteries & gives you extra outlets.
Product Features
  • Radio operates off AC power and Bosch Batteries - 12V, 14.4V, 18V, 24V
  • Charges 12V - 24V Bosch batteries - BAT025, BAT026, BAT040, BAT043, BAT045, BAT030, BAT031, BAT120, BAT140, BAT180, BAT181, BAT240
  • 4-way GFCI power outlet - Power-up jobsite tools and equipment. Meets OSHA requirements
  • FM Stereo AM tuner with 20 FM and 10 AM station presets
  • Four preset equalizer settings and enhanced "Bosch Sound"
  • Protective aluminum roll cage - Protects unit from a 10 foot jobsite drop and is designed for increased durability on the job
  • External plug-in wire antenna - Eliminates antenna bends or breaks
Product Specifications
Weight21 lbs.
AM/FM Presets10 AM / 20 FM
Voltage120V AC, 12V DC, 12-24V Bosch Batteries
ChargerBAT040, BAT043, BAT045, BAT030, BAT031, BAT120, BAT140, BAT180, BAT181, BAT240
Unit Size14 x 14 x 14 in.
Engineering No.2610920591
Watts3.5 Watt Radio Amplifier
Power4-way GFCI outlet, 12V DC outlet, Bosch Battery Charger (12V, 14.4V, 18V, 24V)
Cord Length6 ft. Grounded Cord
AntennaExternal Plug-In
Bosch PB10-CD Jobsite Radio CD/FM Stereo Questions
Questions and Answers
Where to Buy
$224.00
$179.00
Code FALLSAVINGS33 : $5 Off Orders Over $50
$3.99
Show all 4 stores
Product Reviews
Last update: Jan 27, 2009
Bosch PB10-CD Jobsite Radio CD/FM Stereo Reviews
Most helpful positive review
Most helpful negative review
[6 of 9 customers found this review helpful]
4.0
The Ultimate Jobsite Radio
"this radio has all you could need on a job except the coffee. when the radio comes in clear it is great, but it may take some time finding the right place. the brackets on the radio which secure the cord are a bit flimsy in comparison to the overall ruggedness of the product. the radio may survive a fall down the steps but the cord holder wont. these are slight oversites and not a reason to put off buying one. t..." Read Full Review »
Feb 24, 2007 by java man
See more positive Bosch PB10-CD Jobsite Radio CD/FM Stereo reviews
3.0
better than the old one but mine still has a problem
"I bought mine from another on-line place for a bit more. But had an older version for three years. The old one works but has famously bad radio reception. Those fav. public radio stations I preferred, Forget it! Only a few top of the charts, boring oldies stations or a common c/w station. Or worst, Rush Limbaugh b/s. Now the new one tunes in much better almost as good as a typical car radio. Good sound but not v..." Read Full Review »
Sep 16, 2007 by datadave
See more negative Bosch PB10-CD Jobsite Radio CD/FM Stereo reviews
Displaying 1 - 5 of 25 Reviews
Show
Sort by
3.0
"I bought mine from another on-line place for a bit more. But had an older version for three years. The old one works but has famously bad radio reception. Those fav. public radio stations I preferred, Forget it! Only a few top of the charts, boring oldies stations or a common c/w station. Or worst, …"  Read Full Review »
Was this Portable Radio review on the Bosch PB10-CD Jobsite Radio CD/FM Stereo helpful to you?
 Report Abuse  (6)  (3)  0 comments
Sep 16 2007
datadave
Amazon
Reviewed at:
Price: $224.00
[2 of 2 customers found this review helpful]
Just an Okay Unit
1.0
"I bought this unit based on the opinion of a friend of mine since he owned one. I was very displeased with the radio, I can only pick up a few stations. Sometimes only two stations. The sound is pretty good, not great, but good. The GFCI outlets quit working also. I pulled them out and low and behol …"  Read Full Review »
 Report Abuse  (2)  (0)  0 comments
Dec 14 2008
D. Sahr
Amazon
Reviewed at:
Price: $224.00
4.0
    Pros
  • Durable
  • Good Value
    Cons
  • Expensive
  • Plastic Cord Holders
  • Radio Reception
    Best Uses
  • Great Jobsite Radio
"this radio has all you could need on a job except the coffee. when the radio comes in clear it is great, but it may take some time finding the right place. the brackets on the radio which secure the cord are a bit flimsy in comparison to the overall ruggedness of the product. the radio may survive a …"  Read Full Review »
Feb 24 2007
java man
saint louis
[3 of 4 customers found this review helpful]
Negative Experience
1.0
"We purchased the Reconditioned Bosch Construction Radio. We plugged it in and it came on for about one minute then would not play a cd, AM or FM radio. We contacted the Bosch Factory direct, about their reconditioned merchandise and they requested we return this radio to them, (shipping prepaid fo …"  Read Full Review »
 Report Abuse  (3)  (1)  0 comments
Dec 21 2007
S. Miller
Leona, TX
Reviewed at:
Price: $224.00
bosch radio
5.0
    Pros
  • Durable
  • Good Sound Quality
  • Great Reception
  • Lightweight
  • Long Battery Life
    Cons
  • None
    Best Uses
  • Daily Use
"i use the radio on the jobsite and its great to use.i can put the battery in it and it will last all day and the sound is great u can hear it everywhere. also the aux jack is good cause i can plug in the mp3 player and listen to what i want all day. thanks again for the radio it was at good value "
Nov 19 2008
neichco
wainwright alberta
I am:
  • Practical
Reviewed at:
Price: $139.99
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
