BIC America V1020 160 Watt 10" Powered Subwoofer
#343
4.7
based on 15 reviews
Ratings Distribution
5 star
10
4 star
5
3 star
0
2 star
0
1 star
0
Category Average
4.4
$145.25 - $338.80
from 16 stores
More Images
Pros
  • Great sound quality (8)
  • Attractive design (6)
  • Easy to connect (6)
  • Powerful (6)
  • Great boom for your buck (1)
  • Great price (1)
  • Powerful bass (1)
See less See more
Best Uses
  • Smaller rooms / apartments (7)
  • Basic systems (6)
  • Audiophiles (3)
  • Large rooms (2)
  • Med-sized rooms (1)
Provided by Overstock.com
Showcasing a handsome black laminate finish, this 160-watt subwoofer from BIC America features a tuned Venturi port and makes a fine addition to any home theater system.
Features include:
  • Down-firing, long-throw subwoofer with tuned Venturi port
  • BASH technology powered amplifier
  • Adjustable crossover, automatic on/off signal sensing
  • Dolby Pro Logic/Dolby Digital switchable input
  • S/N ratio of greater than 80 dB
  • Gold, 4-way binding posts with external fuse and auto on/off
  • 10-inch woofer
  • 160 watts power handling
  • Black laminate finish
  • 26-180Hz variable frequency response
Specification Description
Model BICV1020, V-1020, V1020, V1020B
UPC 729305002570
Benefits Uses a high power amplifier design by BASH technologyFeatures 160 RMS watts and up to 350 watts at peak powerHeavy-duty, dow
Capacity UOM mAh
Connectivity technology Wired
Country Of Origin China
Description Header Feel the bass.
Display Catalog Number 55031599
End Product Indicator Yes
Frequency response 26-180Hz
Grille color Black
Impedance 8 ohms
Manufacturer Labor Warranty 2
Manufacturer Part Number V1020
Manufacturer Parts Warranty 2
MAP Price 0.0
Model V1020
Operating Temperature UOM ° F
Peak power 350 watts
Powered sub Yes
Product Depth 13
Product Dimensions UOM inches
Product Disclaimer *Dolby and Dolby Pro Logic are registered trademarks of Dolby Laboratories Licensing Corporation. **DTS is a registered trademark of Digital Theater S
Product Height 16.5
Product Type Home speakers
Product Weight 34
Product Weight UOM pounds
Product Width 15
RMS (continuous) power 160 watts
Sensitivity 90 dB
Speaker type Subwoofers
Speakers included 1
Supported Languages English
Woofer size 10 inches
Woofer type Down-firing, long-throw
BIC America V1020 160 Watt 10" Powered Subwoofer Questions
Questions and Answers
Where to Buy
Product Reviews
Last update: Jan 6, 2009
BIC America V1020 160 Watt 10" Powered Subwoofer Reviews
Displaying 1 - 5 of 15 Reviews
Show
Sort by
[1 of 1 customers found this review helpful]
Worth Every Penny!
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great Sound Quality
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Smaller Rooms
"I have to admit, I was extremely pleased with this purchase. The BIC V-1020 was worth every penny. I had done extensive research before making my purchase. I had read several reviews. I also did alot of price shopping. Installation was a breeze, after purchasing an RCA cable, and the sound qual …"  Read Full Review »
Was this Speaker & Subwoofer review on the BIC America V1020 160 Watt 10" Powered Subwoofer helpful to you?
 Report Abuse  (1)  (0)  0 comments
Sep 25 2007
Tazman5858
Waltham, MA
I am:
  • Audiophile
  • Practical
  • Tech Savvy
Great bang for the buck
4.0
    Pros
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Audiophiles
  • Basic Systems
  • Smaller Rooms
"For the price you really can't go wrong. I wanted to expand my current BIC system and begin heading down the road to a surround system. This was the next piece of the puzzle and I'm quite pleased with this unit. I especially like the versatility of hook-up with either the direct sub line or line lev …"  Read Full Review »
Dec 13 2007
RB_WI
Brooklyn, WI
I am:
  • Audiophile
  • Musically Inclined
  • Tech Savvy
It is a keeper
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Great BOOM for your buck
  • Great price
  • More »
    Cons
  • None so far
    Best Uses
  • Basic Systems
  • Med-Sized Rooms
  • Smaller Rooms
"My old sub played out and I needed a new one at a
great price.I put in War of the Worlds to test
it out. It blew me and my wifey away. It is
also great for music. Old cds have new life
with awesome bass. "
May 16 2007
JGthehappycustomer
Brentwood, TN
I am:
  • Audiophile
  • Practical
BOOM
5.0
    Pros
  • Attractive Design
  • Easy To Connect
  • Powerful
    Cons
  • None
    Best Uses
  • Basic Systems
  • Larger Rooms
  • Smaller Rooms
"Be sure you have the system to back up the power provided by this sub. It could be "too" bassy (if possible) if the rest of your audio is lacking. Make sure it has a good clear feed to maximize its awesomeness. "
Nov 24 2007
awestrum
Valparaiso, IN
I am:
  • Practical
  • Tech Savvy
"Wow...is all I can say ...
5.0
"Wow...is all I can say about this subwoofer. The reason I bought this model was because I had heard some rave reviews about its performance to price ratio. I hooked it up, threw in war of the worlds, and knocked many things down/over in my room to my suprise. This sub is very well designed and put t …"  Read Full Review »
Dec 20 2005
Gene. B
Undisclosed
pages: 1 2 3 4 Next »
Email Address: (required)
Comments:
or Cancel
Where to Buy
Selling products online?
Engage, Connect, and Sell.
www.powerreviews.com
Close Login Module
Join
