Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express
#6
4.5
based on 48 reviews
Ratings Distribution
5 star
28
4 star
16
3 star
3
2 star
0
1 star
1
Category Average
4.1
Low Price:
$188.95 at Adorama
 Trusted:
$189.05 at B&H Photo Video
Find it at Amazon
$188.95 - $189.05
from 3 stores
More Images
Pros
  • Easy to install (39)
  • Easy to use (31)
  • Reliable (30)
  • Quality output (28)
  • Highly compatible (6)
  • High quality (4)
  • Fast (3)
  • Quiet (3)
  • Improves performance (2)
  • Compatible with color (1)
See less See more
Cons
  • A bit unstable (1)
  • Adds complexity to set up (1)
  • Advertise s-video (1)
  • Break out cable lacks bnc (1)
  • Difficult to use (1)
  • Lacks functionality (1)
  • Limited codec support (1)
  • Manual is useless (1)
  • No 1080p (1)
  • No box for analog con. (1)
Best Uses
  • Multimedia (23)
  • Everyday (14)
  • Graphic design (8)
  • Independent films (4)
  • Video editing (4)
  • Gaming (3)
  • High-end multimedia (3)
  • Home movies (3)
  • Studio (3)
  • Complex projects (2)
Provided by B&H Photo Video
Intensity Pro HDMI and Analog Editing Card - PCI Express
Specification Description
Model BINTSPRO
Select For Macintosh,For Windows
Software Versions Capture Hardware & Accessories
Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express Questions
Questions and Answers
Where to Buy
$189.05
No Tax Outside NY ends 09/09/15
BizRate Rating Outstanding 9.7
$188.95
BizRate Rating Outstanding 9.1
$189.05
Product Reviews
Last update: Nov 12, 2009
Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express Reviews
Most helpful positive review
[17 of 17 customers found this review helpful]
Most helpful negative review
5.0
Competent HDMI/Component Solution
"What I mean by "easy" is that the Intensity Pro does what it is supposed to do and it does it right without causing problems.I have needed an affordable High Definition video capturing and processing solution for years. Every low-cost hardware product up till now was limited to 480i, or else was severely limited, compressed high definition. How sweet, now with the Intensity Pro, to see great color in perfect hig..." Read Full Review »
Apr 01, 2008 by grdSavant
See more positive Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express reviews
3.0
Good but limited
"Intensity Pro works well, but is limited to only a few of the older, more popular HD codecs. If you are going to be using just these codecs it outputs and plays fine. However if you are not going to be using just these codecs then the card is not usable and will output only a single frame as a still. It also does not support the newer more advanced version of the apple codecs released with Final Cut Studio 3. ..." Read Full Review »
Nov 12, 2009 by MIstair
See more negative Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express reviews
Displaying 1 - 5 of 48 Reviews
Show
Sort by
5.0
    Pros
  • Easy To Use
  • Highly Compatible
  • Improves Performance
  • Lots Of Features
  • Professional Quality
    Cons
  • Read the Whole Manual
    Best Uses
  • Complex Projects
  • Home Movies
  • In The Studio
  • Independent Films
"What I mean by "easy" is that the Intensity Pro does what it is supposed to do and it does it right without causing problems.I have needed an affordable High Definition video capturing and processing solution for years. Every low-cost hardware product up till now was limited to 480i, or else was sev …"  Read Full Review »
Was this Sound & Video Card review on the Blackmagic Design Intensity Pro HDMI Editing Card with PCI Express helpful to you?
 Report Abuse  (17)  (0)  0 comments
Apr 1 2008
grdSavant
SW Florida
I am:
  • Hobbyist
Reviewed at:
Price: $189.05
[4 of 4 customers found this review helpful]
HD Preview on a Budget
4.0
    Pros
  • Easy To Install
  • Quiet
    Cons
  • A bit unstable
  • No 1080p
    Best Uses
  • HDTV Preview
"We use the product to preview to an LCD HTDV while editing video in the Adobe Creative Suite and also with Sony Vegas Pro. For the price, it's a handy little card.
It's inexpensive, easy to install, and will transmit your preview to any HDTV with an HDMI input. Works with a number of applicatio …"  Read Full Review »
 Report Abuse  (4)  (0)  0 comments
Aug 17 2008
Wrightsvile Beach Studios
Wilmington, NC
I am:
  • Heavy Duty User
Reviewed at:
Price: $189.05
[3 of 3 customers found this review helpful]
Incredible product
5.0
    Pros
  • Easy To Install
    Cons
  • You should have RAID
    Best Uses
  • Everyday use
  • Gaming
  • Graphic Design
  • Multimedia
  • Recording gameplay
"We use this product to capture video footage of our Xbox 360 game, directly from the Xbox 360 to our computers. We capture in 720p, the native resolution of the game.
One warning: Blackmagic, the creators of the card, suggest a four hard drive RAID array (four times the speed) to use this produ …"  Read Full Review »
 Report Abuse  (3)  (0)  0 comments
May 11 2009
Xonatron
Nova Scotia, Canada
I am:
  • Power user
Reviewed at:
Price: $189.05
Works as advertised!
5.0
    Pros
  • Easy To Install
  • Great Value
  • Highly Compatible
  • Reliable
  • versatile
    Cons
  • None
    Best Uses
  • SD-HD Capture-Playback
"This product does exactly what its description says it does - captures standard definition and high definition via various analog connections and HDMI connections and outputs audio and video back out via similar connections. If you need an inexpensive way to jump into working with a wide variety of …"  Read Full Review »
Aug 2 2008
bsatchfield
Tampa Bay, Florida
I am:
  • Heavy Duty User
Reviewed at:
Price: $189.05
Good but limited
3.0
    Pros
  • Easy To Install
  • Easy To Use
  • Quality Output
  • Reliable Performance
    Cons
    Best Uses
  • Standard HD Only
If you are going to be using just these codecs it outputs and plays fine. However if you are not going to be using just these codecs then the card is not usable and will output only a single frame as a st …"  Read Full Review »
Nov 12 2009
MIstair
LA
I am:
  • Power user
Reviewed at:
Price: $189.05
pages: 1 2 3 4 5 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
